Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
Problem for Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
I have a dyson dc 05 and a wire has come
By chrisdodson1 on Jun 26, 2009
i have a dyson dc 05 and a wire has come disconnected from the main cable inside the machine how do i get the wheel off to reconnect the cable
Best Solution
posted on Jul 04, 2009
Very Helpful)
parsonm
Rank: Guru
Rating: 96%, 47 votes
In the centre of each wheel there is a different colour plug. This must be removed before the wheel can be pulled off. I used a small screwdriver to prise it out. You will probably damage the plug in removing it but they are easily available online as a replacement. You will then see two screws holding the case together. You need to undo both sides plus the screw on the top.
(If you think you may have a loose connection, then it could be the motor brushes have worn out and need replacing)
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dyson DC05 Cylinder Bagless
Questions and Unsolved Problems for Dyson DC05 Cylinder Bagless
Do you recommend Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum?
Answer
Answer
Power Cord has been stretched and the appliance no go but cord is still attached by phase and... (More)
Answer
i want to clean inside the yellow cyclone section of a DC08 but tapping just wont get out the thick... (More)
Answer
I appear to have suction but, when vacuuming there is not enough suction to pick up all the dirt. I... (More)
Answer
I have cleaned filters (and replaced) Checked for blockages in the hoses. Cleaned the beater bar--It... (More)
Answer
I have a brand new Dyson and the canister is full and it will not open up. I feel like the parts... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dyson DC05 Cylinder Bagless...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
