Question about Samsung SyncMaster 940MW 19 in. LCD Television
Samsung Syncmaster 940MW... The Tv screen keeps
Samsung Syncmaster 940MW... The Tv screen keeps rolling how do I stop this from happening
SOURCE: Samsung SyncMaster 940MW
I managed to fix the problem myself by switching theTV off at the mains socket, waiting 10 seconds and switching back on again.
Posted on Jan 04, 2008
SOURCE: Samsung SyncMaster 940MW will not turn on
There are broken/exploded capacitors on the power plate, it is a 5 Minute job to replace them.
Posted on Apr 17, 2009
  • 1684 Answers
SOURCE: How to remove the back of Samsung 940MW LCD TV
You will need to take a small flat blade screwdriver and insert it between the two halves of the case and gently pry the two apart. There are latches around the case that just need a little pressure to release. Once you get a few released the rest will pop open as you pull the halves apart. We have some pictures posted on our web site at: www.ccl-la.com Look in the monitor repair section. THere are several repair guides for different brands with pictures of what the release latches look like. If you have any questions just call us at: 318-447-9040
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Dec 02, 2009
Testimonial: "Thank you. I thought it might be something like that, but I didn't want to risk breaking something. "
SOURCE: My samsung syncmaster 940mw will not power up?
Hi
I've had the same problem. I've managed to locate and remove the fuse but can't read the writing on it. Any ideas what I need to replace it with? And where's the best place in UK to buy the spares?
Thanks
Posted on Jan 04, 2010
  • 1684 Answers
SOURCE: samsung 940mw monitor ringing then blank screen
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com Look on the monitor repair page 2. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 19, 2010
Why do I have no signal on the Samsung syncmaster 940 mw tv
Check your cable connection on both ends. Try to change the cable.
Oct 06, 2014 | Samsung SyncMaster 940MW 19" LCD Monitor
No enciende samsung 940mw ya le cambie los capacitores y trabajo bien 4 dias
Carnot get Digital on my tv keeps saying cannot access digital services Was ok but not sure wats happened thanks
Dec 09, 2013 | Samsung SyncMaster 940MW 19 in. LCD...
SyncMaster SA10, my screen turned green, i've tried everything but it's still the same. Help ?
The Blue and Red drives are missing and the TV needs attention by a qualified service technician.
Jul 14, 2012 | Samsung SyncMaster 940MW 19 in. LCD...
I have samsung syncmaster 940mw monitor. The monitor for the most part will not turn on. When the power button is pushed or attempt to turn on with the remote the little green pilot light will blink or...
That is a hell know problem with the 940MW tv/monitors. The power supply has failed because of parts called capacitors have shorted. If you can solder then you should be able to repair your monitor. Here is a link to the repair guide for this issue.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/
I hope this helps, if so please rate my solution.
Oct 30, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung 940mw monitor ringing then blank screen
Buddy
Corporate Computer
www.ccl-la.com
Dec 31, 2009 | Samsung SyncMaster 940MW 19 in. LCD...
Power light was blinking took a long time to turn on, now power light does not blink or go solid and screen does not work
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com This model is on Monitor repair page #2 We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
My samsung syncmaster 940mw will not power up? It showed no signs of failure it just stoped. Tino
Good day sir, if it just stop, chances are it could be a fuse blowned, you may need to open your samsung tv, back panel. locate the fuse, replace it with the correct ampere value. if the fuse is in order, close the back cover. you have no choice but to bring it to your dealer for advice on your TV status.
Oct 13, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung SyncMaster 940MW 19 in. LCD Television Logo
125 people viewed this question
Jerry Greenberg
Jerry Greenberg
