Question about HTC S710 Smartphone
Display black out / problems
Display just go blank intermittently ! tried several different ROM upgrades, but no success, the only thing to solve is either leave it for some unknown time / switch off leave for 5min & last best switch off takeout battery for around 2-4min and plug battery / switch on again.
PDA remains fully operational when this happens. Its really frustrating....
any solutions??
Hi, I am having the same problem. and now my screen is completly blank, did u find any other solutions?
Posted on Jul 03, 2009
I am trying to print the Counter for each User on my MP C3502 machine. I have been able to successfully print the counter from our other 2 machines (3352SP, 4002SP) but when I follow the same steps for the...
Someone set it up were these function you have to log in . So either press log in button on panel or when you press user tool counter button press log in user might be admin and password leave blank. unless someone has set it up using different info. If so try supervisor and leave password blank
Jan 21, 2014 | Ricoh Aficio Office Equipment & Supplies
AT POST motherboard hang at INITIALIZING USB.....
Several things you can try:
  • Remove the CMOS battery leave for 10 minutes and re-insert and try to reboot
  • If this fails to solve the issue, check the BIOS (F2 on boot) and disable USB legacy support
  • Then if that fails, try swapping out the RAM modules until you manage to get a successful boot.
  • If you suceed in this, download memtest and check the integrity of the ram modules, it may be you have an intermittently faulty ram module.
  • If this fails, it is likely that the USB controllers on the motherboard are damaged
May 19, 2012 | ASUS P5GL-MX Motherboard
Hi, my name is Walter. I have an HTC 7500 not upgrading
You can try with the sd card boot option,More info you can find here
http://www.resco.net/forums/ShowPost.aspx?PostID=2804
and here
http://pdaphonehome.com/forums/xda-mda-sx56-pocket-pc-phone-edition/48619-upgrade-failed-phoen-s-screwed-up.html
i tried it in the past and is working.
Jan 11, 2010 | HTC Advantage X7500 Smartphone
Blank display
So if you have a blank display or just a white one, replacing the lcd screen should fix the problem.
See the link below for a guide on replacing the N70 lcd screen and links to buy a new one from ebay.
How to Replace the LCD Display Screen on Nokia N70
Nov 06, 2009 | Nokia N70 Cellular Phone
Connected ir3300 to network. Can ping static ip address. the PS3 print driver install detects the printer on the network. Printing fails - print times out every time. Tried installing printer on Server...
Did you just install a NIC (aka ethernet port) in your copier?
To print Network Multi PDL Printer Kit C1 needs to be installed. This contains the NIC and the N Boot-Rom. The copier then needs to be upgraded with networked firmware using SST.
Go into Service Mode (Additional Functions > 2,8 > Additional Functions). Go to Copier > Display > Version. Check the number for BOOT-ROM. This should have a N at the end. If not you need to replace the C BOOT-ROM with a N BOOT-ROM.
Also under Copier > Display > Version check the number for PS/PCL. If this is blank then you don't have printer drivers installed on the copier. You will need to get a technician to come out and upgrade the firmware on the machine.
Aug 17, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Dwq 58a not recognizing blank media
your DVD ROM lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working again but be careful remember that no power should be attached to ROM.
or you can buy a lens cleaner from market and try that.
pls rate my solution
thankyou
Feb 16, 2009 | Sony DWQ 58A 8x8x4 Slim DVD RW w/ NTI DVD...
MMS retreival
Mobile phones take and display pictures in a wide variety of resolutions and file formats. Many phones can't display some of these pictures from different models because their display resolution is not compatible.
Do you have this problem on every MMS received (from different users), or is this an intermittent problem?
It sounds like you are receiving an MMS forwarding message, where the content of the message is actually stored on a web server that you log into with the information that was forwarded to you.
Please check the following MMS settings on your phone and verify that they match:
From the standby screen, press the Menu Key.
Scroll to "Settings," press Select.
Scroll to "WebAccess," press Select.
Scroll to "Web Sessions," press Select.
Scroll to "Cingular MMS" press Menu.
(if not there select "new")
Scroll to "Edit," press Select.
Validate the following parameters:
Homepage: http://mmsc.cingular.com
Service Type 1: HTTP
Gateway IP: 66.209.11.32
Port 1: 9201
Domain 1: leave blank
Service Type 2: WAP
Gateway IP 2: 0.0.0.0
Port 2: 0
Domain 2: leave blank
DNS 1: 0.0.0.0
DNS 2: 0.0.0.0
Time out: 5 minutes
CSD no 1: leave blank
Username: 1: leave blank
Password 1: leave blank
Speed (Bps) 9600
Line Type 1: ISDN
CSD no 2: leave blank
User Name 2: leave blank
Password 2 leave blank
Speed (Bps) 2: 9600
Line Type 2: ISDN
GPRS APN: wap.cingular
User Name: WAP@CINGULARGPRS.COM
Password: CINGULAR1
Press Done.
Press Exit.
Press Back
Press Back.
Scroll to "Messaging," press Select.
Press the Menu key.
Scroll to "Inbox Setup," press Select.
Scroll to "MMS Message Setup," press Change.
Scroll to "Server Info," press Change.
Scroll to "MMS", press Menu key.
Scroll to and select "Edit".
Validate the following settings:
Service Name: MMS
Server Name: http://mmsc.cingular.com
Web Session Name: MMS
Dec 17, 2007 | Motorola Mobility RAZR V3
Sony crx320e cannot read cd but can read dvd.
try re-installing the Drive.
Cleaning the Laser head.
Using a different read-write program.
Mike @ Compurepair.
Oct 20, 2007 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
Ipaq H 3970 storeage card problem
Try soft resetting the unit, then try to access it afterwards. Hope that helps
Apr 25, 2007 | HP iPAQ h3970 Pocket PC
HTC S710 Smartphone Logo
140 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
