How to remove the front panel of ge top loading washer model wcxr 1079a
The washer won't spin or agitate. I need to take the front panel off to take a look to see what the problem is. Can you help????
  • 42 Answers
SOURCE: I have a ge profile
I would check your belt. From what you've told me, your electric pump is working and receiving power from your lid-switch, but your motor and transmission is not turning/agitating.
Meaning, your belt is most likely, NOT engaging or grabbing your pulleys to rotate the motor/tranny. Belts will ware and tare, just like your vehicle fan belts. Change it! You should be good!
If not your belt, your lid switch may be the culpret. However, from what you've described; very unlikely because your water pump is turning on and receiving power from the "lid-switch". The switch becomes defective after constant use and slamming/dropping of the door. The purpose of the lid-switch is to prevent accessing your clothes when in spin-cycle (dangerous)
Posted on Jan 26, 2009
  • 4 Answers
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Posted on Feb 28, 2009
  • 56 Answers
SOURCE: GE washer agitates but won't spin
I think you may have a stopped up pump does it drain the water out if not it will not spin. A putty knife inserted 2 inches in from each side will release the spring catches and gently pull on front as you release sprins then look to the bottom right hand side and there is the pump clamp the tub to pump hose or **** water out with a shop vac take off tub to pump hose and then two 3/8 in screws that hold down the pump turn over where you can look in the pump may have an obstruction as always disconnect power before service.
Posted on May 31, 2009
  • 3361 Answers
SOURCE: how to remove the front panel of a ge top load
Use a putty knife to push in the clips on the top right and left front side of the panel. These clips are about 2 inches in from each side where the top meets the front panel. When you push in on the clips position your fingers on the side of the panel to pull out as you push the clips in. Open the control console and retrieve the tech sheet inside. It will describe how to open the panel.
Posted on Sep 19, 2009
  • 289 Answers
SOURCE: I have a ge profile top load washer. the agitator
if the agitator just spins than you have a bad transmition.
Posted on Dec 29, 2009
  • 43501 Answers
SOURCE: GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Posted on Jun 12, 2010
0 characters
1 Points
Hpw to remove agitator on ge model wvsr106dww
If you look around, I think under the control panel there is usually a diagram explaining how to do this. It also has the electrical schematics on it.
Dec 26, 2011 | GE Washing Machines
How it works: Late model Ge top loading washer
The late model top loading GE washer is much different than it's original models that were so much more dependable than these newer ones are. To access the innards you must forst remove the front panel. Older models had the top pop up first but these newer models have the top bolted down. To get the top up you must first remove the front panel by using downward force on the top between the tiop and the front panel. It is not easy even for eperienced techs but cuss it a minute and it will come off. Once it is off you will notice the washer has an elecetric pump. Strings and junk get into this pump. It is easy to take apart and cleanup. The tub is suspended on 4 rods and the lateral movement is kept in check by 4 rubber cord mounted to the top called bungies. The motor and tranny can easily be accessed by removing the tub from the washer. After disconecting the power cable and pump the tub lifts out. Not all GE washers use the same motor or the same transmission method. Some do not even have a tranny. I have some GE washer service manuals.
GE front access late model washer
on Dec 13, 2010 | Washing Machines
My daughters GE same model washer will not agitate. Stop agitating after just a few months after being purchased. I believe this is a trait from this type of washer. Perhaps GE needs to recall them all...
Premature failure usually is a reuslt of overloading and/or not enough water. So, there is a rubber drive component that fails and some models have agitator pawls, or dogs that fail. Both are fairly easy to change, and not pricey, except for labor..
Feb 07, 2011 | GE WBSR3140DW Top Load Washer
Jun 11, 2010 | GE WVSR1060A Top Load Washer
Washer will only spin with vey light load but seems to agitate just fine
Sounds like the belt is worn , to get to it you need to remove the top and front panel of the machine.
Nov 01, 2009 | GE WBSE2090A Top Load Washer
I have a wcsr2070t2ww (GE) that will not agitate. it will spin, drain, and make noise during agitation cycle but no movement. any ideas?
The belt is definitely broken. to get to it you will need to remove the top of the machine to remove also the front panel.
Oct 28, 2009 | GE WBSE2090A Top Load Washer
I own a ge hydro washer. It won't spin or agitate
If you hear the motor go through the stages, but nothing is happening in the tub, the motor belt may be broken or off.
Aug 31, 2009 | Washing Machines
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
ck lid switch can be acessed by pressing clips at front edge of front anel and pulling panel off
Nov 20, 2008 | GE WWSE5200B Top Load Washer
there are two spring tabs between the front cover and top lid of the machine.. i used a small screwdriver and stiff puddy knife. you have to push in the tab and then lift up..pins will stay in the lid... slide out of the front panel
Sep 04, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
713 people viewed this question
Top Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
