Question about Dishwashers
I have a Whirlpool ADP 7552 dishwasher. The cycle appears to have finished although not completely drained and is flashing FR fault code. What is this and how do I fix it.
  • allomike Jun 26, 2009
    My Whirlpool ADP 7552 dishwasher has fault code FR displayed and the depart button is flashing but will not run when pressed. Also the program is stuck on one program only and the machine has not completely drained. I have tried disconnecting the power completely and reconnecting but the problem persists. Any ideas?
    President:
  • 2,187 Answers
Does your drain hose go directly to a sink? The water in the sink may be backing up to your dishwasher which may be the source of your problem.
Posted on Jun 26, 2009
    Sergeant:
  • 175 Answers
Hi..it is probably due to the electronic control
error.
check it out..
thank u..
kindly rate my response..
Whirlpool adp 951
I have nardi dishwasher model LSFHLX IT SHOW E2 error after completing the programe what problem plz help
Dec 15, 2013 | Dishwashers
Whirlpool dihwasher adp 4552. Water comes into dishwasher, appears to start cycle then water is drained out again and light flashes to show a problem!
This is a typical anti flood activation due to the anti flood device (polystireen float and micro switch) at the base of the washer detecting a water leak / spill. This device puts the washer in pump out mode. Check to see if water at the base is causing the polystireene float to activate the switch. Dry the water and rectify the fault (normally a leaky pipe or pipe clamp) and this should solve the problem.
Mar 25, 2010 | Dishwashers
Whirlpool adp 6600 will not function start light is just flashing
Whirlpool adp 6600 will not function start light is just flashing. Waht di I do?
Sep 17, 2009 | Whirlpool 24 in. ADP6940 Dishwasher
Dishwasher adp 4601 when switched on the pump activates.and after 2 mins start lamp bliks and pump goes off
The number of flashes indicates the fault. Reset machine by holding down the start button for 3 secs, then start a new cycle. If fault reoccurs, the number of flashes indicates fault eg 3 flashes, stop, 3 flashes stop, indicates F3 fault.
Faults listed below- advice on repair depends on which fault your machine is indicating, but may give you an idea of what to look for
1flash=NTC (temperature sensor) break- NTC outside normal range.
2flash=water leakage-float switch in base activated.
3flash=heating fault(check element.NTC,control board).
4flash=drain error-blockage in pump or drain system,or faulty water indicator switch.
6flash=water inlet fault-check inlet valve, check inlet hose not kinked
7flash=flow meter failure (flow meter measures water intake volume-large plastic weir located on left hand side of machine-reomve side panel to access)
These a most common faults, but further advice on repair requires counting flashes when fault occurs.
Aug 09, 2009 | Whirlpool Dishwashers
Dishwasher (Whirlpool ADP 952) not working
I have a whirlpool ADP 952 and the start button is flashing and it won't work
May 25, 2009 | Dishwashers
Our whirlpool ADP 6565 dishwasher stops very close to but short of the end of the cycle, with the on-button flashing. If we press that button for a few seconds, it starts again and completes the cycle. I...
It appears that you have a timer malfunction. at the point that the timer stop, you need to listen closely to any sound from the timer. if no sounds emerges, repalce timer
Jul 30, 2008 | Whirlpool Dishwashers
WHIRLPOOL ADP 8540 dishwasher has blinking light on all the time (blinking in cycles of 4). When you turn it on (by holding the button down for around 4 seconds) it wont complete the cycle and you need to...
WHIRLPOOL ADP 8540 dishwasher has blinking light on all the time (blinking in cycles of 4). When you turn it on (by holding the button down for around 4 seconds) it wont complete the cycle and you need to keep restarting it. can anyone let us know what the problem may be. Thank you
Jul 17, 2008 | Whirlpool Dishwashers
Whirlpool adp 5540
My dishwasher isnt working anymore after i cleaned the filters? i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere?
It is a Whirlpool ADP 5540
thanks for your help
**** the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
May 13, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool adp 8540 - 7 flashes
replace the control board in the console
Apr 10, 2008 | Dishwashers
Dishwashers Logo
81 people viewed this question
Top Dishwashers Experts
