Question about Fisher Paykel Eco IWL16
Water leaking from under washing maching
My fisher and paykel top loading wash machine is leaking water from under the machine- other than that is is working ok - can you help with how i can get to the pump - i suspect it is a leaking seal in the pump
thank you
kerrind@iprimus.com.au
The ribbed drainage tube on mine was leaking from a small hole at the bottom of the curved "u" - due to flex fatigue tiny crack. My solution - a short (1 inch) section of copper water pipe for a splice, secured with black electical tape and a hose clamp. This fixed the leak, but when I stood it back up, it wouldn't run right. This was due to the out of balance microswitch mentioned above, which was corroded. I bypassed it, and it works like new.
dt
Posted on May 04, 2010
I run into this problem when I put too much soap in the dispencer, cut the soap in half and it will stop leaking.
Posted on Dec 14, 2009
  • 417 Answers
your going to have to study it. put the machine on its side and look for access panels or a whole plate to remove on the bottom or rear. take the panels off and study it while its running, maybe put the machine up on blocks, careful of moving parts of course.
hopefully it may just be an adjustment with a clamp. also the agititator seal inside the machine may have be bad, pop the cap off the agitator, remove the bolt and pull it straight up and out and study the seal area, might be leaking right down the middle too.
good luck
J
Posted on Jun 26, 2009
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Soap residue fisher & paykel top loader
Agitator can be removed easy,Take out the fabric dispenser cup,
Reach down inside the agitator & undo the wing nut, left to undo.
Take out agitator & clean & the bottom of the bowl,
For a more better clean fill machine with hot to high water level & leave soak over night,Do heavy duty wash in the morning to remove scrud.
Feb 10, 2013 | Fisher and Paykel Washing Machines
My washing machine will not light up
Generally this problem happens when the drain pump starts to leak under the washing maching. A Fisher Paykel has a main control board under the touch panel that has direct wires running from it to the drain pump. When the drain pump leaks it shorts out the wire connecting it to the control board and blow out the main control. Look under washer and look for the drain pump (Drain pump looks like a fan from the underside.) You will most likely see residue from where the water has been leaking, built up on the pump. If all of the above is true on your machine, replace the pump and control board. Fisher Paykel includes an inline fuse to keep this from happening again.
Mar 30, 2012 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks...
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks out of top panel under lid. Machine is level. Any Suggestions?
Jul 28, 2011 | Fisher and Paykel WA37T26G Top Load Washer
Pump blockage on fisher and paykel gw708u top loader washing mach
dont do that the pump is fitted under the sytem there should be a small plastic plate at the front of the machine to get to the pump or go under the unit and its right there un plug the motor pull back the plastic lock gard and turn .the motor should just fall of ..replace as taken off good luck
Apr 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water leaking on my fisher paykel washer. does it
Hi, It is due to a split in the flexible hose from the bowl to the pump. When machine is working, the split opens and closes, but when not operating it can be closed up enough to prevent seeing it leaking. .
Apr 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel Eco IWL16 Logo
258 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
