Question about Olympus Photography
Om4 light seals spares - Olympus Photography
    Problem Solver:
  • 13 Answers
I make light seal kits for all OM bodies. Servicing Olympus OM since 1977. www.zuiko.com John
Posted on Oct 14, 2010
    Brigadier General:
  • 3,006 Answers
If you can get a specific OM-4 light seal kit then you've done well as they're made of solid unobtanium with prices to match.
The job is not difficult on a DIY basis, just buy a suitable kit of cut to fit material and adhesive. Not difficult, but it can be fiddly...
I've been using kits from an eBay supplier in Japan for a while as his kits contain the correct type of foam, but I've now found one based in the UK who uses the same material with a better adhesive.
The first address is for a current listing. The second one is for the specific seller. You may find another trader who suits you better.
http://cgi.ebay.co.uk/COMBINED-CAMERA-LIGHT-SEAL-SELECTION-REPAIR-KIT_W0QQitemZ380129608842QQcmdZViewItemQQptZUK_Photography_OtherAccess_RL?hash=item58817d848a&_trksid=p3286.c0.m14&_trkparms=65%3A10|66%3A2|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
http://shop.ebay.co.uk/merchant/pilgrim18_W0QQ_nkwZQQ_armrsZ1QQ_fromZ
If you lack confidence to do this yourself, then get a pro to do so, but ask for a diagnostic check of shutter speeds first as OM-4's are notorious for circuit board failures. If it's jiggered then the light seal replacement is a waste of time and you should sell the camera for spares or to sit in a collector's display case and buy another.
Posted on Jul 02, 2009
2008 Buick Lucerne...water in spare tire compartment
to fix this problem with my 2007 buick lucerne I had to take off the bumper and then remove the old seal on the body under this bumper and reseal it. it was not the trunk seal and nor was it coming from the lights or anything else. it was this seal that you cannot see unless you remove the bumper.
Aug 14, 2012 | 2007 Buick Lucerne CXS Sedan
I have a brand new 2011 Nissan Sentra 2.0S. Found water in the wheel well of spare tire in trunk. Nissan tested it for leak and of course found nothing. Happened on 2 ocassions. Suspect undercarriage car...
probablly the result of insufficiently sealed body seams.empty trunk,sprinkle baby powder everywhere use vehicle or get it washed and look for trails in powder ...follow back to source.a little messy but very definitive!
Jan 20, 2011 | 2010 Nissan Sentra
I put in new batteries but the film will not advance and the shuter will not work?
Film advance on your model is entirely mechanical and is not affected by the batteries, but it does interlock with the shutter mechanism which is entirely battery dependent.
Unfortunately, OM4's are were notorious for having a main circuit board which corroded. There were a number of revisions to the board and the OM4-ti had a major revision which improved things greatly but didn't fix it entirely. If the board's faulty, your camera has become a display piece only as it cannot be fixed and spares are impossible to obtain. It doesn't help that OM4-ti's were made in far fewer numbers than regular OM4's and that the boards are not interchangeable between them.
It is still possible though that the fault is due to the camera just needing a thorough CLA service (Clean, Lubricate, Adjust) but expect to find that some mechanical parts may need to be replaced, especially if the film advance has been forced. If the shutter assembly is faulty, then once again you're into rocking-horse poo territory as it's unique to the OM4-ti. They can't be obtained new any more, but they can be taken from scrap OM4-ti's which suffered circuit board failure.
Note that due to the complexity of this model most repairs are not a DIY option. Repairs will not be cheap, but an OM4-ti which is advertised for sale with proof of recent professional repairs and servicing by an Olympus specialist is worth a lot of money so is often a worthwhile investment.
Apr 24, 2010 | Olympus OM-4TI 35mm SLR Camera
Accumulation of water under the spare tire. Cannot find any leaks
Here is the best way to find out where the water is coming in. Get inside the trunk and have someone you trust close the trunk. make sure you do it when it is daylight or a well lit garage. while you are in the trunk with the lid closed you will be able to see light where there is any gap around the trunk seal and that will be where the water is coming in. some times the sides of the trunk opening gets bent down causing the trunk gasket not to seal properly.
Nov 02, 2009 | 2006 Chrysler 300M
Water leakage in spare tire compartment
These are hard to pinpoint, but look closely at tail light areas, and trunk seal....
Sep 25, 2009 | 2002 Ford Taurus
05 almera hatch back
can be the rear door seal (check for damage)
or seal around the rear light cluster but that's less likely
Sep 07, 2009 | Nissan Pulsar Cars & Trucks
Water is getting into spare tire area on 2006 Nissan Sentra
CHECK TO MAKE SURE THE WEATHER SEAL AROUND THE TRUNK LID IS NOT DAMAGED.IF YOU CAN GET SOMEONE IN THE TRUNK WITH A FLASHLIGHT TO SEE IF WATER IS COMING IN AROUND THE SEAL WHILE YOU USE A HOSE TO SOAK THE TRUNK LID GAPS
Aug 06, 2009 | Nissan Sentra Cars & Trucks
Olympus om-4ti makes a screatching noise and stops working
The biggest clue is that you're having to take action to save the batteries. High battery consumption is a a classic sign of a faulty circuit board in this camera. Unlike most regular OM-4's, the OM-4ti generally had an improved circuit board fitted from new which was made available as a warranty repair item on regular OM4's, but you may have an early one.
The faulty circuit board manifests in other ways, most commonly the dead display/non functioning shutter except for the mechanical default speed. I've heard of the screeching fault as part of this problem but have not personally encountered it.
The fault is irrepairable as replacement boards are fashioned of finest unobtanium; the same faults affect the OM-2sp as well. This is exactly why both cameras are now available far more cheaply as used buys: potential buyers who know these models are aware that they're taking a gamble.
There is a revision marking on the "good" boards but it's largely academic. Anyone with a "good" OM4 rarely sells it, and even the revised boards are old enough to have started deteriorating by now.
May 06, 2009 | Olympus OM-4TI 35mm SLR Camera
Photography Logo
881 people viewed this question
Top Olympus Photography Experts
pontelemon
pontelemon
Steve
David Payne
David Payne
Are you an Olympus Photography Expert? Answer questions, earn points and help others
