Question about Bosch Axxis WTL 5410 Electric Dryer
My kenmore dryer is blowing out cold air
My kenmore dryer is blowing cold air even after installing a new thermostat and a new heating element
    Problem Solver:
  • 15 Answers
Make sure that both poles of your circuit are live - An electric dryer uses 220 volts to the heating element, but taps into only one pole (110 volt) for the motor that spins the drum. Check your circuit breaker to make sure that neither pole has tripped.
Posted on Jul 20, 2009
  • 109 Answers
Have a look for either a reset button (red) or a overload.
One of these will be in the heating circuit and possibly tripped out due to over temp.
Posted on Jun 26, 2009
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
Dryer is not heating up.
90% of electric dryers emitting cold air need a new heating element installed. If you've checked the thermal fuse, and verified the unit has around 220 volts of power, then the only thing left is the heating element. Typically costs around $40-$60. Can be done by you if you have basic electrical knowledge, otherwise call an electrician.
May 13, 2010 | Kenmore 62802 Electric Dryer
My dryer is blowing cold air. I replaced the
if you hooked up yhe wires on the heating element check the thermostat it will be a oval shapef unit on housing of element and has wires going to it it may be bad.
Dec 28, 2009 | Washing Machines
The dryer continues to heat after it is turned
Was this the reason you installed the element and thermostat? Or did it start doing that after you installed the new ones? Maybe you have the spiral element portion touching the metal encasing aroung it. The element has Line 2 to it at all times so the ground will provide a circuit even when all else shuts off. Check for any other ground issues.
Nov 02, 2009 | Kenmore 800 6983 Electric Dryer
OUR KENMORE DRYER BLOWS OUT COLD AIR
It's most likely a thermal fuse if it's a gas dryer. very easy to install. If your dryer is electric, it's either the thermal cut-off or the heating element itself. If you need help with anything, please feel free to e-mail me. good luck :)
Jul 06, 2009 | Kenmore Dryers
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
No heat
replace the heating element and the limit switches and it will work again cost about 40.00
Jan 26, 2009 | Kenmore Dryers
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore he3 dryer turning round and blowing out cold air. No warm air at all on any of the progams
check for continuity on the thermal fuse, thermostats and heating element which are all located behind the lower panel
Dec 29, 2008 | Dryers
TCO & HLtherm on Dryer
I think you've got your bases pretty well covered. I don't see a reason for you to replace the hi-limit as well. At less than an ohm, I see no reason to bother with it.
Oct 25, 2008 | Kenmore 63942 Dryer
Bosch Axxis WTL 5410 Electric Dryer Logo
1,188 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
