Question about Casio DL 250LA Calculator
Won't work The machine just gives a buzz grunt when I press a number key. It also displays E. I changed the ribbon and made sure it is plugged in properly.HELP!Thank YouMichele MillsConejo Recreation & Park District
  • Anonymous Feb 23, 2008
    turn on the calculator makes a high pitch screech and the lettet E is displayed , Nothing works on printer or no printer setting. Paper is not jammed.
  • 21 Answers
The problem is with printer. It is either a gear alignment is needed or the printer detector is already defective. There is also a case that an I.C. for the printer on its mainboard is defective. The best solution is to contact your authorized service center on your area.
Posted on May 27, 2008
Jazfit Running Machine
reset the machine, follow this steps and fix it. God bless you
However RUN the software calibration for easy diagnostic goes under the HOOD motor and follow the steps.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 06, 2013 | Exercise & Fitness
Nordic Track C2200 Error Code 440-17E what might be wrong?
reset the machine, follow this step and fix it. God bless you
    • 1
    • 3
    • 4
    • 2
Oct 21, 2013 | Exercise & Fitness
After attaching key all lighs come on but none of the buttons work except foe pulse feature. also belt won't move.
rests the treadmills, follow this steps and fix it. God bless you
replace old batteries ( if your system has batteries, clean the contacts batteries from oxide, dirty, etc) put a new one. Tight the ribbon cable inside the display board+tight the upper and lower connector too.
    • 1
    • 3
    • 4
    • 2
Oct 18, 2013 | Nordic Track C2255 Console (treadmill)
Fitstride t920 treadmill faults
Reset the machine follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
· 2
· 3
Oct 07, 2013 | Exercise & Fitness
I need to program are fax machine to have are fax # on documents that are being sent to other fax machine's
1. Press <function> then "Down Arrow" on the <start> button until [ENTRY MODE] appears.
2. Press "Right Arrow" on the <start> button until [OWN NUMBER SET] is displayed.
3. Press "Right Arrow" [ENTER FAX #] will display.
4. Enter your fax number with the number keys (max. 20 digits). To insert space, press <#>, to enter "+" press <*>. To clear a mistake press <speaker> button.
5. Press <start/memory> button.
6. Enter your name by pressing number keys for each letter. Will display the capital letter for each of 3-4 letters to number, then number, then the lower case letters for each press. Use "Right Arrow" to go to next letter, if using the same number key (IE: B to A uses 1, use "right arrow" to go to next space). The #1 will give a space between words. (Max. 24 Characters).
7. Press <start/memory> [DATE&TIME SET] will display.
8. Press <stop> to exit.
Mar 19, 2010 | Sharp UX-B750 Inkjet Fax
Button problem
What those keys on the membrane pad have in common is pin 18 of the keypad matrix. See page 20 of the Service Manual Membrane Pad Continuity Checks. Do you know how to make continuity readings with an ohm meter? Follow the SM to power down the machine and remove the console to get to the console ribbon cable plugged into the Control Board. Very carefully remove the ribbon cable by squeezing the ribbon cable retainer plug ends to release the retaining plug which will then slide up the ribbon cable as in the pic's. Don't pull on the ribbon cable until you slide the retaining clip up the cable. I would check for any corrosion path issues between the pins on the ribbon cable and the mating socket on the Control Board. Follow the service manual for the continuity checks for the keys mentioned. The ribbon cable has black conductive pads on one side of the cable and you may need helper to make these measurements. With no keypad press you will read an open. Between a few of the keys I pressed for measurements I measured 30 ohms to 90 OHMS.
Do not make any measurements on the control board with the OHM meter. Here is a pic of the retraining clip that latches to the socket on the control board.
If the key press readings are similar to my readings for the effected keys I would try reseating the ribbon cable back in the socket on the control board then latch the retaining clip into the socket on the control board, power up the washer and give it a try. If the community checks on the keys in question read similar to mine not open under key press and the ribbon cable socket looks clean with no corrosion then I would suspect a Control Board issue.
If you feel uncomfortable with this I would call in a authorized repair service. Good Luck.
Jun 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Intel D845GBV will not boot into Operating System ,Win XP Pro
Still have that Windows XP Pro full installation disk, that you used for this harddrive?
First:
Make sure all power cables from the power supply are connected.
You have a motherboard, (Intel D845GBV), that has a Socket 478 processor socket, and uses Intel Pentium 4 processors.
Computer Unplugged from power! Touch the metal frame of the computer case to relieve your body of static. Work on a table. IF you get up for any reason, then return, Make Sure you touch the metal frame, BEFORE you reach inside.
