Question about Kodak EasyShare Z710 Digital Camera
Hi, When switching on, flash opens,selection light is orange and lens does not extend, evf and lcd are blank. After approx one minute, selection light turns green, lens extends and evf works but no lcd. Review does not work in either. Mike
  • 1 more comment
  • reedsaltford Jun 26, 2009
    Contact cleaning had no effect. Batteries removed and camera put on printer dock, selector light flashes green. Still no evf or lcd.
  • reedsaltford Jun 30, 2009
    H, Camera has not been dropped, nor has it got wet. Review works with evf. Pictures can be printed
    but not viewed on the lcd screen.
  • reedsaltford Jul 07, 2009
    Sorry for delay in replying. problem not solved. evf now works in review, and as viewfinder, you can take a photo and review. sd card changed but no difference. all functions appear to work after about
    1 minute after switch on, except for lcd
    Top Expert:
  • Kodak Master
  • 80,339 Answers
Most likely the tiny back-light bulb for the LCD screen is burned out, LCD's produce no light of there own and depend on being lighted from rear to be visible, u will need to have the back light bulb checked and replaced as necessary.
Posted on Jul 08, 2009
  • 2,200 Answers
Hi
To troubleshoot this issue
1)Remove the batteries from your camera, then wipe the battery contacts with a soft, clean cloth.
2)Reinstall the batteries into your camera, then turn on your camera
If above makes no difference - do you have an AC adapter or dock for the camera? Let me know what happens if you remove the batteries and connect it to the dock or AC adapter and then turn the camera on.
Posted on Jun 26, 2009
  • 3 more comments
  • Radio Code Pro
    Radio Code Pro Jun 26, 2009
    Is the camera still taking photos when you use the EVF? Can you review them through the EVF?
  • Radio Code Pro
    Apologies. I see your comment that review is not working in either EVF or LCD.
    Can you access the cameras menu in either EVF or LCD?
    Also - has the camera been dropped at all or had liquid spilled on it?
  • Radio Code Pro
    Radio Code Pro Jun 30, 2009
    The display may simply have turned itself off. Push the EVF/LCD button see if this works.
  • Radio Code Pro
    Additionally Kodak advise that a faulty memory card can cause a black screen to show during photo review.
    In this case transfer all your photos to computer. Then select the internal memory as storage in the settings menu. Take a photograph and see if the screen is working now in review.
  • Radio Code Pro
    Radio Code Pro Jul 05, 2009
    Any update. Is the issue resolved?
  • 749 Answers
Hi, it seems like there is a malfunction that is causing this in the camera, do you have guarantee/warantee?
EVF is dead
It's a known issue with both the A1 and the A2, and is caused by very poor design of the strain relief to the flexible circuit board which eventually cracks. If you open the EVF you'll see a small piece of blue or yellow tape on the pcb just where the damage occurs: this was clearly Minolta's pathetic attempt to prevent the problem.
There is effectively no fix for this as the only way ro repair it is to replace the pcb and to keep costs down Minolta made the EVF flexi pcb an integral part of the entire pcb which snakes it's way deep into the camera. If only they'd redesigned it as a separate replaceable section then things would have been easier. You'll notice that Minolta omitted the tilting EVF from the successor to the A2, the closely related Dimage A200.
The best you can attempt to do is to peel off the rubber eyecup (it has a tendency to tear, so be very careful) and then remove the two screws from the underside of the EVF. You'll then see part of the EVF pcb. Note that there are actually two pcbs layered together, one does have a joint in it, but sadly it's not the one which has broken. You'll see a red and a black wire connecting to a plug which attaches to a socket mounted on a side spur of the broken pcb. The blue or yellow tape I mentioned earlier will be stuck to this spur (ignore the second piece of tape right near the EVF lens). Now set the selection switch to the EVF position and turn on the camera. By carefully and gently manipulating the broken area (the break is usually microscopic, so don't expect to see the damage) you can usually achieve a position where the EVF lights up. You may need to apply more tape or some folded paper packing beneath the pcb to get the EVF to remain illuminated, and usually will need to give it umpteen attempts so be patient. When it stays illuminated, reassemble and gently fold the EVF back down. You'll often find that you have to repeat the job a few more times as the action of moving the EVF back down upsets the "repair". Once it's down, and the fix appears to be stable (i.e. it doesn't black) out or blink every time you touch the camera) then carefully glue the eyecup back on and use your preferred method to stick the EVF in it's parked position. I use thin double-sided adhesive foam jointing tape: if you live near a modelling shop or know a radio control modeller, ask for a piece of thin servo tape.
