Question about HP Computers & Internet
Motherboard led light blinking
My motherboard led light blinking continuously and when i plug in the power cable nothing seems to go ON. what could be the problem.
The PSU is new!
HELP URGENT>
  • 854 Answers
Check memory module...might be defectivie...try another to test it.
Posted on Jun 26, 2009
Dell 1555 Studio laptop won't power up. After the power cord is plugged in, the LED light on the side blinks white once and orange four times. What could be causing it and how can it be remedi
have you tried a different power source or power supply ,maybe you can borrow one from a friend and try and if that don't work you might have to take it apart and see if your power cable is seated properly in the motherboard
Sep 28, 2014 | Dell Studio 1555 laptop
No display & blink power led
This sounds like a power supply issue. Are the fans in the system plugged into the board? If so, are they kicking on and off at the same time at the power light? Make sure you have a good working PSU and tried that in place of the one you are using.
If that doesn't work, start removing parts until you have just the motherboard and the case speaker plugged in (plus your power button of course). Once you have removed the faulty device, you should start getting a beep code from the motherboard. If you put a known good part back in and it does it again, then the slot on the board that the part seats into is bad (IE: RAM slot if RAM replaced, etc) and you need a new motherboard.
Nov 18, 2013 | Foxconn G41MXE Motherboard
My Dell laptop d600 suddenly shut off and will not power back up....led light on adapter blinks when plugged in...I have tried re-inserting RAM modules but this or nothing else seems to work.. thank you...
Unplug your battery and then plug in AC adaptor and see if laptop powers on. I assume you power button doesnt turn on at all? If so, your motherboard seems to have a power issue. Unfortunately, you have to replace motherboard. If laptop. powers on withour battery then you then battery needs replacement.
Nov 25, 2009 | Dell Latitude D600 Notebook
Front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Jul 28, 2009 | Computers & Internet
HP won't power on at all~PSU light blinking, then solid, then off
Dead short on the machine causing the power supply to go into shutdown (Fold Back Protection)
Remove all of the connectors coming from the power supply (Label them so that you know here they go back to on the Motherboard and the DVD etc (Including the processor fan one)
Place all of them back one at a time starting with the main one if the led stays on then plug in another till you locate the short.
If the led dies when you plug in the main MB connector then you are in deep brown stuff
All you can do then is to remove the Ram and any other unpluggable device to see if that is the cause
Jul 05, 2009 | HP PAVILION A6230N DESKTOP PC
Won't power up
hi
seems like your ram is bad and also change your vga [graphics card]
kind Regards
RAHUL_hunk
Mar 10, 2009 | HP PAVILION A847C Intel Pentium 540 HT...
T5026 won't start up
Unplug the power cord, open the computer and disconnect all the power cables (the cables going from the power supply to motherboard and drives). Then reconnect the power cord and see if the light on the PSU comes on, if so disconnect the power cord and plug in the motherboard connectors and continue connecting components one by one to determine which may be the problem. If no power light with everything disconnected then the PSU needs replaced.
Jan 03, 2009 | E-Machines Emachine T5026 power supply **...
No power
if you have changed and confirmed the psu and after that no power, then do a final test.
by the way, have u plug the power switch,reset switch, hdd led connector, power on led connector in the right pins on the motherboad. confirm it with the help of user manual , also mentioned in the motherboard too.
if all are in the right positions, and system still not working then do a final test.
remove all the power, data cables for all devices like cdrom,hdd,dvd etc. just plug the power plug of psu inside the motherboard and check. remove the ram too. the supply fan and processor fan should run without ram. but it should give a continuous on and off beeps.
if after removing all this, its still not working then it is surely dead.
Jul 24, 2008 | NEC /Packard Bell 4 DIMM AT Motherboard...
A7V8X NOTHING HAPPENING,
When a power supply goes out the way yours did, it's going to fry the MB 99% of the time. So you're going to need a new MB. It's possible that you CPU is ok, but that could also go too. I would replace the MB first, then the CPU if that doesn't work.
Nov 07, 2007 | ASUS A7V8X Motherboard
Psu blinking green light, no power
I read all the solutions, followed the manufacturers instructions exactly, replaced the cmos battery and nothing solved the problem (blinking light on PSU after a power failure and no startup at all). I had ascertained that the PSU was intact by disconnecting all the PSU connections to drives and motherboard at which time the PSU LED stopped blinking and was constantly on.
Just before throwing my computer away I decided to follow the instructions listed by "guest" to unplug the power to the motherboard and then with the power supply back on to plug the cables back into the motherboard. No only did sparks not fly, but it started up and ran perfectly! Many thanks to "guest."
Oct 31, 2007 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Computers & Internet Logo
266 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
