Question about Garden
My weed eater will not ignite the gas
My weedeater will not ignite the gas when it gets to the cylinder
  • 181 Answers
Pull the muffle off and look inside the cylinder,if you see score marks it means that you need to replace the piston and cylinder,usually they are not worth rebuilding,you are looking at $125.00 to $175.00 to replace these parts.that price does not enclude any labor cost.hope this helped,let me know.......................
Posted on Jun 26, 2009
My hand held blower wont spark plug and carb.replaced still wont start
If the plug is wet with fuel and it is firing then pull the muffler and for a struck ring. Struck and bad score cylinders will cause one not to start as you need at least 100 psi of compression to ignite the fuel mix.
These are okay then check the ignition of the flywheel to coil relationship as it could be a sheared flywheel key. Note most 2 cycles are now using cast in key as part of the flywheel itself.
Mar 14, 2015 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
What fuel do I put in the weed eater gas blower fb25?
Regular unleaded with whatever oil mix the fuel cap has on it.
Try to avoid gasoline with high ethanol content. You can look online and find alcohol-free gas in your area. You wont regret it!
Oct 05, 2014 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
What is gas to oil mix ratio on weedeater string trimmer
The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
Sep 19, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Weed eater fb25 25cc gas blower wont start
change the spark plug--put fresh fuel in gas tank 89 octane mix
Sep 04, 2014 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
No spark on Weed Eater FB25 25cc Gas Blower
Test the kill switch first, disconnect the kill switch and see if you have spark. Then the kill switch is not working or is grounding out. If not, the problem could be the ignition module.
Mar 16, 2013 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
How do you fix a broken gas line to gas tank that was previously glued but does not hold and leaks gas to a Poulan GE21 weedeater?
Buy a new gas tank! Are you serious! Or buy a new weed eater, if you can't live without this one, those models are cheap, don't waste your time.
Apr 08, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
Jun 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
