Question about Canon LASER SHOT LBP-5000 Printer
Yellow light on and the driver report an error code: E198 0000 What does this code mean please.
Posted on May 20, 2010
Dell latitude d830 screen not showing but external screen showing and on device manager NVIDIA QUADRO says windows stoped this because it reported a problem error code 43 and the drivers are up to date
Error code 43 means a driver either didn't load properly, is the wrong one or is missing.
Check video driver by running in safe mode. If it still won't work the laptop screen, replace the screen after checking it isn't the backlight by shining a bright light at the screen to see if anything is showing.
Jul 11, 2014 | Computers & Internet
I cannot cannect my 6230i nokia to my computer when connected your device is reported windows error 43
Error Code 43 is a Device Manager error that means the following:
Windows has stopped this device because it has reported problems. (Code 43)
When you get this error with USB devices it's because one of the drivers controlling the device notified the operating system that the device failed in some manner. It will be of issue of the loaded corrupted drivers. You should reinstall the operating system or reinstall the drivers that doesnt have virus or file damages.
Oct 05, 2013 | Nokia 6230i USB
What is code 43
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Restart your computer if you haven't done so already.
There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Depending on the changes you made, some solutions might include:
Jan 23, 2013 | Lenovo Computers & Internet
Canon ir c3220 color copier error E000020-01b0. What means? How solve that error?
Canon Error Code E000020 01b0
Although the yellow drum is indicated, in the link above, please note it may not be the yellow drum if instead it is the:"laser shutter or the plastic actuator on the right side of the front door."
Jan 24, 2018 | Office Equipment & Supplies
My web cam stop working it say the following error in device manager. Windows has stopped this device because it has reported problems. (Code 43)
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or
update driver
hope this helps
Feb 16, 2011 | Computers & Internet
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
Broadcom 440x 10/100 Integrated Controller driver will not load
Your resolution will most likely be a replacement of the motherboard. You can try flashing the BIOS and see if that resolves, but from your details it appears there is a hardware failure of the motherboard. Generally, you can find a motherboard for this model on Ebay for around $100
Jan 10, 2009 | Dell Inspiron 8600 Notebook
Canon i550 problem
The yellow blinking light is not reported in the code errors, take a look to service manual http://rapidshare.com/files/91114670/Canon_i550_i850_i950_Service_Manual.pdf.html
(hard to find but I did it ! )
I had the same problem and I solve it sending the clean head command from the settings of the printer driver (win XP)
I also reset the printer as it is explained in the service manual.
Nov 02, 2007 | Canon BubbleJet i550 InkJet Printer
Canon LASER SHOT LBP-5000 Printer Logo
825 people viewed this question
old marine
old marine
