Question about Eclipse EA3422 Car Audio Amplifier
Eclipse model 5302 car cd,radio
Battery has gone dead and lost cd to reinstall program. esn light is on. anyway to bypass this sillyness?
0 characters
1 Points
I have an eclipse ea3235 that was given to me by my cousin anyways i know this amp hits and it works. i just do not know how to wire or how to place the rca there is something im not doing right.
the rca connections should run from the back of your stereo to the amp, the remote wire should be a blue one in your radio wiring harness. now for battery power, its best to run a seperate wire from the positive post on your battery. the ground wire should be ran as close to the amp as possible. hope this helps, if not let me know what i left out.
Apr 01, 2011 | Eclipse EA3532 Car Audio Amplifier
Radio reset itself whe car is turned off
probably lost its line source for the memory. a dead car battery or removing or bad contact on your car battery would do it. or a bad crimp behind the stereo in the dash also, check the wire colored yellow and its connection/splice. some manufacturers use the blue wire for line power, but usually that is the antenna control or power amp line control.
Jan 21, 2010 | Pioneer Car Amplifiers
I have an eclipse cd3424 that says call800 when i power it up, i called the 18002332216 on the deck and the number isnt in service. The unit wont work unless i figure out what is wrong
310-327-2151 is eclipses new main number. try giving them a call and tell them whats going on. the eclipse radios had a anti theft thing that messed everyones world up. if power is disconnected from it it locks down. good luck
Dec 29, 2009 | Car Amplifiers
Where does the rem wire plug into
It plugs into the power antenna cord on your radio if your radio does not have a dedicated remote cord. The remote switch is so that you amp can detect when your radio is on and turn on too, or is off when your radio is off so as not to drain the battery
Sep 23, 2009 | Eclipse (XA1000) Car Audio Amplifier
Blaupunkt brighton MP35 car cd/mp3 player CD ERROR
Try head cleaning. These things get a real beating, cars vibrate a lot, and potholes does no justice to anything. There is a chance it is on its way out. I bought a 400 dollar pioneer, and it broke after 3 months! I couldn't get it repaired because i lost the receipt. Lat time i buy from best buy, or pioneer...
Nov 19, 2008 | Car Amplifiers
Car radio/cd player replacement, wiring problem
Yes. Both leads need to have +12v for the device to function.
Yes. You can run a bypass to the battery to make it work.
Jun 28, 2008 | Car Amplifiers
Need help in installing amp.
depending on the power consumption of the amp u will need to run a 4-12 ga wire to the positive battery terminal. then u need to ground it with a wire connected to a clean ground like a chassis bolt. next u need preamp outputs on ur deck to send audio signals to the amp. lastly u need to hook up a remote wire to the blue wire in ur cd player harness
Jun 20, 2008 | Eclipse EA3422 Car Audio Amplifier
Factory radio keeps blowing fuses.
you should bypass the factory cd player. I installed a panasonic cd player in a 1994 gs 300 and it was hell. there are alot of wires that have nothing to do with the radio i believe one or some of those wires may be whats causing your problem try this solution if that doesnt work you may have a serious electrical problem
Mar 26, 2008 | Car Amplifiers
Becker Car Radio Security Code Unlock
The best way that your gonna find it is by checking out the dealership, they can help you with that
Dec 28, 2007 | Infinity Reference 1211a Car Audio...
Dodge Neon Radio
The lights may work because the might be tied in with your parking lights, allowing them to illuminate at night for visibility. First thing's first, did you check the fuses in the fuse panel? Check them all since cars have circuits mixed around and the radio is no exception. OK since all the fuses are good, you'll have to pull out the radio and unplug it from the harness. You will have to use a multimeter which you can get anywhere (wal-mart, etc). Set the meter to DC, put the probe on a bare piece of metal in the radio cavity and use the red probe on the harness. Scout the web for a diagram of your car's harness to know what to meter. Now since everything there is ok, you will have to dig a hole and throw the radio into it because the radio is dead. A new one can be bought for as little as $100. You will need a trim kit to fit it into the weird hole from the the radio and a wiring harness as well to make it match up to your car's harness. Both can be bought on e-bay for cheap. Actually the radio can too.
Nov 17, 2007 | Car Amplifiers
Eclipse EA3422 Car Audio Amplifier Logo
69 people viewed this question
Top Eclipse Car Amplifiers Experts
Are you an Eclipse Car Amplifier Expert? Answer questions, earn points and help others
