Bosch classixx 1200 wont spin at all, water fills ok even pump to drain it back out .can hear it clicking as it tries to get motor to turn
  • darren_br261 Jun 26, 2009
    thanks , have got the back off and the belt is fine , would be gratefull for more advice.
    Genius:
  • 1,341 Answers
You need to check the back of the unit and there's a strong possibility that the belt is broken or slipped out of track.
Posted on Jun 26, 2009
  • heeman mohun Jun 26, 2009
    There is something which looks like a c or d size battery which has got 2 or 3 wires plugged into it which boost the electric motor to start.Have it checked as this is a very common fault.
Bosch classixx 1200 express spin light flashing water wont drain pump is running water draining very slow i checked for blockage none found help... thanks
Sounds like the blockage is closer to the drum, Tilt the machine as far back as you can to access underneath. Make sure to have a basin and remove the pipe going from the drain pump to the tub and see if anything is obstructing the pipe or stuck in the tub, is usually a sock. Hope this helps.
Feb 28, 2011 | Bosch Classixx WFC 2465 Front Load Washer
My bosch classix 1200 fl wont spin or drain
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the wall first. Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes (at terminal end of motor), if they are any shorter than 1 cm replace brushes.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Oct 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx 1200 - Drum not turning
It could be the motor itself (is there any overheating smell from the motor) or it could be the capacitor which controls the motor. I had a similar problem and it turned out to be the motor brushes. I replaced the brushes and all was OK.
The only other thing that could be wrong especially if it overfills with water is the water level switch (this is a pressure switch on the side of the washer) You can easily check this by removing the hosepipe to the switch and blow gently into it, you should hear a clicking sound) This might be the clicking that you heard so it is probably Ok.
Aug 08, 2017 | Bosch Washing Machines
Clicking noises
IF APPLIANCE IS RUNNING OK I WOULDNT WORRY TOO MUCH THE CLICKING YOURE HEARING IS PROBABLY THE HEATER RELAYS SWITCHING ON AND OFF AND THE MOTOR REVERSING RELAY ALSO NORMALLY THEY WOULD NOT BE HEARD OVER NORMAL RUNNING NOISES OF MACHINE.
Sep 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1200 fills, drains, but won't wash ?
This a classic example of worn brushes in the motor.
To check , remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws that secure motor, and lever motor back with a screwdriver or similar.
Keep hold of the motor as you lever it back.
You will find the brushes at the terminal end of the motor, replace if less than 4=5 mm in length.
Refit motor belt and motor plug.Test. before you refit panel
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch Washing Machines
Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch Classixx 1200 Washing machine won't drain & spin
The motor and motor control unit need to be replaced.
Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Aug 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Not spinning
I found my Classixx 1200 express with a flashing spin light, the water wasn't up in the drum, so I moved the selector to rinse, and pressed start, pump was noisy but worked, I could hear water going into the drain, thinking I'd got a blockage in thye pump, I drained machine using small hose and inspected the pump orifice at the front of the machine (towel handy to catch spillage.
No obvious blockage and the pump could be turned by hand, tried rinse again with water feed turned off, (otherwise it pumps for a while and then lets water in to rinse - which comes out the open pump housing!) I could see the pump impeller spinning but also sticking, its was also noisy.
Solution - new pump, according to my local spares shop, the pump is available as either motor & impeller (back half), or complete with black housing that the pipes fit to, to get the front cover off, and to remove the pump, you need a "star" screwdriver or key, and a pair of pliers to undo the hose clips - have a bowl ready to catch the water, and make sure the machine's unplugged before you start!
Jul 12, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
340 people viewed this question
Top Washing Machines Experts
