Question about Compaq Computers & Internet
Tally backup error
Sir,
I have 6 companies in tally 7.2. Whwn I am taking backup showing error ''Cannot take backup''. How do I solve it.
Regards
DK
Jalpaiguri
West Bengal
India
  • 527 Answers
Click this link for ur problem. just go through it. this is one of the best site i had ever seen
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on Jun 26, 2009
Tally 5.4 error
try to configure your configuration setting. change the data source where you data saved.
Exp (from program files, configuration setting) :
;; Tally eis 5.4 workstation specific parameters file
[Tally]
; Specify location of Data files
Data = D:\data tally\Tally 2\DATA
;; Specify list of companies to preload
; ** TO STOP DEFAULT LOADING set the following line to NO
Default Companies = Yes
Load = 0001
;Load = 0002
; Specify list of TDL files for user defined reports and changes
; ** TO STOP LOADING TDL FILES, set the following line to NO
User TDL = Yes
;TDL = <TDL file 1>
; Specify location of TALLY.SAV (saved configuration of Tally)
Config = c:\TALLY
; Specify Color details of local monitor
Color = Yes
a bold letter is the source of data that you must change.
Jun 22, 2009 | Computers & Internet
Sub : TALLY 7.2 error
exiting tally! \r\ninternal error
software exception c0000005
(memory access violation)
Apr 20, 2009 | Tally T2250 Matrix Printer
Software Exception c0000005
to solve this type of problem first of all take backup of your tally data then right click on ur tally icon on desktop go to properties then click on findtargate open ur tally configuration file see the line
load comony=yes (change yes into no) save the file & exit start ur tally pres ctr+alt+r selct the company which was giving error press enter tally will ask to rewrite the company press y to yes let the finish rewrite task then start working on tally
try this this works
RAKESH RANA
98682225794
Feb 02, 2009 | Computers & Internet
Have a problem in tally 7.2
Dear Archana,
If you are using tally legal. Please check whether the date & time are correct. If correct then check the data folder file permission (readonly, hidden, system attributes) are removed. If not while starting tally press Ctrl + Alt + R for and select company which one is getting error. It will rewrites the data of that particular company. Then close tally and open again check it. If this doesn't work u should contact tally support with u r licence key and product id.
Thanks & Regards
Nanda Kishore
Nov 13, 2008 | Computers & Internet
ERROR IS (MEMORY ACCESS VOILATION C0000005)
I AM FACING LOT OF PROBLEM DUE TO ABOVE SAID ERROR ALL THE OTHER SOFTWARE IS RUNNING PROPERLY EXECPT TALLY 7.2
TALLY IS OPEN UPTO SELECTION OF COMPANY AFTER THE COMPANY SELECTION AT GATEWAY OF TALLY IT SHOWS THE ERROR MEMORY ACCESS VOILATION C0000005
Nov 12, 2008 | Tally Line Matrix T6050 Printer
How to Take a Back up Of Tally 7.2
Open Tally, press Alt+F3-Company Info, you will see Back Up link. Select & enter required fields (drives) where you would like to take back up
Go to company information- click backup - you can take backup on floppy or on hard disk with proper path.
i.e make the backup (or any name) folder on suitable drive. But do not choose C: drive as you may forget when you are formatting the drive.
Then you can copy the same folder on CD to open any where.
Sep 16, 2008 | Computers & Internet
My tally 9 single user not opening my selected company
i have problem regarding tally9 internal error
software exception errorc0000005
sagar_manohar@yahoo.com
Aug 25, 2008 | Computers & Internet
Tally6.3
Sir,
There is no option to recover the password. But there is simple steps to recovor the data... try it
Lets understand some feature and working of tally. Tally provides a backup and restore utility which collects all files of tally company into one file named tbk500.001. This way of tally backup is easier to restore as this one file can be kept save and easily can be restored instead of all files in that folder. If any of the file gets missing or gets corrupted tally data wouldn't work.
In first case when data gets corrupted while working on tally and we are unable to open the company then data can simply rewritten. Come to Company selection menu. Press "Ctrl + Alt + R". Now select the company for re writing. 90% chance is that you problem would be get solved.
This is the best website for all the tally solutions. try it
http://www.apnitally.com/2006/09/recover-your-data-in-tally-some-tips.html
Thanks
Good Luck
“Don’t Forget to rate the Solution”
Jun 14, 2008 | Computers & Internet
Error in tally 7.2
This is vishu
Solutions to these problems needs common sense rather than tallyexpertise. Lets understand some feature and working of tally. Tallyprovides a backup and restore utility which collects all files of tallycompany into one file named tbk500.001. This way of tally backup iseasier to restore as this one file can be kept save and easily can berestored instead of all files in that folder. If any of the file getsmissing or gets corrupted tally data wouldn't work.
when data gets corrupted while working on tally and we are unable toopen the company then data can simply rewritten. Come to Companyselection menu. Press "Ctrl + Alt + R". Now select the company for re writing. 90% chance is that you problem would be get solved.
Mail me Your response.
Dec 21, 2007 | Computers & Internet
Recover tally data
Dear Sir/Madam,
I am getting the following error,
Existing TALLY file damaged File:C:/Tally/0001/Tr01298.500
Position:149760
Chars:128(done 128)
Please give me a solution to get my data and I am using Tally7.2 version...
Thanks & Regards,
S.Prasada Rao
Sep 10, 2007 | Tally T2250 Matrix Printer
Computers & Internet Logo
264 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
