Question about Welding Tools
Toolex 140 mig welder, wont feed wire.
I have a toolex 140 mig welder, whilst welding the feed stopped and I have noticed the roller is now not working, and the wire not coming thru, yet when I pull the trigger, I do hear a click in the machine each time, any suggestions?
You may have the scew settint your wire tension set to tight. Try loosening the tension and if that doesnt work check the eletrical wire that supplies the power to the roller and make sure it hasnt become disconected.
Posted on Jun 28, 2009
My wire feed welder wont slow down. I was welding some thick galvanized pipe and went to turn the wire feed down and it didn't work
the speed feed rheostat(control) is shorted or you've got a short on the board if it has one. Hopefully just your switch. Check for a short from the switch to the drive motor. Remember, electricity can and will kill you. Be safe
Bryan
Nov 04, 2013 | Lincoln Electric Lincoln Easy MIG 140...
L bought a hobart 140 two days ago, welded about 10 feet of wire with it .now it only feed wire on three out of the five settings
Check the selector switch with an ohm meter. Unplug the unit, ground to chassis and probe the contacts while turning the switch on and off.
Dec 17, 2012 | Hobart Handler 140 Mig Welder
I have a weldmark 140. When you turn the voltage knob it controls the wire speed. The wire speed knob does nothing
Flip up the cover on the side to expose the welding wire rool.
push the feed button on your welding gun, and watch the feed rollers.
If they are turning, then you need to increase the force on your rollers untill the wire starts feeding.
If the rollers do not turn, then you most likely have a bad switch, or connection in your welding gun or your speed control
Good Luck
Oct 24, 2010 | Welding Tools
Wire feed stopped after tack welding on set-up jig
i had the same problem. its probably a bad solder on the wire feed pot. not hard to fix ,but you need a solering iron .BE CAREFULL 1 unplug welder.
2 remove pot and the nut underneath.
3 remove case from welder and remove controll box.
4 run the soldering iron over the joins , then put it all back together, should work fine.
Jul 22, 2009 | Hobart Handler 140 Mig Welder
Wire feed assembly for a Astro power mig welder 110
go here and buy the parts i have one too, fix it and sale it!!!!! (JUNK WIRE FEED )
http://store.daytonamig.com/wifeteas.html
Jul 11, 2009 | Miller matic 140 Mig Welding Package W/As...
Handler 140 wire jerky when welding
make sure rollers are clean and slots not wore out check alignment
do not over tighten wire feed so it smashes the wire
flux wire is hard to get a good setting
make sure if you can set it for gas welding it is not on this setting
Apr 06, 2009 | Hobart Welders 500505 Handler 140 MIG &...
Hobart handler 140 will not feed wire
A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
Feb 13, 2009 | Hobart Handler 140 Mig Welder
Need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Dec 27, 2008 | Miller matic 140 Mig Welding Package W/As...
Welding Tools Logo
643 people viewed this question
Top Welding Tools Experts
Bill Boyd
Marvin
Marvin
Are you a Welding Tool Expert? Answer questions, earn points and help others
