Question about Apple iPhone Smartphone
Key pad botom line is not working - Apple iPhone Smartphone
  • 157 Answers
Touch Screen got problem ! You have to change it .
Best Regards Oz.
Posted on Jun 26, 2009
The touch pad is not work, so now i can't get any water or ice, why?
First check the water line, cut the valve may be closed, dirty filter, then, check for voltage to the solenoid gets water at the time of pressing the botom, review contron card that is not damaged any relay, switch keyboard
Nov 06, 2014 | Kenmore Refrigerators
White lines at only the top & botom of the picture
Vertical retrace line fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 27, 2014 | Toshiba 32HFX71 32" TV
Hotpoint microwave key pad parcially not working
The pads actually share some of the same lines inside the touch pad. There are silver oxide traces inside there. If a trace inside breaks, it depends on which trace breaks as to what pads dont work. If a trace that is common to say pads 1,3,5,7 you would lose function of those pads. 1.....2.....3.....4......5....... it is sort of set up like that inside wher eone connects to another and so on. So lets say a line between 2 and 3 breaks then you would lose pads 3, 4, 5 and any others on that same line. Will have to replace touch pad, cannot repair.
Oct 15, 2017 | Hotpoint JE740WY/GY Microwave Oven
How to remove brake pads on a mistubishi colt bakkie
Jack & support with stands, remove wheels, undo botom caliperslide bolt, flip up calliper & remove pads only 1 side, drain some fluid out of the brake master cylinder, push caliper piston back with G clamp, install new pads, flip caliper down & do up bottom bolt, repeat with other side, replace wheels & your done
Jun 22, 2012 | Mitsubishi Cars & Trucks
Cannt get past black screen on my hp mini 1151nr
IF YOU KNOW ABOUT COMPUTERS OPEN THE MINI, TAKE THE BOTOM 6 SCREWS OF THEN OPEN THE KEY BORD,UNDER THE MOUSE PAD IS THE BIOS BATTERY YOU HAVE TO GET TWO PIECES OF WIRE AND CROSS THEM SO THE SISTEM WILL RESSET TO DEFAULT AND THEN YOU CAN PROCEDE,
Apr 02, 2012 | Computers & Internet
The touch pad was working and now all of a sudden its not
Check your model for a mouse pad disable key. A lot of times it is right above the mouse pad (and is easily bumped) or a function key. It generally looks like a symbol of two mousepads with the second one having a line drawn through it.
Try pressing this button or holding in the Fn key (lower left hand corner) and pressing the function key and see if that resolves your issue.
If not make sure mouse drivers are installed and working properly.
If none of this helps, please post your model and Windows version.
Please leave feedback if this was helpful.
Mar 23, 2011 | Computers & Internet
MY DRIVER SIDE DOOR ON 1995 CHEVY IS HARD TO CLOSE HAVE REPLACED THE DOOR HINGES
have you ajusted the door catch pin to the corect position and does the door line up you might have to ajust the hinges to level the door properly
check the door lines make sure it hits the pin in the right spot if not grab the pin and loosen it with a pair of vise grips and ajust up down or in and out if required
if it is the hinges loosen the botom and top and slide th hinges eithor way remember to ajust 1 hinge at a time onlt loosen 1 hinge at a time if door needs to go up loosen the botom hinge slightly and pull up on back of door when it's almost closed then open door and tighten botom hinge
if too high try loosening it then push down on the back of door
Jan 02, 2010 | 1993 GMC Suburban
Replace water dispenser pad
1st (DISCONNECT THE POWER)then pull the tray at the botom.you will find 3 torx screws .then just push up on the frame and remove the ribbon conector.then 4 screws and pull and your there.
Jul 23, 2009 | Refrigerators
Maitneance required light
Hi.. after you do this step come back and rate as fixya. OK..
Turn the ignitio key to run position
Push and hold for 5 seconds the Trip reset botom.
With the botom pushed turn the ignition key to OFF position.
Keeping pushed the botom.
Turn the Ignition switch to RUN position. keep pushed the trip botom for 10 seconds or untill you see the MAINT_Requi. go OFF.
Remember all this steps with the trip botom pushed. OK.
I hope this solve your question. Thank you for use fixya.
Aug 01, 2008 | 1998 Honda Accord
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