1.Make SURE the 4-pin ATX power cable from the power supply, is plugged into the 12 volt ATX connector on the motherboard.
[12 volt ATX connector on motherboard:
Bottom LEFT corner of the processor socket. You are looking at the motherboard with the processor at the top, and the ram slots to the right]
2.Make sure the 40-pin flat ribbon interface cable, is plugged into the harddrive correctly.
There is a faint red stripe along one edge of this flat ribbon cable. The red stripe designates Number 1 pin. (There are 40 pins on the back of the harddrive. [39 actually. One pin is blocked out]
As you view the back of the harddrive, the 4-pin Molex power cable, plugs into the right side. (All the way to the right)
The 40-pin flat ribbon cable plugs in to the left of the power cable.
Number 1 pin of the flat ribbon cable, is next to the power cable connection.
The red stripe, will now be close to the power cable connection on the harddrive, when the flat ribbon cable is plugged in correctly.
3.Make sure the 4-pin Molex power cable is plugged in firmly into the harddrive.
4.Check all power cables to the optical drive/s, and the main power cable to the motherboard.
[20-pin ATX power cable. To the right of the ram slots]
Now, close the computer case, plug the computer back into power, WAIT 1 minute, turn the computer on.
As SOON as the POST screen goes by, start tapping on the F2 key. You are going into BIOS Setup.
You should now be on the main menu in BIOS Setup. You can no longer use your mouse, you have to use your keyboard to get around in BIOS Setup.
At the top you will see headings in the header bar. Maintenance, Main, Advanced, Security, Power, Boot, and Exit.
Use the Right Arrow key and highlight Boot.
Press the Enter key.
Use the Down Arrow key and highlight Boot Device Priority in the drop down submenu. Press the Enter key.
Use the Down Arrow key and highlight ATAPI CD-ROM. Press the Enter key.
Now press the F10 key.
If Yes/No comes up, use the appropriate Side Arrow key, (Left or Right), and highlight YES. Press the Enter key.
IF Y/N comes up, press the y key for YES.
(It isn't a capital Y. The capital Y is shown for clarity. Do Not press the Shift key, and the y key. Just press the y key)
Now press the Enter key.
(F10 is to Save Changes. Y is Yes you want to save changes. The Enter key executes the command)
Your computer will now restart. You need to have that full installation disk in your optical drive. (CD/DVD drive)
Your computer will now boot from the full installation disk in your optical drive.
If your computer goes past booting from the installation disk, because you did not get it in there in time, don't worry.
Just press the CTRL key, ALT key, and DELete key, AT THE SAME TIME. (Not shouting)
This will restart your computer, and it will boot from the Windows full installation disk.
Apr 08, 2009 | Computers & Internet
Grunting noise?
If your machine is a Brother 4100 you can clear the drum message by pulling the drum out of the machine and then pressing the clear button. The display will ask if a new drum is the be installed. Press the number 1 to say yes. Reinstall drum. This resets the drum counter.
As far as the grunting sound, that may be caused by a tight or jammed toner cartridge. Try changing that out.
Hope this helps.
Aug 27, 2008 | Brother IntelliFAX 4100 Laser Fax
How to set date and time on Canon FAX-L350
Maek sure machine is switched on and there is a display showing.
1. Open the 'one-touch' speed dial panel (plastic flap to right of main number keys)
2.Press the key 'data registration' The display will show "REGISTRATION 1. DATA REGISTRATION"
3. Press 'Set' key twice (lower right key on grey centre panel area). The display will show "DATA REGISTRATION 1. USER SETTINGS" after the first key press, then "USER SETTINGS 1. DATE & TIME" after the second key press.
4. Press 'Set' again, then use the numeric buttons to type in the correct date and time - you should get something like 11/01 2009 and 16:09 in the display (use 24 hr clock for the time).
5.Press 'Set' to save the date and time the display will show "USER SETTINGS 2. UNIT TELEPHONE #"
6. Press the 'Stop' key to return tot he machine's normal 'standby mode' .
7. Print off this webpage so that you can remember how to change the time for daylight saving time changes etc... or int hee vent of a power cut.
Hope this helps.
Aug 12, 2008 | Canon FAX-L350 Plain Paper Laser
E0004 on Canon NP6050
it is a SSR,heater 1 or 2 ,or thermal switch error.   Try to reset,        follow this procedure. SERVICE MODE E004 SSR O FUSER WON´T SHUT OFF
To reset this code use simulation 401
SERVICE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck     CE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck
Oct 24, 2007 | Canon NP 6050 Copier
Casio DL 250LA Calculator Logo
255 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
