Question about GE GSS25IFR Side by Side Refrigerator
GE refrigerator GSL25IFRF side by side fridge quit cooling. Had problems with ice maker first, now both sides of fridge quit cooling. Is there a quick fix or do I need a repairman to come out?
  • jasonkirk73 Jun 26, 2009
    Redhaze,
    Thanks for you quick reply. I looked under the hinge of the freezer door and all I see if a water line. The weird thing is that after i unplugged the fridge and let it sit a while, then plugged it back in. It seems to be starting to cool again. Can this be? Do they just quit working and start working again?
    Thanks
    Jk
  • 10,515 Answers
There are 2 Scenario's -
1.Refrigerator QUIT cooling
2.Refrigerator is not cooling well.
I Believe in the problem you described above , there might be few possibilities.
Note - Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
  • To check Compressor, follow the below guidelines :-
    http://www.acmehowto.com/howto/appliance/freezer/check/compressor.php
    Note - You would need to put an amp-meter on the circuit to see what the current draw is like.If the compressor is shorted to ground you cannot check the amp draw because it will constantly kill the circuit breaker. A better way to go would be to check the continuity of the compressor to ground and each winding.
    To check Thermostat, follow the below guidelines :-
    http://www.ehow.com/how_2167621_troubleshoot-refrigerators-thermostat.html
    To check Relay, follow the below guidelines :-
    http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
    To check Defrost Timer, follow the below guidelines :-
    http://www.acmehowto.com/howto/appliance/refrigerator/check/defrosttimer.php
    To check Condenser Fan Motor, follow the below guidelines :-
    http://www.popularmechanics.com/how_to_central/home_clinic/1275621.html?page=2
    I HOPE THE MATERIAL IS MORE THAN SUFFICIENT FOR YOU TO FIX THE FAULT.
    I HOPE I HELPED YOU.
    DO RATE THE SOLUTION.
    ******************THANKS FOR USING FIXYA***************************
    Posted on Jun 26, 2009
    • 854 Answers
    Check the wires in the harness down inside of the lower hinge of the freezer door. I've seen them wear and short out against each other causing this type of intermittent problem. It can be related to the control board problem and your model# is one that is covered for the repair by what my paper work shows. Just google the GE phone # and give them a call.
    Top shelf of freezer and ice maker not cold and top shelf of fridge not cold. everything else on bottom shelves is frozen and cold .GE model GSS22JEMA
    Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator Defrost Timer Problem
    Water Running in refrigerator from Freezer
    heatman101
    Sep 17, 2010 | GE GSS22JEM Side by Side Refrigerator
    I have A GSL25IFRF bs side by side fridge with ice and wter dispenser on the outside and I am not sure how to connect it to work so I can get ice and water
    On the back right side facing the refrigerator at the bottom is a connector for a quarter inch water line. Sometimes you have to loosen the back to access this. Hook your water line up here.
    Jun 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    Ice maker not working on GE side by side
    Here is a tip that I wrote about the reasons why ice makers do not work.
    Ice Maker Problems and Ice Maker Troubleshooting
    heatman101
    iyooyi76
    Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
    Ice maker quit working and is causing ice build up on the back of the freezer
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Hola: my GE PSC25PSTBSS sometimes is not cooling in the fridge side. some days it is at ~50F and other days at 37F. one year ago it was not cooling anything and GE technician replaced the fan unit from the...
    edtorres: if the freezer side and ice maker are working fine then the problem may be the damper that allows cooling into the refrigerator side is having trouble opening or the controls to the damper are defective.
    Mar 06, 2010 | Refrigerators
    GE Profile Arctica ice dispenser switch quits working
    I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
    http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
    It was covered under warranty , at the previous customers residence .
    Nov 20, 2009 | GE Profile¿ Arctica® Energy...
    I have a PSS26 ge profile fridge and it quit making ice
    The icemaker is bad . You have an electronic icemaker and the internal boards cannot take the freezing and the heat (freezing moisture) . Just replace the icemaker .
    Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Ice and water is not coming out. ge side by side
    Check the plug to the door first. Then turn the ice machine head off unplug the refrigerator for a few minutes. Plug it in and turn on icemaker. this part problably just lead back to squre one. have someone push the button for water while you are listening at back bottom for humming sound,if you dont hear it its probably a bad water valve.
    Mar 21, 2009 | GE Refrigerators
    GE GSS25LGM Ice maker
    one of the valves could be open circuit. ice build up where the pipe enters the cabinet or sadly if not that then the complete ice maker. hope this helps
    Feb 11, 2008 | GE GSS25LGM Side by Side Refrigerator
    GE GSS25IFR Side by Side Refrigerator Logo
    235 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Ilia Bichin
