Question about Toshiba 57H83 57" Rear Projection HDTV
My 57" proj tv toshiba has sound sound but no picture. Need help.
I get sound from all channels. No video. Checked all other inputs and also get sound but no picture.
5 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Toshiba TP50H95 No sound no picture
Sounds like a problem in the deflection circuits either vertical or horizontal. You may also want to check the solder connections in the tuner as they have been known to develop cracks over time. But the prior shrinking tends to say deflection problems.If I can assist you further please let me know.
Posted on Feb 03, 2008
ctf1800
  • 4402 Answers
SOURCE: toshiba tv - no picture
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Posted on Mar 14, 2008
SD Tech
  • 14553 Answers
SOURCE: Distored picture on top half of the screen
This is one of the sets with bad HYPER boards. If it clears up after a while this is your trouble;I just checked a site in LA--the only way to get the board is to go to PTS electronics and send them the original board for repair--part alone is over 200 and is soldered in--a lot of these sets are having this problem.
I know I am not giving you good news but I am pretty sure this is what is wrong with your set--seen dozens of them.
if you think I helped you in some way--give me a vote here I do this for free. IF YOU HAVE QUESTIONS OR NEED MORE HELP contact me by responding to this post.
SD TECH (SAN DIEGO)
Posted on Aug 29, 2009
techman007
  • 1112 Answers
SOURCE: Toshiba DLP 60" TV not showing TV programs, sound ok
Have the tuner signal board replaced. HDMI does not use the regular tuner bands, it is bypassed when using hd inputs.
Posted on Oct 24, 2009
Toshiba TV/VHS/DVD
press the tv on the remote. if you want to use the vcr. press vcr on the remote.
Apr 04, 2008 | Televison & Video
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
ON-LINE INSTRUCTIONS???
One of the most recognizable makers of TVs in the world is Toshiba. The company's TVs are found in every major electronics store at a reasonable price. Packed with features, they have a model for everyone, whether it be LCD or older, tube-based CRT technology. Toshiba T.v are fairly easy to operate. Basic functions
  • Before you do anything with your Toshiba TV, you have to plug it in to a wall outlet. After plugging it in, locate the power button on the front (or on the remote) and turn on your TV. Depending on if you have cable TV or not, you can use the channel functions to flip between your favorite channels. The "Menu" button is useful to access advanced settings, like channel detection, parental controls, closed captions and picture controls.
  • Using video inputs
  • You can connect a variety of devices to your Toshiba TV via its front, side or rear inputs. If you look at the back, you'll see a variety of audio and video inputs to connect virtually any kind of device. You should see a few kinds of video inputs: Composite and s-video (for connecting older technology like VCRs and cable boxes), component video (for connecting older DVD players) and HDMI (for connecting digital technology like receivers and Blu-Ray players). Audio inputs are analog (red and white) or digital (coaxial and optical). Use digital connections when possible to ensure the best quality.
    To connect VCRs and DVD players, simply connect the proper cable to their audio and video outputs, then match the cable to the proper inputs on the back of the TV. Make sure everything is secure and take note of which input you connected it to. Now, tune your TV to the proper input by pressing "Video" on the remote.
  • Maintenence and tips
  • Your Toshiba TV is a sensitive electronic device, so precautions should be taken to keep it in top working order. If the screen gets dusty, wipe it with a dry, soft cloth. If you own a Toshiba plasma TV, be aware of burn-in and ghosting problems. Avoid watching programs that have static images is left on the TV for hours at a time. If you have a flat-panel Toshiba TV, consider getting it professionally calibrated to get the best possible picture
  • Dec 02, 2009 | Cell Phones
    When using cable input video is good but sound has fuzzy static
    Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
    Oct 11, 2009 | Toshiba 27A30 27" TV
    Need the remote code for a phillips dvd player
    These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
    Press a button on the TV’s original remote control that selects an external input channel until the DVD
    recorder’s picture appears. Check your TV owner’s manual for details.
    Admiral
    Curtis Mathis
    GE
    Hitachi
    JVC
    Kenwood
    LXI-Series
    Magnavox
    AUX
    LINE1, LINE2, 00, 90, 91, 92, 93
    INPUT, TV/VCR, 00, 90, 91, 92, 93
    INPUT, AUX
    VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
    AUX
    00
    AUX CHANNEL
    Input Mode Names for Common TV Brands (Example)
    Panasonic
    RCA
    Samsung
    Sanyo
    Sharp
    Sony
    Toshiba
    Zenith
    TV/VIDEO
    TV/VIDEO
    VIDEO
    00
    VIDEO1, VIDEO2, VIDEO3
    TV/GAME
    00
    Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
    Grainy picture
    Hi and welcome to FixYa,
    Initially, some ideas you may want to try/consider:
    • other than the TV, all switched off and unplug. Try evaluating the reception of any/all TV channels;
    • if quality is bad, either the tuner (least likely) is bad or a problem with your cable system/provider;
    • if the quality is good, then either the DVD or the game console has an RF modulator that interferes with the Toshiba's reception;
    • if the grainy picture is when using the Audio/Video inputs, then it would not be the tuner but rather the video processor;
    • should the tuner really require replacement, it would be relatively easy since it is a single block/assembly with a couple of pins and a mini coaxial connector;
    • best approach would be to reference a Service Manual. Pls bear in mind that voltage check requires the unit to be powered on and therefore exposes you to potential electrical hazard.
    Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
    Jan 16, 2009 | Toshiba 57HDX82 57" Rear Projection HDTV
    Sony 57 Inch XBR 2001
    I don't have the XBR, but on my sony, using the cable box remote, I had to go into menu/display/etc. and mark the 1080i, 720p, and 480i settings. you usually get a "if you can see this" comment if your tv accepts the settings. for standard tv i set the screen to normal, and when the upper channels go to HD, they auto go to full screen. Sounds like you are using the component cable, and also make sure you are on the video port of remote, and the the TV input. The above worked for mine. Hope it helps.
    Dec 04, 2007 | Sony KP-57XBR10 57" Rear Projection...
    Video input
    There may be a child lock feature on your set but you would not get sound or picture. If you can not get a picture from the video input jacks and the set works fine other wise then this - sounds like a problem with the Video switching circuits inside your television. I would refer this type of repair to a qualified technician.
    Jul 29, 2006 | Toshiba 57H81 57" Rear Projection...
    Toshiba 57H83 57" Rear Projection HDTV Logo
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
