Question about ASUS P5VD2-MX SE Motherboard
Atk 0110 acpi utility error
Some time ago i started getting this error. I don't what happened to precipitate the error but I can't get rid of it! I've gone to different forums and asked and i've tried different solutions (downloading ai booster, removing device from device manager) and the problem won't go away.
Please help!
  • 883 Answers
Re: atk 0110 acpi utility error
Try disabling the power saving features at the BIOS startup screen. this is an ACPI (advanced configuration power interface) error. I think that Windows does not like the BIOS settings so it just errors out.
Posted on Nov 06, 2007
0 characters
3 Points
Why ACPI not supported by upgrade to windows 7
acpi is supporrted by win 7 just make sure ist on in the bios and download acpi driver from the motherboard factory
Microsoft ACPI Driver Windows 7 Service batcmd com
Sep 05, 2014 | Motherboards
Why error 'ACPI not supported' when installating windows 7 home premium
did you start with the application disk? that has to be first then the web will find the rest
A problem detected and windows has been shut down to prevent damage to your comp. I this is first time that u have seen this stop error screen restart pc. If this screen appears again follow these...
This happens when your operating has a problem with it's hardware, e.g or ram etc. Also some windows major files like DLL are gone missing by chance. Try to restart the Pc and press f8 until you get the options to start in safe mode, If safe mode dosn't works and gives the same informaton, try to make a backup of your filesby using the external hard drive, whereby you will need any other computer to make this backup, from your own hard drive. After doing this, you can format the hard drive and load operating system on it, if you know how to do this. You haven't mentioned the operating system you have in your pc, if you have vista or win 7. by pressing f8 key will aslo give you options,, run computer to last known configuration etc. Hope this works, or you can also go online help with service tech.
Sep 01, 2011 | Motherboards
On the k7s5a motherboard i am getting an error stating acpi not supported by the bios
Hi s_gehring,
Have you installed something new on your board? What this is telling you is that the ACPI (Advanced Configuration and Power Interface) does not work with something on the board. Or check your bios setting and make sure you have ACPI turned on.
Thanks Mark
Nov 21, 2009 | EliteGroup K7S6A Motherboard
The BIOS in the system is not fully ACPI compliant. I want to updated BIOS. How can I do?
Hi meangmoeurn, what makes you think your bios is not ACPI complaint?
Enter your bios & disable ACPI. The reason for this is windows must be fully updated. One windows has been fully updated you can turn on ACPI. Its a software issue.
Read through this Microsoft link;
Update for ACPI, (Windows update);
The above update should be included with other updates. This is why I suggested the above.
If you still feel you need to update your bios,
(Flash Utility software). I'll need the motherboard model number & manufacture's name.
Good luck meangmoeurn!
Feel free to correct me on this issue.
Thank you for using fixya.
Jan 11, 2009 | Motherboards
Does the following show any deficiency with the mother board?
Hello there.
As the errors say, there are no drivers installed to make the motherboard function correctly. Your Windows Operating System only knows so many drivers. So what i recommend is to download and install the drivers for your motherboard.
For Windows XP professional click here
The drivers you need on that page are as follows, please install them in this order as well or it may not work correctly.
document.write("Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards")* Chipset: Intel® Chipset Software Installation Utility for Intel® Desktop Boards (1342KB)
* Video: Intel® Extreme Graphics Driver (5410KB)
* LAN: Intel LAN [V6.4_PRO2KXP_ONLY.EXE] (8798KB)
* Audio: Realtek AC97 [AUD_ALLOS_5.10.0.6020_PV_REALTEKAC97.EXE] (24333KB)
* USB: USB 2.0 [USB2.0.EXE] (1106KB)
This will install the drivers for your Chipset, Video, Network, Audio and USB.
Afterwards everything should appear as installed in device manager.
Hope this helps.
Jun 18, 2008 | Intel D845GVSR Motherboard
System reboots when acpi turned off
Hi martinkp, what you need is the update from windows. Leave you're acpi enabled withing the bios. Check windows update. Windows will update (windows software for the acpi). Rule of thumb concerning windows update. Check the dates of the updates & install in order, oldest to newest. This should fix you're system from shutting down. There will be no reason to turn off acpi after updating.
Apr 06, 2008 | MSI K9VGM-V Motherboard
ACPI error message
Hey there rcrozier, your solution is to disable ACPI in the BIOS. To do so, follow these steps. 1/ When set up is loading, a blue screen will appear asking if you have RAID devices, indicating pressing F6. Instead press and hold F7. This should prevent ACPI from installing. Alternately at the blue screen mentioned above, press F5 and hold. It should advance eventually to a new screen prompting you to press F2. Keep holding F5. It will give you another screen telling you it cannot recognize your pc type. It gives you two choices: standard pc or other. Choose standard pc. resulting in ACPI not being installed. Unfortunately the other result of this ACPI not being installed is that your power management will be reduced. Overclocking is not advised. Hope this helps. Good Luck!
Jan 29, 2008 | EPoX EP-8RDA3I Pro Motherboard
Problem on o/s installation
Look in your bios & see if you can disable the ACPI, (which you should be able too do. Finish installing your OS. Than update the OS. After completing all updates re-enter your bios & enable the ACPI. You should not get that error message after re-start.
Boards that support ACPI will get this error during a fresh install untill they get windows updated. All OS's
Post back if this did not help! It worked for me.
Please vote..
Jan 28, 2008 | Intel D945GNT Motherboard
Acpi complaint - reg
Fiend your solution direct from intel. Here is your solution........
Jan 17, 2008 | Intel Motherboard
ASUS P5VD2-MX SE Motherboard Logo
636 people viewed this question
Top ASUS Motherboards Experts
Brian Sullivan
Brian Sullivan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an ASUS Motherboard Expert? Answer questions, earn points and help others
