Question about Intel Pentium III, 800MHz (229725001)
Computer will not turn on?
i have a computer that dont turn on not even the fan in the back of the computer i tried changing the 3v battery i wounder if it could be my power supply
    Problem Solver:
  • 7 Answers
By that detail i would say almost 100% that it is your power supply try a changing it :)
Posted on Nov 11, 2007
Unit starts/stops-starts/stops after replacing 3v battery?
When you say starts/stops (etc) are you saying it just keeps trying to reboot? Or are you getting a message such as boot disk not found press any key to restart? Replacing the 3V battery will cause the CMOS to reset to factory defaults. You may need to go into the CMOS and make setting changes to point to the proper disk drive for booting. You may even have to change the type of disc drive since there is now the old MBR as well as the newer GPT format. Also, there is the possibility that if you are upgrading you may need to use the legacy CMOS instead of the UEFI that many newer mainboards come defaulted to. Any error in the CMOS settings can cause a boot failure.
Apr 03, 2016 | Gigabyte GA-H55M-USB3 Socket 1156/ Intel...
How do i change my battery
This unit includes one lithium battery, CR2025/3V.
Remove battery before discarding the remote.
Battery Replacement
a) Locate the battery compartment on the back of the
remote control handset. Slide the battery cover out
with your thumb.
b) Remove old battery.
c) Place new battery into battery compartment.
d) Slide battery compartment into the remote control
• Remove the battery from the equipment when it is not
being used for an extended period of time.
• Remove the used battery promptly.
• Do not discard used batteries into household trash
containers. Contact your local government for disposal
or recycling practices in your area.
Jul 01, 2015 | Bionaire BT200RCU Tower Fan
Compaq Presario CQ62 faulty BIOS or not!?
Your computer will not start up with out a BIOS working, it starts the hard drive and loads the operating system.
The CMOS memory stores parameters which are updated by the operating system. Hence it needs a battery to keep the parameters. It also needs the operating system to make any necessary changes to start up again.
I do not know your full model number, but this utility will check if your pc is bootable.
HP System Diagnostics UEFI
You can also find all the drivers, bios updates etc. on
Sep 26, 2014 | Computers & Internet
Pc can't boot up , no display , hdd led is constatly lighted
Check CMOS battery(Coin shaped battery), it should show 2.5-3V, if not then replace and check, you can even try and test the mbd without the CMOS battery. Some mbd does not boot with a faulty CMOS battery.
Mar 17, 2009 | MSI K8MM-V Motherboard
AA Battery Drain...just discovered a 3V battery in my camera
Usually the 3v battery holds the date and time in your camera. A lot of time with digital cameras you have to remove the batteries when there not in use for a long period of time to prevent the draining from happening.
Do you have regular AA batteries to see if the meter changes? That would be the best way to see it the camera is reporting the correct battery life.
Dec 05, 2008 | Canon PowerShot A560 Digital Camera
Computer not turning on.
You will get the on/off switch in the market. The 3V battery that you see inside has nothing to do with the on/off switch. That battery saves your BIOS setting in CMOS when your computer is turned off.
Oct 27, 2008 | E-Machines eMachines Desktop PC
Computer won't turn on
u did not said ur mother board vander name and chipset. because some mother board can not star if CMOS battery expire. remove CMOS battery check it voltage bellow 3V or not if it's voltage bellow 3V then replace it. and try to trun on ur shuttle.
Jun 29, 2008 | Shuttle 200W Internal Power Supply for...
Troubleshooting a computer that doesnt start
It's more than likely the CMOS battery a disk shaped 3V watch type battery found on the motherboard. Change this then reset time and other settings and your away.
Dec 26, 2006 | Compaq Deskpro EN PC Desktop
Intel Pentium III, 800MHz (229725001) Logo
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
