Question about Carrier Heating & Cooling
Ac fan not turning on I can ''stick start it'' but which direction?
Ac making buzzing/humming noise when thermostat is turned to the cooling temperature. Fan is not spinning on it's own but I can take a stick to turn it to start it. Capacitor and motor replaced last year. Which direction should it be turning? It will stick start in both directions. Clockwise will blow a lot of air out of the top, but it seems a bit cooler than usual (it's night time maybe?). Counter clockwise will not really blow out the top any air. The motor housing is warmer than it should be this late at night. How do I know which way it should be turning? I don't think the ac in the house either direction is blowing air that is very cool and the thermostat is maintaining, not lowering like it should. I'm hoping if I can keep it spinning in the right direction it will cool the house down a bit for the night until I can fix it tomorrow. (cap. /maybe motor) My wife has MS and can't get hot. Anyone up this late? HELP!
1. Which direction should the fan blades be spinning?
2. One direction blows a lot of air out top like usual but not warm air (it's evening?) the other direction spins doesn't reallly blow any air out the top of unit.
3. Does this sound like the capacitor and how can I tell if my compressor is shot?
    Problem Solver:
  • 7 Answers
The condensor fan should be sucking air from the top and blowing it through the coils, probably a counter clockwise direction. The buzzing/humming sound is confusing to me. A humming sound sounds like a motor that can not turn over to start. A starting capacity would be needed. Just because you changed it out last year does not mean it is good. A buzzing sound sounds like a contactor problem. Contactors buzz and after a while, they will fail. In any case, you can "stick start" the condensor fan PROVIDED you are sure the ac compressor is working (this is for a short and temporary use). Also, you may have a high load duty capacitor that assists in the unit running. This will affect your condensor fan operation if it is not good. Unless you know all the components and operations of ac electrical, I would highly recommend calling out a professional.
Posted on Jun 26, 2009
  • 82 Answers
I am sorry but I have to disagree with what the other guy said.
First, all condensing units suck in through the coils and blow out the top. (it's probably the capacitor why the fan motor wont run.)
Second, you mentioned that it was not warm air like you expected-again the capacitor because on these units the capacitor is a dual job that connects to the fan and the compressor. If it's bad the compressor will just sit there and its casing will get hot.
(it is a bit unusual for both sides of a capacitor to go out so make sure and check for loose wires-in particular the black wire in this case.)
The buzzing sound could be the motor trying to work with a bad capacitor, or it could be the contactor buzzing-no big deal either way, once you fix it that will go away.
Posted on Jan 30, 2015
My rooftop air conditioner is making a humming noise, but will not blow out air. The fan will not kick on manually from the thermostat. The humming stops when I turn the thermostat to off.
check the capacitor of the fan motor may be it was bust u can see physical by the size bulge if u found damage. change it to new one with same rating then it will fix your humming problem.
Aug 20, 2016 | Heating & Cooling
Goodman air handler ARUF036-00A-1A does not blow air in heating or cooling mode only hums/buzzes, what could it be?
Looking at the wall thermostat, you will see the fan switch that has two settings: fan auto, fan on.
You will need to place the fan switch in the fan on position for testing purposes.
This will make the indoor fan run continuosly, and never cycle off.
In the fan auto position, the fan will turn off when the thermostat temperature setting has been satisfied.
Remove the air handler access panel.
Is the air handler fan operating?
If the fan isn't working see if you can listen closely if it is humming, or can touch the motor to see if it is hot.
If it is humming and has a bad capacitor, you can tell this without having an electrical tester by spinning the fan wheel by hand.
Be very careful... making sure your hand won't get cut by the fan wheel spinning when it starts up.
If the fan spins and picks up full speed, replace the defective fan capacitor.
It is the shiny silver metallic cylindrical object with electrical wires attached to it.
Make sure you write down where those wires attach and turn the power off before removal as they carry 240 volts to the fan motor.
If you find that the fan wheel doesn't turn freely when you try to spin it by hand, the bearings have seized and you will need to find another fan motor of the same size, shaft length , speed , and horsepower to replace the defective motor.
Keep in mind that a humming sound in the air handler COULD be from the transformer instead of the fan motor.
The transformer is a black cube shaped device with electrical wires attached to it.
If the 24 volt transformer goes bad, your thermostat will not function and nothing will come on.
Dec 01, 2014 | Goodman Heating & Cooling
Turn on AC but outside unit fan doesn't move
Either a very bad Capacitor, or the fan belt came loose and the motor is just spinning
May 26, 2014 | Empire DV-215 Direct Vent Natural Gas...
My 2006 chevy cobalt is making a loud buzz when in park and ac is on
Anytime the a/c is turned on the cooling fan will come on so that the engine does'nt over heat.It will not turn off until the ebgine has colled down.
Nov 02, 2012 | 2006 Chevrolet Cobalt
Loud humming noise from under my Tahoe 2 WD
Is it closer to the back of the vehicle or the front?Possibly the fuel pump. Try opening the gas tank and stick your ear close to the intake of the tank while someone turns the key.
Aug 02, 2012 | Chevrolet Tahoe Cars & Trucks
Loud humming noise from under my Tahoe. 2WD
The noise is your fuel pump which should hum, but not buzz. It is going bad & will need replaced soon.
murf427
Aug 02, 2012 | Chevrolet 2001 CHEVROLET TAHOE Chassis...
After oven turned on for normal baking it starts to hum rather than typical noise from exhaust fan.
If you're not hearing the fan turn at its normal speed, it is possible that your fan motor has become stalled. AC motors will often hum or buzz when they can no longer turn but still have power applied to them. This could be due to bad bearings, or a blockage of some sort. It's probably not easy to get to, but if you can hand check the fan it should spin quite freely. Be sure to unplug the unit before messing with the insides, or shut of its circuit breaker if it's a built-in unit.
Dec 24, 2010 | Dacor ECS130 Epicure Electric Single Oven
Our window AC/heat unit fan only buzzes when turned on- no matter whether you turn on fan only or heat or cool mode.
so the fan does not spin and blow air? it could be a stick broken fan try free spinning it make sure its turned of. if fan spins freely its probably your start capacitor which is not to expensive.
Nov 10, 2010 | LG Heat cool Window Air Conditioner
Heating & Cooling Logo
4,724 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
