Question about Lofra MXUD66GGI Gas Kitchen Range
I took off the oven door of my Lofra stove to do some repairs, but now I do not know how to put it back on. I have trouble with the hinges.
  • cvitkos1 Jun 26, 2009
    I took off the oven door of my Lofra stove and now I cannot put it back on.
    My problem is how to put the door back on, not how to remove it. The hinges are just fine.
    President:
  • 1,952 Answers
If your oven door has gotten bent or warped (maybe you rested something heavy on it…), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up.
If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Posted on Jun 26, 2009
  • 4 more comments
  • mohammed marika thambi
    mohammed marika thambi Jun 26, 2009
    owner's
    manual. These are often incomplete.
    Much of the
    wiring for an electric range/oven is on the back of the appliance. The
    steel panels that cover the wiring protect both you and the wiring.
    Other components--such as relays, self-cleaning switches, transformers,
    and terminal blocks--are also behind the protective back panels.
    The back of the unit
    RepairGuru®
    see the user manual contact ..........repair guru
    SOME HINGES HAVE A HOLE THROUGH THEM TO LOCK THE HINGE IN THE "BROIL
    STOP POSITION" THAT WILL MAKE IT ALOT EASIER TO REINSTALL THE DOOR.
    SOME HINGES HAVE A BUILT IN LEVER THAT YOU FOLD INTO THE JOINT OF THE
    HINGE, LOCKING IT IN PLACE. IF THE HINGE CAME OFF WITH THE DOOR, THERE
    ARE TWO PINS THAT THE HINGE HAS TO HOOK BACK OVER WHEN INSERTED INTO
    THE HOLES IN THE FRONT OF THE RANGE. FIND THE CORRECT ANGLE TO ENGAGE
    THE HINGES CORRECTLY.
    IF THE HINGES ARE ATTACHED TO THE RANGE, PULL THEM OPEN TO THE BROIL
    STOP POSITION. THEY NORMALLY WILL HANG IN THAT POSITION. USE YOUR KNEE
    TO SUPPORT THE DOOR AS YOU SLIDE IT BACK OVER THE HINGES.
    If you merely lifted it up off the two spring loaded supports, you
    should only need to slide it back into the bottom of the door...You may
    need to use pliers to move the supports into a horizontal position
    (normallaly open position). If you actually removed the supports from
    the springs...it will be very hard to replace, because the springs are
    hidden.
    hidden.
    mohammed marika thambi Jul 06, 2009
    had a similar problem and tried simlar fixes. Spraying the chain, the
    rollers, the track with silicon based lubricant did not good for my
    problem. My wife then listened carefully from where the squeak was
    coming. It was coming from the hinged in the actual door, the hinge
    like parts that allow the door to roll up. After we sprayed all of
    them, the sound just went back to the normal electrical / mechanical
    sound of the door opening and closing. I am sure our neighbors are
    happy too after 6 months of (very) early openings. Hope this he
    remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
    2 Remove the outer screws , starting from lower side of the panel.
    Remove the inner screws. Keep all set of screws ordered, and take note
    of the order you remove them. You will follow reverse order in
    reassembly.
    4 the frame will be free now,
    5 Remove the external glass panel and leave it in a safe place.
    6 Replace the inner glass.
    7 Clean outer glass and metal door, re-assemble it and mount it back
  • 3,230 Answers
There should be a hole in it to where you can slide a nail or a screw through to hold the hinge open so you can put it back on
Good Luck!!
Thanks
Took maytag oven door off to clean cannot get it back on hinges will.not stay open and keep.snapping back fingers r sore took a pipe to pull them back but they wont stay How do I keep them from snapping...
It is a two person job unless you want to pull the whole stove out and take the cover off and then remove the springs. Put the door back on and put the springs back and the put the cover back on.
Oct 10, 2014 | Ovens
How do I get the door off for cleaning
On the door hinges move the little clip up on both hinges then you can lift the door of the stove don't forget to clip them back when you put the door back on
Cheers Steve
Apr 19, 2014 | Lofra MXUD66GGI Gas Kitchen Range
Oven door
Nectar time take a photo first, they generally only go back one way.
removing the door may make it easier open the door see the hinges on the bottom lift up the little cam on each hinge then just lift the door up & it should come out.
Apr 17, 2014 | Kenmore Sears Electric Range Stove Oven...
Hi I have a Lofra Maxima Model no: MXD96AMFEP and need the Oven Selector Switch and Oven Door Hinges - can anyone help please am deperate!
Hi Gemma, this is Carlos from Lofra of Brazil. I would recommend you to contact our headquarters in Italy to help you locate the needed part for your range.
Please write to consumerservice@lofra.it or call +39 049 9904811.
Kind regards,
Carlos Fleischfresser
Lofra Sud America
Jan 18, 2011 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Hi, I have a Lofra Model 51440401 MG 96 GG/Cn.
Have the hinges and springs definitely gone? I only ask because Lofra oven doors have a reasonably awkward fitting method. If you don't get the anti rotation hooks sorted out correctly. There is a manual online that may help. http://www.lofra.it/manuali/manualeITA_ING.pdf you would need to check page 44 of this pdf file to just see what I mean. Other than that I have not seen these as spares anywhere, So I apologise if I have wasted your time.
Nov 17, 2009 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Lofra five burner gas cooker, oven door not closing properly,
It sounds like you need to check the fixing screws of the oven,failing this replace the hinges.
I hope this helps.
Jul 07, 2009 | Lofra MXD96MFEPI Dual Fuel (Electric and...
Oven door won't go back on
well there is one where u have to put a pin through the hinge to lock it in a certain place to remove and reinstall it..kinda tricky. locks it in the semi-open position. others have pieces that swivel down to lock the hinge in that position for removal and reinstall. it's not easy if you've never done it. :)
Jun 13, 2009 | Kitchen Ranges
Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
May 23, 2009 | GE Ovens
Kenmore ceramic top electric stove door problem
For a while, they were building Kenmore stoves with hinges that get bent out of shape easily. If your stove is still in warranty, (I'm sorry to say) call the 800 number for a repair. You can get a Saturday appointment if you're persistent enough.
If not in warranty, the hinge kit should still fix it, and the parts are about $45.00 for both, and they come with instructions. It took me about an hour the first time, but I've got it down to 25 mins. You'll need a square drive bit, and beware of the very sharp metal edges.
If you have a warming drawer in the bottom, it's more difficult. In this case, removing the drawer is harder. And after getting the drawer out, the metal liner along the sides of the drawer have to be loosened in the front and bent inward out of the way. Don't worry, they go right back with no trouble.
If you decide to pay someone to do the work, please call a local company.
Mar 31, 2008 | Maytag CWG3100A Gas Single Oven
Lofra MXUD66GGI Gas Kitchen Range Logo
166 people viewed this question
Top Lofra Kitchen Ranges Experts
Paul Carew
ray gallant
Are you a Lofra Kitchen Range Expert? Answer questions, earn points and help others
