Question about Konica Minolta Maxxum 7D / Dynax 7D Digital Camera
M42 adaptor Minolta 7D does not see lens attached via M42 adaptor.
    Brigadier General:
  • 3,006 Answers
Quite right too. When the M42 adaptor is fitted there is absolutely no exchange of information between the lens and the body: M42 lenses pre-date all of those later developments. Your camera will also be unable to stop down the lens automatically when taking the picture, most M42 lenses don't even stop down automatically when connected to an M42 body.
You need to do things the old-fashioned way. Your camera needs to be set to meter manually, shutter priority mode may also be used. In manual mode you focus the lens as normal with the aperture ring set to the lowest aperture number (i.e.aperture is wide open).
You then make sure that the lens in in manual mode as well and stop down to whatever you want, if the image remains bright enough then you can adjust the precise focus using the hyperfocal principle if you like which takes advantage of the increased depth of field of a stopped down lens.
In manual mode, you then tell the camera what aperture you have set (read it from the lens barrel) and set the shutter speed using the camera's light meter to guide you. If using shutter priority mode then the camera will choose the shutter speed for you.
Check everything is set as you intend and press the shutter.
It all sounds long winded but is exactly how many of the world's greatest photos were taken and soon becomes second nature. You also learn far more about the relationship between aperture, shutter speed and ISO settings and will be able to talk about reciprocity like you know about it!
Posted on Jun 26, 2009
Is it possible to convert a sigma lens to fit a canon body or by using an m42 adapter?
Sigma makes their lenses with a variety of mounts. If the lens has a Canon or M42 mount then there is no problem. If it has a Minolta mount, for example, then replacing the lens will be easier and just as cheap as changing the mount. If it has Nikon mount, you can buy adapters to fit it to Canon or M42 bodies.
May 12, 2012 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
What's your pwill Tamron AF 1780 Lens 80mm - 210 work on a sony 200A dslrmmroblem?
you need a proper t2 adapter. when you remove the m42 adaptor on tair lens, you can attach the proper t2 to nikon adaptor on it. check my tair 300 photo. it has "t2 to m42" adapter on it. please be sure that find the correct adapter. i bought several adapters to find the correct one. one of them was different than t2 adapter but looking alike and sold as t2 by seller. it is hard to find the correct adapter. i guess there are variants of that standard(which is odd).
Feb 01, 2012 | Tamron 80-210mm f/4.5-5.6 Lens
A700 flashing "lens" message
Is the lens switched to manual as well as the mode dial. If the compatable lens is a minolta requiring an M42 adapter make sure that the protruding arm/rod is operating the shutter when depressed and that the adapter when fitted operates the lens when turned from auto to manual. Good luck.
Jun 27, 2009 | Sony Alpha DSLR-A700
Camera will not recognize the lens
Hi, I have a Minolta 7D. I bought an M42 screw lens adapter, an almost flat plate, however the camera kept saying "no lens detected". Then somewher on the web I found a solution: On the menue screen I found "Shutter Lock" with the choice On or Off. By switching to off I can now use 42mm lenses. Though there is no AF and the metering works with setting the aperture manually. Good luck and maybe you find the Sony to be the same.
Roy Smith
Jan 26, 2009 | Kenko Teleplus MC-4 DG for Konica-Minolta...
Instuctions for opteka 650-1300 lens for use on konica minolta
Try turning off the shutter lock.. In my Dynax 7D manual it tells you to turn off shutter lock when attaching to a telescope or microscope this is what this lens basicly is .The shutter lock is turned on and off in section three of the custon menu on my Dynax ,check your manual for your camera to find out where to turn on and off shutter lock, hope this helps
Jan 18, 2009 | Canon Opteka 650-1300mm F8/16 Super...
Looking for Digital Camera to use lens
Your Minolta QTsi Maxxum takes a Konika Minolta AF lens. These lenses work on these Konika Minolta DSLR cameras:
DYNAX 5D / Maxxum 5D
DYNAX 7D / Maxxum 7D
Dec 16, 2008 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Minolta 7000 Maxxum
The Minolta Maxxum 7000 uses a Minolta A mount, which is also used on the Sony Alpha series, as they bought out Minolta's technology. All Maxxum lenses should work for the most part on the Sony Alpha series of DSLR's, including the autofocus.
-John
Sep 15, 2008 | Tamron 28-300mm f/3.5-6.3 XR Lens for...
Camera does not turn on
did you recently have the ccd replaced?
May 09, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Lens adaptor
The good news is that it is possible to get the camera to operate with the lens & adapter :-)
The bad news is that you'll only be able to use it in manual mode :-(
To get the camera(s) to actually fire, you will need to change some settings.
For the Maxxum 7:
Go to Custom settings (No.16) and change to 'Lock Off'.
For Maxxum 7D
Go to the settings menu (purple cog icon) and then to sub-menu 3. Change Shutter lock to Off.
With the camera set to Manual mode, you can still use the built-in meter. Half-press the shutter button and you will see a metering scale appear in the viewfinder. This will indicate whether the shutter/aperture setting you've selected will over/under-expose the image. Adjust your settings until the indicator bar is over the zero.
Hope this helps,
Matt.
PS. Even if you could somehow modify the adapter, the lens won't have the necessary electrical and mechanical coupling for the cameras to control it in an automatic mode.
Mar 05, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Sigma 600mm lens mount
You may be able to find a Konica toMinolta or Konica to M42 adaptor. Some adaptors are available...some aren't; it depends upon the film plane dist. and mount diameter. For instance you can get a Nikon to Canon adaptor, you can't get a Canon to Nikon adaptor. Email KonicaMinolta and ask them.
Jan 18, 2008 | Sigma Super Telephoto 600mm f/8.0 Mirror...
Konica Minolta Maxxum 7D / Dynax 7D Digital Camera Logo
189 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
