Question about Sunbeam Heating & Cooling
TA-08MB portable AC is dumping water on floor rather than in water tank
4 Suggested Answers
galati2k
  • 281 Answers
SOURCE: I don't see the dirty water re-entering the tank to dump.
your suction tube where the water gets sucked up is clogged
Posted on May 03, 2009
  • 151 Answers
SOURCE: hot water tank blew and saturated the storage room
Place on max setting , draw the most moisture from air. Watch for mold in carpeting
Posted on Oct 27, 2009
espressonist
  • 1711 Answers
SOURCE: Portable AC unit Delonghi Pinguini
This is normal exceed water in the reservoir should be removed and empty out from the AC and put back empty.
Posted on Sep 06, 2011
MANUAL FOR TA-08MB
Please provide me with the following
Brand name/Manufacturer
Model number and serial number
Specify the product
And I'll get back to you asap
Regards
Jun 09, 2016 | Heating & Cooling
How do I drain water from a toyotomi portable ac unit
1. put it on higher position near water drainage, window...etc
2. make hole in water tank
3. put tube in hole and lead tube in drainage or outside (hole in frame of window recommended for long term use). Fix tube with glue
4. take care that water tank is higher than end of the tube
5. done
Jul 06, 2014 | Toyotomi TAD-T40LW 14000 BTU Portable Air...
Whers does water evacuate from portable ac unit
there is a holding tank in the bottom of the unit, on the front right by the floor is a rubber cap that plugs this tank. water evaporates from there, if the tank gets too full, the power button will flash red and the unit will not turn on. put pan under, pull plug and drain if this happens. if it doesnt happen, don't worry about exhausting the water as its not a problem.
Jun 10, 2014 | Maytag Portable Air Conditioner M6P09S2A
Sunbeam tm-08mb : error code E4 and water on the floor
the dry system for the condensing watter is dirty and it must to clean .
Dec 27, 2013 | Heating & Cooling
I have an kenmore elite A100E portable air conditioner. I have two questions; 1- It drains water from the back pipe outlet which makes my floor wet. How to collect this drained water to stop it damaging...
Yes is does work as a dehumidifier, when it's in dehumidifier mode. Using just the AC mode, will slow up the collect ion of water some. However, the tank will still need to be drained occasionally. There are 2 ways to train the tank.
1. In to a low sided pan or bowl, capable of holding at least 1 quart of water.
2. Roll the unit to a floor drain or outside to drain the bucket.
Hope this helps and thanks for choosing FixYa.
Jul 31, 2011 | Heating & Cooling
My Danby DPAC1010 Portable Air Conditioner is dehumidifying when simply in AC mode. I don't want it to, but if fills up a 2 gallon bucket every 2-3 days. I've had it overflow twice and I cannot...
The only way to stop it from dehumidifying is to stop it. A dehumidifier is a AC that is 'tuned poorly'. In your machine, while in dehumidify mode, you actually are running the AC in 'slow".
It is a law of physics. Warm air can hold moisture. Cold air can not hold moisture. When you remove the heat from the air, the water has to go somewhere, so it condenses on the coils and drips into the tank. Yes, that is true: Heat is a thing, you have to remove heat from the air. You don't simply "cool it", you remove the heat.
Your Danby should have a automatic shut off that comes into play when the condensate tank gets full. MY Danby, which is a sllightly different model than yours, has a connection that allows me to connect a hose that I lead to a floor drain to disponse of the condensate (water).
If yours is not equipped with a shut off nor a drain and you say it fills every 2 to 3 days, the options I see that you have is to dump it every day, or - don't run it all the time, or - turn the setting to a higher number which will reduce the AC and dehumidifying effect. On the down side of that, your humidity will remain high at the higher setting.
Thanks for your question @ FixYa.com and thanks for letting me assist you this evening.
Jun 29, 2011 | Heating & Cooling
My unit is leaking tons of water only when a/c is on for a while. It leaks out of base and I have to drain tank every day. Help!!!
It is supposed to "leak" water into it's reservoir and it needs to be dumped when it gets full. That water is the humidity that the a/c is pulling form the air inside your home. As long as it's going into the reservoir and not leaking onto your floor then it is working properly.
Jun 24, 2011 | Windchaser PACR10 Portable Air Conditioner
LX-140 SOLEUS A/C DUMPED WATER ALL OVER MY WOODEN FLOOR........THE TANK ALWAYS GETS EMPTIED AND CONVINCED THAT THE WATER IS COMING FROM THE BOTTOM OF THE UNIT, I TURNED IT OVER AND WATER CAME POURING OUT...
I would recommend that you manually fill the tank so you can watch it and see when it is completly full. If tank full sensor does not work then I would replace it. I think it is probably bad as it should not only tell you the tank is full it should also shut it off. Thank you.
Apr 29, 2011 | Soleus KY-34 Portable Air Conditioner
Will not operate due to mositure.
Probably needs the water jacket dumped OR the pump has failed. Just guessing you have a portable ac. Have a typical manual for these.
10,000 BTU portable AC service manual
Sep 27, 2010 | Heating & Cooling
May 03, 2009 | Vacuums
Heating & Cooling Logo
82 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
