Question about GE WSM2700D Top Load Stacked Washer / Dryer
Kenmore 80 series won't spin
Kenmore 80 series, dual action agitator. Washer quit last night while in spinning cycle - Makes loud humming sound in spin cycle. It drains and fills up OK. Recently change motor-coupler. Checked it again just to be sure. Checked out fine. Lid switch & pump also checked out OK. Looking at your help page, I don't know how to test if my motor to verify it isn't bad. Also don't know how to troubleshoot transmission, belt or clutch problems. Please help. Thanks.
  • 3 more comments
  • Diamondndave Jan 29, 2008
    Washer will not spin full, but empty seems to be fine. Making a humming noise in either situation.
  • Anonymous Feb 21, 2008
    Tub stated banging (real loose inside) and machine stopped spinning. Makes a loud grinding sound or hum.
  • Anonymous Mar 22, 2008
    won't spin how do I get to the coupler
  • wswinson Apr 06, 2008
    won't spin and makes a loud noise. Also, has a burning smell.
  • Anonymous Mar 07, 2009
    Tranny blew out as described by other. The washer is only a few years old. From the comments I've seen on the web, this is a common problem. Mfg defect!
  • 290 Answers
If it is draining then the motor is turning the pump so it is ok.
This washer has no belt so that is not the problem.
Remove the cabinet and bypass the lid switch wires and put into a spin. Watch the clutch to see if it is turning. If the clutch housing is not turning and you know for sure the coupler is not broken then you need a new transmission. If the clutch housing is turning but the basket is not spinning you have something binding the basket or you need a new basket drive and clutch.
If you have only looked at the coupler from underneath you may not be able to tell if it is broken in the center. If it is broken again your transmission is not staying in neutral drain until the water is drained. That means it is going into spin with full load of clothes and water. This puts a lot of pressure on the coupler and causes them to fail prematurely. If this is the case you will need a new transmission.
Post back if you have any questions.
Posted on Nov 05, 2007
  • Michael  Lindley
    Michael Lindley Nov 08, 2007
    Just wanted to follow up on your washer and see what you found out.
  • smhaqqi Dec 29, 2010
    we tried to wash, and it filled up with water, but it's not spinning. It doesn't do anything.
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Motor is humming loudly.
Motors hum, and your right, it could be no worse than normal.
I would be suspect that there is a gear stripped in the gearcase, since this is a direct drive washing machine.
Reassemble the motor back onto the washer. Run it through a cycle manually (rotate the timer by hand) until the motor turns, then look to see if it's turning. If it is, or even more so, if it pumps water out of the tub, then it is probably the stripped out gearcase.
Reply with you findings and more advice.
Jan 23, 2009 | Kenmore 24872 Top Load Washer
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver
Apr 26, 2007 | Kenmore 22422 Top Load Washer
GE WSM2700D Top Load Stacked Washer / Dryer Logo
1,333 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
