Question about Sharp R-963 Convection/Microwave Oven
How to change bulb - Sharp R-963 Convection/Microwave Oven
  • 417 Answers
I imagine the whole outer cover has to come off, there are screws all along the back . Be extremely careful inside the microwave, stay away from the transformer and capacitor red wires, they store charge and are very dangerous.
be careful, wear leather gloves too
J
Posted on Jun 26, 2009
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
How to change the bulb for kleenmaid wall oven model T055x
Changing the bulb
Warning: disconnect the appliance from the power supply before replacing the bulb
- Turn the cover one quarter turn to the left.
- Unscrew the bulb and replace it with a heat-resistant (300 °C) bulb of the same size with an E14 base - 15 W.
Aug 12, 2017 | Microwave Ovens
GE double Oven range PLT059-2 How do you access surface light bulb to change it?
There should a sliding panel of glass or plastic covering the light. Remove the glass or plastic then you should see the light bulb. If the light buld is a regular old bulb unscrew it if its a small floorisent bulb twist it so it will roll out of its sitting position. Then you can take the bulb to any hardware store to match the bulb. DO NOT PAY FOR SOME ONE TO CHANGE A LIGHT BULB....Please if this helped you post that I helped you with the correct answer so i may get credit....
Nov 17, 2014 | Microwave Ovens
How do I change the bulb in Alba TRDAB2820 radio
back-light bulb is actually LED's and these fade when the capacitors fail 4 X 470uf at 10v and 1 X 1000uf at 16v on board behind display, change all 5 and it should be ok again.
Martin
Mar 18, 2014 | Emerson MW8107WA Microwave Oven
How to change bulb
Hi
we have two vintage vacuum cleaners a 612 from 1949 and a 652 from 1959 Does anybody know how to change bulbs on the headlights ion these machines ?
Jan 07, 2014 | Emerson MW8107WA Microwave Oven
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
Need to change the light bulb. found it but can't
push in on the bulb and then turn a quarter turn counter-clockwise,its a bayonet base bulb,not a candelabra base like a typical light bulb has
Jul 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to change inside bulb
Normal procedure is to remove case cover to access the bulb.
Usually several screws on the back and some partially hidden on the front to remove. Sometimes the screws require a Torx screwdriver.
Unplug unit and avoid touching any wires.
Replace bulb with exact type.
Jan 07, 2010 | Frigidaire FMV156DC Microwave Oven
Changing Microwave bulb
Remove lid, you'll probably need a pozi drive screw driver and a tamper proof torx drive.
The bulb is located near the front.
Mar 15, 2009 | Microwave Ovens
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-963 Convection/Microwave Oven Logo
120 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
