Question about Maxtor Hard Drive
Installation of a Maxtor OneTouch III, Mini Edition external hard drive.
I installed the three phases of software for my Maxtor OneTouch III, Mini Edition external hard drive but the Unit does not show up on my computer. I had the drive connected to a USB outlet. My computer does not recognize it. What am I doing wrong?
  • Anonymous Mar 23, 2014
    windows 7 system does not recognize my Maxtor OneTouch 4 External drive
  • 1,006 Answers
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Posted on Nov 07, 2007
The Maxtor OneTouch III Mini Edition series ...i have a I/O device error and dont want to open...
If your external harddrive came with software, you may want to reinstall it. If not you may have to go the the website for the Maxtor One Touch 3 and download the driver for the unit.
You may also want to open the device manager and check to see if your usb port is having trouble. More than likely it is the driver itself>
Feb 19, 2010 | Maxtor OneTouch III Mini Edition 120GB...
Other computers dont recognize my Maxtor OneTouch 4 Mini
Please Make sure you External Hard disk USB cable is working correctly. Your cable is probably having partial contact, so try another cable
May 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Need drivers for a Maxtor 80GB Onetouch III Mini edition
I have a Maxtor Ext HD myself. Maxtor has a website. Try www.maxtor.com or Google it and you will find their web site. Then search for your HD and do a search for the download of the drivers needed for your HD
Mar 13, 2009 | Maxtor OneTouch III Mini Edition 120GB...
NEED SFTWARE FOR MAXTOR ONE TOUCH III MINI EDITION
Software downloads are available from the Seagate support site. Here is a link to the download page for Maxtor OneTouch III family.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-downloads&vgnextoid=35c6069f356d3110VgnVCM100000f5ee0a0aRCRD
Hope it helps!
Mike
Jan 04, 2009 | Maxtor OneTouch III Mini Edition 120GB...
NEED SOFTWARE FOR mAXTOR ONE TOUCH III MINI EDITION. lOST
Software downloads are available from the Seagate support site. Here is a link to the download page for Maxtor OneTouch III family. It should provide the latest version of all software that came with the new unit.
Hope it helps!
Mike
Vista Home Premuim Use with Maxtor onetouch
Software downloads are available from the Seagate support site. Here is a link to the download page for Maxtor OneTouch III family. It should provide the latest version of all software that came with the new unit, including "Updated software to run in Windows Vista. Also can be used in case the original software that was preloaded on the drive has been erased."
Hope it helps!
Mike
Nov 30, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Sortware for maxtor onetouch 111 mini edition to install in the maxtor onetouch 111 mini edition not compatible with MS vista ultimate 64bits
Here is the link to download the software for the Maxtor Onetouch III
OneTouch III USB
OneTouch III FireWire 400/USB (all models other than ones starting with FA)
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-maxbu-vista&vgnextoid=c42f69a859d63110VgnVCM100000f5ee0a0aRCRD
Or
OneTouch III FireWire 800
OneTouch III Turbo
OneTouch III FireWire 400/USB models starting with FA
Use this :
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-emc-vista&vgnextoid=b6623428ab622110VgnVCM100000f5ee0a0aRCRD
Good Luck.
Live, Love, Laugh.
May 11, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Maxtor Hard Drive Logo
166 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
