Question about Sony VAIO VGN-FS830/W Notebook
Display not showing
When i powered on the laptop but the display not showing on the laptop
  • 448 Answers
Hi!
Please refer the article through the link given below to troubleshoot the issue.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C390934
Posted on Jun 27, 2009
I have problems in sarting up my EI System laptop ,the power light is on but no display on screen
The power light will only show whether power is reaching the machine. The important light is the hard drive activity light and perhaps the wireless activity light.
If the power light is all you have you should take your laptop to the computer doctor but if the hard drive light shows activity it would be worth connecting it to a separate monitor and if it then produces a display you might be able to figure out what has happened.
Sep 19, 2016 | Computers & Internet
What causes laptos to not show display despite showing that they have switched on?
Step 1:
The display on your laptop is the interface through which you interact with and control your computer. If it is not working, your laptop will become virtually impossible to use. A laptop is a computer, and like all computers is subject to both hardware and software problems that may affect the display. Before taking your laptop in for repair or getting rid of it, you should first check the display yourself to see if it needs to be replaced.
Check the laptop's battery and power cord. If the laptop is out of power, the display will not work. This usually happens if the power cord is unplugged and you were unknowingly running your laptop on battery power. Check to make sure the power cord is plugged in and that the laptop has power. Many laptops also turn off the display if it is being powered by its battery after a period of nonuse. Touching any key will usually turn the display back on if the battery is not drained. Restart your computer. If a software program is stuck or malfunctioning, it may cause your display to stop functioning. Press and hold the "Power" button on your laptop to reboot your computer. If the problem was a malfunctioning program, the display will turn on after the computer restarts. Check the brightness level of the display. If the level is too low, the screen will appear dark. The brightness controls are usually located on two function keys, such as "F9" and "F10." Look for sun or light icons on the keys. Press the key with the larger icon to increase the brightness level. Alternatively, on some laptops hold the "Fn" key while simultaneously pressing the "Up Arrow" key to increase the screen brightness. Check the display closed switch. Many laptops have a small button that senses when the LCD screen is closed and puts the laptop in sleep or hibernation mode. If the switch gets clogged with dirt, it may get stuck in the closed position. This will result in dark display even when the lid is open. The switch is usually located near the hinges of the lid. Spray the switch with a can of compressed air to loosen the dirt so that it will resume its normal operation. Plug an external monitor into your laptop. If the problem is not software related, the external monitor will display the laptop's screen. Connect the monitor by plugging the cable into the VGA, HDMI or DVI port on the laptop. Press and hold the "Fn" key while simultaneously pressing the "F8" key. The video output will be directed to the external monitor if there is a hardware problem.
b>
Feb 21, 2013 | Toshiba Satellite Computers & Internet
Cq60-212ea screen black power switch on power led on .processor fan on .but not laptop on screen black. Not display show. And not wellcome display show
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 14, 2011 | Compaq Computers & Internet
Laptop screen is not showing anything after power is on
if the power is on and the screen does not show up , try to hook an external monitor using the VGA cable. If the screen does show up, it means that the problem is in the laptop LCD monitor itself. Otherwise if the external monitor does not show up, that means your laptop does not boot anymore to the operating system. Try to turn off the power and remove the power cable and battery on the laptop. Then press and hold the power button for 8 secs. Then reinsert the battery and power cables on the laptop then turn on the laptop. If there is still no screen displayed then call Lenovo for repair of your laptop.
Oct 22, 2010 | Lenovo 3000 C200 Notebook
I have dell laptop.Cursor is showing. caplock on
No display? but you have an mouse cursor showing? So you must have an display and it is locking on startup of the OS. Do you have an bootable cd? If not lets try to start it up in safe mode..
1: power down system
2: on power up hit the F8 key keep taping it till you get display saying startup in safe mode.
3: start up in safe mode no network.
4: if it starts up to an desktop then its an driver or software which you have installed causing normal startup to stop.
If it doesn't start in safe mode we will have to boot to an OS CD.
Let me know how these first steps go..
Feb 23, 2010 | Fujitsu Siemens Lifebook C2230 Notebook
No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
Nov 05, 2009 | Acer Aspire 4520-5582 Notebook
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Card error, Laptop with vistas displaying ' insert disk' when card inserted
Not know the age of the card, is seems that it is faulty and needs to be replaced.
Sep 23, 2008 | Cameras
Battery Display Problem
Hi Mxtacsy,
Power down your laptop. Remove the battery and power for about 2 min. Plug in the power only. Boot up your XP. Right click on My Computer>Properties>Hardware>Device Manager. Click on View>Show hidden devices.
If it lists a battery catagory, click on the + , right click on your battery, and select Uninstall.
If it doesn't show, don't worry. Now plug in your battery, without powering down. That should cause XP to redetect your battery. Reboot and your Battery icon and powersaving settings should all be ok.
Good Luck!
Jan 08, 2008 | Computers & Internet
Sony VAIO VGN-FS830/W Notebook Logo
113 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
