Question about Zebra Eltron TLP 2742 Thermal Label Printer
Currently have a TLP2742 duplicator which prints barcode and text. Need to alter this to just print the text. how do i do it?
  • 32 Answers
Do you know if you are using a label software program to design the label or just ZPL (which is Zebra Programming Language) code direct to the printer? If it is software, then you can open that label design software file and remove the barcode. If it is ZPL, then you need to remove it from the code. I can help with this if you can email me the code.
hilster1968@gmail.com
Posted on Oct 27, 2009
Our e-Studio 45 printer is printing duplicate text / images. Looking at the print out, it looks like a duplicate of what is being printed slightly below the original text or image. Looks like a ghost layer...
Some printers have a maintenance option to clean it. May need to manual clean the drum or rollers but follow the instructions or could damage components. Might need to check drivers are up to date. Are you using a different type of paper? Is the paper feeding correctly? Are the rollers catching/sticky? Is the toner/Ink old or almost out?
Jan 06, 2015 | Toshiba e-Studio 45 Black and White Copier
Barcode Print aliginment is not proper in windows7
Try a different print driver. Go to Zebra web site and download driver for Windows 7'
Apr 22, 2014 | Zebra Office Equipment & Supplies
We're using 4.00 X 2.00 inch labels. The barcode is printing just under an inch long when it should be about 2 inches long so our scanners cannot read the barcodes. The text is printing out the
in some barcode software you can see the preview. if you click on the barcode itself maybe you can stretch it out to fit better. or try swapping to 2 by 4 format and see if that works. good luck
Aug 12, 2017 | Zebra ZM400 Thermal Label Printer -...
Cannot print graphics accurately. Barcode and text
Problem with your software.
Tec do have instructions for printing diagonals.
Your software must be sending graphics with grey pixels.
Nov 03, 2010 | Toshiba TEC B-472 Thermal Label Printer
I have godex 1100 barcode printer which is not working. It doesn't print barcode. it responds the print command from the computer and tries to print but halt immidiately blinking status light. It gives...
You did not tell us, whether it is not printing barcode's alone or no text is printing.
You might hear beeps for 2 reasons, Sensor posistion is not correct. or ribbon is not correctly fitted.
Kindly check both these. hope this will solve your problems.
If you have any other queries with barcode printer kindly mail/call us.
Regards Trridev Labelss Mfg Co Web Marketing Division www.trridevlabelss.com email Kirubakaran.rv@gmail.com trridevlabelss@gmail.com
Manufactures of Self adhesive labels and resellers of barcode printers and scanners and ribbons
Sep 14, 2010 | Argox X-2000+ Thermal Label Printer
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
Duplicating the top page text at lower page region- Duplicating
Needs a good clean. The fuser isn't completely setting the text so it's sticking to the roller and coming back round on the paper further down.
Oct 10, 2009 | Canon LASER SHOT LBP-3000 Printer
Printing duplicate labels. Switched from the 9840
The printer shouldn't print the same barcode twice. As long as the data is exactly the same, and the supplies are exactly the same, these two printers should be acting the same.
Are you using a 3rd party software application or driver? If so, you may need to contact them to help you adjust the issue, but longoftheshort, if the printer details are exact, like above, then the printer is duplicating, likely, because it is being told to do it. Since the printer cannot arbitrarily reprint a label, it must be told to do it. That is either done through data, or it is done because it didn't finish the job on the previous label and may do it on the followup label.
May 13, 2009 | Paxar Monarch 9855 Thermal Printer
CAN'T PRINT USING A ZEBRA PORTABLE PT400 PRINTER
Verify that the zebra software is loaded. Depending on the type of zebra printer used, might need special software. Zebra printers use the "zebra printer language" (zpl), not a standardized print language.
Dec 16, 2008 | Zebra Symbol Technologies MC909X-G Series...
Zebra Eltron TLP 2742 Thermal Label Printer Logo
233 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
