Maytag washing machine is not stoping puring watter in the moment of wash
  • 109 Answers
The water inlet valve needs replacing.
Over time they lose tension on the spring and the seal wears out cause the inlet valve to constantly let water in.
Hope this helps!?
Posted on Jun 26, 2009
Maytag bravos stoped working during a wash cycle. No lights or power. Outlet has power. Just bought it brandnew 3 weeks ago.
then call them , (the seller )about getting warranty service . if you touch it there will be no warranty
Feb 07, 2017 | Maytag Washing Machines
My maytag has error f 28
F28 is a communications fault between control boards. Before throwing money at it, check all wire harness connections. Make sure they are clean and tight. Check for oxidation on the gold terminals. Remove the connectors and put them back on 4-5 times to clean the terminals. Recheck the machine operation.
Jun 13, 2016 | Maytag Epic Z and Performance Series 2000...
My Maytag washer stops working after water had filled, why?
The lid switch may have chosen that exact moment to fail.
Aug 12, 2015 | Maytag Washing Machines
Door will not unlock
Press the start/pause pad to stop the machine. • It may take a few moments for the door lock mechanism to disengage.
If that doesn't work, try unplugging the machine for a few moment. door lock should disengage
Feb 05, 2011 | Maytag Neptune MAH5500B Front Load Washer
Wash machine model mav 7600, started making tremendous noise, first in spin cycle only and then in wash cycle also. After running a few loads with the noise the machine just stoped running....
This sounds like collapsed/broken drum bearings. Check for movement between inner and outer drum. Also rotating the drum by hand will be hard (or immpossible), and noisy. It could be the motor and belt, but most times it is bearings.
Aug 11, 2010 | Maytag Washing Machines
Low watter on wash cycle is there a setting to add more watter to the wash cycle
Try checking the pressure switch. If adjustments are there try. Otherwise you have to check with another switch assy.
Try cleaning the small water hose connected to the switch assembley body.
Mar 30, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Watter likage from underneeth
leakage underneath can (pump) front boot ) and maybe the rear drum seal . I would not use till cked it may get the electronic controller wet if the boot has failed .and they cost big bucks. the front will have to be removed for this . (open door remove 4 screw's in hinge and side then pull out on the top corners /tilt to 30 deg and lift off .. ****.
Dec 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
SHUTING DOWN DURING WATTER DRAIN
defective pump..but replace pump and belt at the same time,,,onthejob
Jan 09, 2009 | Maytag Performa PAV2200
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
