Question about Sony Playstation 3 (PS3) Console
Red light on controller stuck on
I also have the same problem where the red light on the controller is stuck on even when the system is off. i tried to use it and it does not work. its been about 24 hours and im waiting for the battery to die so maybe the light goes off and i can try to recharge it and hopefully it works. any suggestions?
    Scholar:
  • 46 Answers
Have you tried turning the system off, than plugging the controller in and turning the system on. It may pick up the controller and allow it to work.
You can also try removing the back of the controller and disconnecting the battery and reconnecting it. Although this is not advised, the controller can be a very huge hassle to put back together. I've had that problem before.
Letting it die could also potentially help, although seeing as it's been over 24 hours I don't know if that's going to work, but it's always worth a try.
Anyway, hope this helps. be sure to rate if it did or not.
Posted on Jun 26, 2009
PS3 stuck on red light after it froze up. I unplugged it and replugged it and it's still stuck on the red light. It doesn't change or anything even after hitting the power button.
It would help, if you posted the model number of your system, as they do vary sightly. Is there a disk inside they system? This could be the main problem in witch there are several solutions to remove it. If not, than try inserting a disk, as the PS3 auto recognizes a disk being inserted and turns on the system. If the light is on, and it wont let you power it on, then generally it's the stuck disk problem. ^^ Hope this helps, and good luck.
PS3 Slim Manual Eject for Stuck Disc
Sep 23, 2015 | Sony Playstation 3 (PS3) Console
Parking lights stuck on
the park lamp relay is stuck on. its bad or the control to it is bad.
hazards next.
ok HAZ does glow park to park is a red herring.
the HAZ relay is stuck on, or controls to it are bad
the BCM 100% controls hazard at all times
the BCM gets and input from you , that you want HAZ and then closes the relay/
the HAZ switch ground pin 18 on the BCM, it not 12v here the switch is bad.
IF NOT< bad switch input the HAZ relay is bad.
Dash Fuse Box , fuse 7 is haz. and the relay is there.
replace the relay or the switch,
if you unplug the relay the haz will die.
i bench test relays and am not , doing that here.
Jun 24, 2014 | 2003 Hyundai Tiburon
Bose 321 series ii remote control
try remote on your tv...hold tv button till it lights up and enter code for tv till red led goes out...then try it on tv..if it works,then your ir reciever is kerput...not your remote.i am trying to find parts for mine as well.
Oct 01, 2012 | Bose (321GS) System
Hi I just moved plugged in my ps3 the red standby light came on and now nothing it won't even try to turn on what should I do ?
Sorry I had no idea you sent me this message until today. I apologize for the delay. You probably found a solution by now but if you haven't, please try this..
Solution:
  1. With the PS3 in Standby mode (Red light on), press and hold the Start button until you hear a single beep, followed by double beeps.
  2. Connect the controller using USB cable and press the PS button on the controller.
  3. Now, the system restore screen (or whatever they call it) will come up like this
  4. You have several options here for restoring the system, some will unfortunately wipe up all your data, others will make you lose the file naming.
I hope this helps :D
Oct 24, 2011 | Sony Playstation 3 (PS3) Console
Just bought a camper. The braking system the guy gave me was for a ford. (Husky Journey HD) I have a Nissan titan (2005). I have been trying to match the wires, but no success. Could you tell me what color...
OK on the truck side, brake controller harness wire colors are:
RED = +12V (Hot at all times, even with truck off)
RED/GREEN = Stop light (Hot when brake pedal is depressed)
BLACK = Ground
BROWN/WHITE = Brake out (variable voltage to trailer brakes, 2v-12v)
RED/BLUE = Dimmer (not used on most controllers)
On the controller side (these are pretty much universal):
BLACK = +12v
RED = Stop light
WHITE = Ground
BLUE = Brake out
Jun 05, 2010 | 2005 Nissan Titan
Red light stuck on
hello sir
Solving Your Red Light Flashing:
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Accepte My Greetings
Oct 18, 2009 | Microsoft Xbox 360 Elite Console
1994 Camry Red dash warning light stuck on
This is most likely the security system light.
Mar 14, 2009 | 1994 Toyota Camry
Embedded dirt finder light stuck
Try cleaning out all the pathways you can get to. Trapped particles can mess up this indicator. Particularly check the extra mesh filter that is under the bag (there's a plastic grid that snaps over it to hold it into place). Clean that out and make sure the bag is securely in place.
Dec 04, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Remote will not work
if the light is staying on this means that a button is stuck down on your remote. It might be defective I would contact the company about warranty.
Oct 31, 2007 | GE RM24925 Remote Control
Sony Playstation 3 (PS3) Console Logo
60 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
