Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
F&P dishwasher; Model DW 691ED WH; Fault - F4 on display. What is this fault?
  • 3,230 Answers
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
good luck
Posted on Jun 26, 2009
When the indoor unit is on F4 fault error code display.please help to solve the problem.
f4 mean Air Conditioners Questions & Answers - Fixya
www.fixya.com > Forum > Tags > f4 mean
My gree split type ac error F4 what is problem Name of malfunction = Outdoor tube sensor open or short circuit Display of double eight code = F4 this means
Oct 29, 2015 | Heating & Cooling
Fisher & Paykel dishwasher. Why is it displaying fault F4?
According to the owners manual that fault code is for a faulty temperature sensor or element. It also says to contact an Authorized Service Center. Hope this helps!
May 15, 2015 | Fisher Dishwashers
How do I fix a fault
Not a problem. I have noted that the F4 Ignition fault you are getting is with a Glowworm 18si boiler.
This relates to the burner system and will need a gas licensed technician to fix it.
I am providing you reference to an Installation and service manual to help you understand the likely fault but under no circumstances is this an invitation to attempt to fix the fault unless you are a qualified gas technician. Refer page 37 in the manual.
http://www.acwilgar.co.uk/Boiler-Manual-PDF/Glow%20Worm/24ci-18si.pdf
Aug 13, 2014 | Dishwashers
My bosch dw gives a error code of 1 this is an over or under water filling fault not a heating error which is posted on this site which one is correct
Hello, welcome to Fixya. Actually an error code "1" refers ONLY to a heating error. I'm not sure what you've based your info on, but "1" being displayed has nothibg to do with a water fill/level issue what-so-ever with any Bosch dishwashers. Here's how to perform a test or diagnostic for the "shu43" series Bosch to determine once and for all the problem you're having though. Make sure the power button is in the off position ( open & closing of the door will activate the "auto shut off" ). Once certain it is "off" press and hold both the regular button and rinse & hold button, then turn the unit "on" while continuing to depress those 2 buttons. Initially, control module version # will display ( i.e. "20" = version "0" without jumper...not important for this ). When the buttons are now released, the lights above them will flash. To start testing, press both the "regular wash" and "rinse & hold" a second time. Let the test follow through. When testing has ended, the display will show an error using codes as follows. "0" = no error. "1" = aqua sensor fault. "2" = heating fault. "4" = filling fault. and finally, "8" = NTC ( temperature sensor ) fault. If it where related to a fill/level error you would see the letter "F" during washing but the # 4 in diagnostic's. Similarly for a heating fault, the diagnostic will identify a #2 but the "1" appears during normal washing. Let me know if I can assist you further. Hope you found this helpful and if so please allow for a positive rating. If there is anything not clear let me know and I'll try to expand on the info I posted. Good luck. Macmarkus :)
Jun 09, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Error message f4 fan lt electric double oven model 49425 & 49429
Every fault code I am able to find concerning F-4 period has to do with bad oven sensor. This is the probe coming through the wall inside the oven to read oven temp and to regulate it. Hope this helps. Rick
Mar 04, 2010 | Ovens
F4 fault nautilus
F4 mean heat sensor. need a proffesional to come in and fix it.
Aug 16, 2009 | Fisher Dishwashers
Whirlpool dishwasher ADP 4732AL
sound like you have a valty inlet valve if your model has the valve built into the hose you will have to replace the hose assy.
Mar 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
F4 Fault indication
F4 is a water inlet fault. It doesn't make sense if you have this fault indication with water flowing into the unit. Does the dishwasher drain properly? Usual suspects for an F4 indication would be a clogged inlet line, water supply turned off, bad fill valve, or a control board failure. Let me know if this helps, or give me a little more information on what you have done to correct so far.
Jul 09, 2007 | Asko 24 in. D3350 Dishwasher
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
308 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