The bad news is that this repair will not last and that you'll have to either learn to love the LCD panel or resign yourself to regular re-fixes, but eventually the damage progresses until beyond repair. For the same reason, if you replace it with a used example, go for the A200 instead. It has the same lens and many of the same features as the A2, although ditches many of the useful manual switches in favour of menu-driven settings.
If you are lucky enough to actually obtain a complete and unused flexible pcb then expect three things: 1. it will cost more than the camera is worth; 2. it will cost far more than that to have it fitted; 3. it WILL fail unless you stick the EVF down permanently as Minolta never revised the design. You probably won't find the part though as Minolta pretty well exhausted the spares supply whilst making repairs under warranty.
The same fault occurs to pretty much all cameras which have articulated displays, whether EVF or LCD and is why top-spec cameras aimed at professional users omit this feature. Pro's want reliability and give their gear a hard time, so articulated gadgetry is a liability.
It's a real shame as the A2 was otherwise my near-perfect all-rounder. In my case I only encountered the problem after buying a broken A2 for spares (just for the rubber eyecup and a few minor parts) and just a few weeks after investing in the rare, expensive and vital BP-200 battery grip. I've stopped using mine altogether now as I simply cannot get to grips with composing on an LCD panel.
Sorry this isn't all good news, but hopefully you'll find my posting to be of use and will be one of the lucky ones whose DIY fix lasts. Feel free to ask me for further advice and please don't forget to rate my answer.
Jan 29, 2010 | Konica Minolta DiMAGE A2 Digital Camera
When I open the shutter door on the front it does not seem to switch on - the battery is charged - the green and orange light on the back flash and beep ???
2 thoughts. 1, with both green and orange lights flashing the manual indicates that that means that the battery is not charged. This site provided an answer to a similar question that suggested cleaning around the battery area [see Bill BS answer to Wendy]. 2, To you and Wendy, I had a similar problem and a call to Olympus suggested the likely problem was not battery related. When you open the slide, and if you press down on the cover, around where the "s" on olympus appears, that keeps the lens extended. Don't know why that is, or how to permanently fix, but it seemed to work.
Dec 07, 2009 | Olympus Camedia C-50 Zoom Digital Camera
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
Lens won't extend when switched on
I would like to know what mode are you clicking these photos in.. because overexposure is due to either slow shutter speeds or large aperture. Try setting the camre mode according to the surrounding light conditions.. for example, no need of flash when you are clicking pictures in broad day light, instead of setting the camera on Auto mode, try using Portrait mode for short distance (5 to 6 meters away) objects etc..
Let me know if that fixes the issue.
And important .. Do not forget to rate the solution :D
Thanka and Regards,
Srinivas
Apr 08, 2009 | Kodak EasyShare DX7440 Digital Camera
Problem at switch on
The problem was caused by fine particles getting trapped between the sections of the lens. I tore off a thin strip of paper and wrapped it around the inner barrel of the lens. By rotating the paper, I dislodged the particles, switched on and the camera functioned normally.
Mar 22, 2009 | Kodak EASYSHARE M1063 Digital Camera
LCD screen is blank with a purple line on the left side of screen
Its is problem of bad ccd imager and this part will be replaced in your Canon A75 camera.
Canon will repair A75 camera free of cost.
Click Canon CCD Imager Advisory for details.
Mar 17, 2009 | Canon PowerShot A75 Digital Camera
LCD/EVF screen come on but is "snowy"
The problem is the lens is not opening, If you look into the lens you can see it is closed. This will require a trip to the repair shop.
Aug 16, 2008 | Kodak EasyShare Z650 Digital Camera
Camera turns on then auto shuts down??
when the lens comes out grab it and lightly!!! push it to one side this worked on a cannon i have
Jan 22, 2007 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Kodak EasyShare Z710 Digital Camera Logo
117 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
