Question about Sharp LC26SB24U 26 in. LCD TV/DVD Combo
I DONT KNOW HOW TO PUT THE VGA INPUT ON MY TV BECAUSE I DONT HAVE THE CONTROL.
Use the channel up/down on the tv, go below channel 1 for input 6.
Posted on Sep 12, 2010
  • 417 Answers
get a higher end universal remote with expanded features. the menu will be in there.
J
Posted on Jun 26, 2009
How do i know exactly what cables to connect from tv to laptop
Your tv must have a vga input.....the same hookup that is on the side of your laptop. If it does, put your tv input on vga and use the function key on your laptop....hold it down while tapping f5.....
May 02, 2012 | Televison & Video
I don't seem to be able to scan for channels it keeps saying "No Signal". Need to know how to be sure everything is unlocked before starting to program. I have checked the connection with...
I dont know where to get the instructions but make sure your tv is on the right input or source. If you have it hooked up coax then dont look for picture in hdmi or vga. Once you have the right input or source on the tv it should come right up.
Jun 21, 2011 | Olevia LT32HVM 32 in. LCD Television
How i use my samsung CRT TV as a computer monitor? my TV has A/V and RGB input connectors. and My PC has only VGA out put.
You'll need a VGA to Video composite / S-Video converter (commonly called PC to TV converter), this device will allow you to connect the VGA output to composite video input of your TV.
Feb 24, 2011 | Computers & Internet
Why won't my tv display my computer screen
Hi. The best way to hook your computers display to your LCD screen will be to use the VGA input socket. If your video card can support both S-video input and VGA, you can use either one but, the VGA is best for optimal resolution. This is the easy way to do this. Step one, connect the VGA cable to the computers video card and then, run the other end of this same cable to the VGA input slot on the LCD screen.Step 2, next you will make sure that the LCD's input selection is selected to show what is being transferred from the CPU video card by using the input button on the lcd remote control. The lcd(your tv) should be on VGA or PC input signal. Step 3, now, you Will have to also make sure that your video card is set to transfer this signal as well by pulling up your video cards software window and switch to the proper options. once this is done, you should get a signal. Be sure to use the VGA input/output ports on both the lcd television and your cpu for optimal transfer of the video stream. Here is a pic of your back panel. use the input port labeled I for good PC input quality.
Mar 24, 2009 | Proscan 32LB30QD 32 in. LCD TV
NO VGA INPUT SIGNAL
hi im aleli can you give me a driver of c700 video controller,, tnx
Jan 08, 2009 | Compaq Presario C700T Notebook
Connecting laptop to LCD TV
Have you tried another monitor on the VGA output? If that still doesnt work may need to set up in CONTROL PANEL>DISPLAY>SETTINGS>DISPLAY- should show another monitor fool around with that and see if you can get it to work, if so then try your tv, But ive never seen a tv with a VGA input? Maybe its me? Good luck JLS
Oct 14, 2008 | Dell Inspiron 1200 Notebook
How do i make my hp computer connect to my samsung tv
First you have to make sure your TV has the right video input like VGA or DVI.
Then Your computer has to have DVI if the TV has DVI connector.
If the TV has VGA and you know that all computers come with at least VGA, all you would need is a VGA video cable.
Hook the cable to the VGA port, then set your TV to the input that coincides with VGA.
then you can set the resolution in the control Panel > display to the best resolution that gives you a good picture on the TV.
Please remember to rate all users who assist you for free :)
Oct 04, 2008 | HP Computers & Internet
How to connect my esprimo laptop to my lcd tv
you would be able to connect the laptop to the lcd if the laptop has an extra vga port. if it has the port make sure the tv has the same port and if it does connect them together and put the lcd tv on inut mode for that (ex. PC input, VGA Input, RGB input). you might have to go into the display properties in the control panel and make sure you enable it for 2 displays(1 for the laptop mainscreen, and 1 for the lcd tv).
Sep 17, 2008 | Siemens Computers & Internet
I pressed the VGA button on my remote and lost my picture.
Find the button that relates to the input you want to view. IE "video" "composite" "s-video"
Or simply try any of the input buttons until the picture returns.
Also try simply hitting the VGA button again.
If none of that works, please let me know the model number of the tv and the input sources you are trying to view.
May 02, 2008 | Televison & Video
Getting my Matsui TV to play sound out of the PC VGA source
you need a cable to connect the sounds from your PC to TV. you need a baby plug to RCA plug.then you have to connect the baby plug to your pc soundcard audio output to your TV sound input.
Mar 13, 2008 | Computers & Internet
Sharp LC26SB24U 26 in. LCD TV/DVD Combo Logo
128 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
