Question about Garmin eTrex GPS Receiver
How to setting tm3 - Garmin eTrex GPS Receiver
How to Make the Matrix Raining Codes by Using Only Notepad?
thats easy..
open notepad then copy and paste the following text
@echo off
color 0a
cls
:a
set /a a=%random%
if %a% geq 16384 set /a aa=1
if %a% lss 16384 set /a aa=0
set /a b=%random%
if %b% geq 16384 set /a bb=1
if %b% lss 16384 set /a bb=0
set /a c=%random%
if %c% geq 16384 set /a cc=1
if %c% lss 16384 set /a cc=0
set /a d=%random%
if %d% geq 16384 set /a dd=1
if %d% lss 16384 set /a dd=0
set /a e=%random%
if %e% geq 16384 set /a ee=1
if %e% lss 16384 set /a ee=0
set /a f=%random%
if %f% geq 16384 set /a ff=1
if %f% lss 16384 set /a ff=0
set /a g=%random%
if %g% geq 16384 set /a gg=1
if %g% lss 16384 set /a gg=0
set /a h=%random%
if %h% geq 16384 set /a hh=1
if %h% lss 16384 set /a hh=0
set /a i=%random%
if %i% geq 16384 set /a ii=1
if %i% lss 16384 set /a ii=0
set /a j=%random%
if %j% geq 16384 set /a jj=1
if %j% lss 16384 set /a jj=0
set /a k=%random%
if %k% geq 16384 set /a kk=1
if %k% lss 16384 set /a kk=0
set /a l=%random%
if %l% geq 16384 set /a ll=1
if %l% lss 16384 set /a ll=0
set /a m=%random%
if %m% geq 16384 set /a mm=1
if %m% lss 16384 set /a mm=0
set /a n=%random%
if %n% geq 16384 set /a nn=1
if %n% lss 16384 set /a nn=0
set /a o=%random%
if %o% geq 16384 set /a oo=1
if %o% lss 16384 set /a oo=0
set /a p=%random%
if %p% geq 16384 set /a pp=1
if %p% lss 16384 set /a pp=0
set /a q=%random%
if %q% geq 16384 set /a qq=1
if %q% lss 16384 set /a qq=0
set /a r=%random%
if %r% geq 16384 set /a rr=1
if %r% lss 16384 set /a rr=0
set /a s=%random%
if %s% geq 16384 set /a ss=1
if %s% lss 16384 set /a ss=0
set /a t=%random%
if %t% geq 16384 set /a tt=1
if %t% lss 16384 set /a tt=0
set /a u=%random%
if %u% geq 16384 set /a uu=1
if %u% lss 16384 set /a uu=0
set /a v=%random%
if %v% geq 16384 set /a vv=1
if %v% lss 16384 set /a vv=0
set /a w=%random%
if %w% geq 16384 set /a ww=1
if %w% lss 16384 set /a ww=0
set /a x=%random%
if %x% geq 16384 set /a xx=1
if %x% lss 16384 set /a xx=0
set /a y=%random%
if %y% geq 16384 set /a yy=1
if %y% lss 16384 set /a yy=0
set /a z=%random%
if %z% geq 16384 set /a zz=1
if %z% lss 16384 set /a zz=0
echo %aa% %bb% %cc% %dd% %ee% %ff% %gg% %hh% %ii% %jj% %kk% %ll% %mm% %nn% %oo% %pp% %qq% %rr% %ss% %tt% %uu% %vv% %ww% %xx% %yy% %zz%
goto a
Dont copy this line or anything below it.
once the text is pasted into notepad. click file then Save As...
where is says Save as type: click the drop down and select All Files
the save Type the File name: as Matrix.bat
or you could just google how to make a Matrix bat file.. LOL
Oct 20, 2016 | Microsoft Computers & Internet
Ps3 was owned by someone else and they put a block for mature games how do you get the block off
Unless you know the password they used you would need to completely re-initialize the unit as it was a new one, from the beginning, to wipe it out completely and set it back to factory defaults (sledge-hammer reset).
There is no way I know of to retrieve this lost password if you do not also know the owner's PSN information, which I'm sure you cannot get to. You might Google the question.
Feb 14, 2015 | Sony Playstation 3 (PS3) Console
Manual for telstra tough tm3
how do i charge this phone i have the cord but can't see where to plug it in
Aug 01, 2013 | Audio Players & Recorders
How to use mr coffee tea appliance
First clean the pitcher, lid, steeping basket and steeping basket before you use it the first time. Run a brewing cycle without any tea the first time and discard the water.
With the unit unplugged, fill the pitcher with water to the top water level mark on the pitcher and then pour the water into the reservoir. Do not overfill. Place the steeping basket and lid on top of the machine. Place a tray of ice cubes into the pitcher. Turn the steeping dial to open. Put the lid with the spout open on the pitcher and slide it, spout first, under the machine. Plug in the unit and turn it on. Wait until it turns off automatically.
For brewing, fill the pitcher with water to the line for the desired amount of tea. Pour this water into the reservoir (with the steeping basket and lid removed). Place a Mr Coffee filter into the steeping basket and add the desired amount of tea bags or loose tea. You can add sugar or lemon over the top of the tea if desired. Slide the steeping basket into the unit and put on the lid with the steeping dial set to closed. Fill the pitcher with ice to the desired ice level or with cold water to the same volume as poured into the reservoir. (If you are using water, put the pitcher in the refrigerator to chill.) Slide the pitcher with the lid on under the brewer and make sure the lid is open over the spout. Plug in and turn on the brewer. When the brewing cycle is done, it will turn off. Turn the steeping dial to open to drain the remaining tea from the steeping basket. (Let the remaining tea sit longer before opening the dial if you want stronger tea.)
You can get the manual from http://www.mrcoffee.com/Products.aspx?cid=43 . Click on the link for the TM3 (all the models in a series work the same way).
I hope this helps.
Jan 16, 2011 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
Screen goes blank after a few minutes
POWER OPTION
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
POWER OPTION
-set display to never
Restart pc
Jul 14, 2010 | Dell Inspiron 1318 Notebook
Pioneer PD-M501 6-CD Player manual and what magazine cartridge
CDs go in the Upside Down position. Your PD M501 will accept PRW 1139, PRW 1141 and 163.
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM
May 15, 2010 | Pioneer PD-M603 6-Disc CD Changer
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
Cleaning ice tea maker
Try to do that
  1. Pour 1 quart (32 oz.) of undiluted white household vinegar into the water reservoir.
  2. Place the pitcher lid on the pitcher. ...
  3. Push the "on" button to begin brewing cycle. ...
  4. Re-plug the cord. ...
  5. When your machine shuts off, unplug the cord, remove the pitcher.
Feb 24, 2009 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
Garmin eTrex GPS Receiver Logo
61 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
