Question about SanDisk 2GB microSD Memory Card
How do I turn off write protected? - SanDisk 2GB microSD Memory Card
    Problem Solver:
  • 8 Answers
There was a little lock on the right side of the card you can see it on the buttom(facing up).
Hope this helps
Posted on Jun 26, 2009
Where is amp curcuit protection in onkyo sr
There are plenty of protect circuits in your receiver. Each chanel has one as well as dc protect and thermal protect etc etc. More than likely you have a blown channel that needs to be rebuilt.
May 17, 2012 | Onkyo TX-SR604 Receiver
How do you reset the protection mode
The protection function has been activated because it has sensed an output load problem, turn receiver off and remove the speaker wires, this will reset the protection circuit. Now! turn the device on and turn the volume right down, if the protection mode stays off it indicates a short in the speaker wire or one of the speakers, but! if the protection circuit comes on with "the speakers and wires dis-connected" it means there is a short in the audio outputs in the receiver itself, this can only be rectified by having the parts replaced.
Mar 02, 2011 | Sony STR-DE585 Receiver
I turn it on and it says protect then it turns off
Disconnect the speakers and turn it back on. If it still says "protect" it needs serviced. If not, turn it off and re connect one speaker at a time and turn on. If it goes back into protect, you need to check the speakers themselves for an internal short or a blown voice coil. If you have a multimeter, check the impedance on the speakers or the resistance on the speakers. If the meter reads 1...... the speaker is more than likely bad. If you need further help, post a comment and I can help you further.
Jun 17, 2010 | JVC HX-D7 Shelf System
How to remove wave protect in spds
Use the following procedure to turn off wave protect:
1. Power on while holding SETUP and WAVE ("Welcome to SPD-S", followed by "wave protect off" will show momentarily in the display).
Note: Repeat the procedure to turn wave protect back on.
Apr 17, 2010 | Roland Spd-S Sampling Percussion Pad...
When i switch on my samsung HT-Z110 the word hello appears then protect thenit turned off!
Audio receivers have an output protection circuit called "protect mode", this is to protect the receiver from short circuit failures.The speakers and speaker wires are what I inspect thoroughly first, look for bare speaker wires,or bare wires that are touching each other at that point,check speaker wires at the back of the receiver for sloppy connections,etc.If all looks good then try disconnecting all the speakers at the receiver,then turn power on to see if it goes into "protect mode", if it does the the receiver probably has an internal short and will need to be sent in for service,if it doesn't go into "protect mode" then connect one speaker at a time back into the receiver until it does go into "protect mode" then which ever speaker you connected last is the speaker that is shorted(blown) and then you know that speaker is the problem and it will need to be replaced or repaired. Good luck !
Nov 29, 2009 | Samsung HT-DB600 System
How to turn protect off power shot s30.
You'll need to go into the review mode, hit menu, and then in the first category (top menu), scroll down to protect, and then hit "function set" to turn it off.
Sep 13, 2009 | Canon Cameras
Protect is ON
Either there is a bad capacitor in the protection unit or you can find the wire that goes from volume control to protection unit and unplug it.
You can also try turning the volume all the way off before turning on, then slowly turn up from there
Jul 20, 2009 | Denon AVR-900 Receiver
Protection mode
It's normal for some amps to go into protect for a few seconds when initially powered up. If it remains in protect mode, it may have shorted output transistors. To eliminate other possible causes, read through the following troubleshooting page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Dec 11, 2008 | Phoenix Gold Titanium 800.1 Car Audio...
Amp keeps turning itself down - cant turn off 'protection'
yes,pls.stop plugging the system,you may harm your system if you do so,the system has it's own system analysis mode,and if there's something wrong in the circuitry,it will activate,you need the authorize service center my friend,it's a technical problem.
Dec 09, 2006 | Cambridge Audio Azur 540A Amplifier
Write protect turned off
If the write protection tab of the cassette is open(set to save), (STOP and Protection! will be displayed) Release the write protection tab to record
Dec 15, 2005 | Samsung SC-D353 Mini DV Digital Camcorder
SanDisk 2GB microSD Memory Card Logo
419 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
