Question about RIM BlackBerry Pearl 8100
Can't scroll down with track ball. Pl. suggest
  • 129 Answers
Clean your trackball regularly by slightly dipping a cotton swab into rubbing alcohol and using that to clean your trackball.
Unfortunately, dirt and oils on your fingers wear out the trackball over time, causing it to behave in unpredictable ways.
Posted on Jun 26, 2009
When i push scroll button down nothing works only side to side up and down works
This is very common for the blackberry's. Sometimes the trackball gets full of lent and dirt which won't allow the wheels to move. The chrome ring around the ball just pops off and the track ball should come out. Try cleaning it with a small brush. If this doesn't fix the problem, then a new track ball can be purchased on ebay for less than $5
Dec 03, 2009 | RIM BlackBerry Curve 8310 Smartphone
Rollerball will not go up it goes left and right and down
Trackball doesn't work if you have not selected the sensitivity. To select the sensitivity, kindly follow the steps: 1. Select menu. 2. Select option. 3. Select screen/key board. 4. Scroll down to find horizontal and verticle 5. Select horizontal-100 and verticle-100.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 16, 2009 | RIM BlackBerry Pearl 8100
My track ball scrolls on my blackberry curve but niether the keypad or the track ball works. how can this be soved without buying a new phone?
try cleaning the track ball with a qtip dipped in alcohol or nail polish remover.. It could be that the track ball isn't "reading" correctly due to oil, etc.
Nov 15, 2009 | RIM BlackBerry Curve 8310 Smartphone
When I roll the ball to the left, the cursor doesn't go to the left?
change the trackball sensitivity
Steps :
1. Click Menu Key
2. Go to options, under that select Screen/Keyboard
3. scroll down you will get track ball settings
Horizontal sensitivity
Vertical sensitivity
increase the sensivity to 100 then you will be able to roll track ball,it will work fine....
Oct 30, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Tracking ball not working after cleaning it exactly as directed
do a battery pull.. wait 30 to 60 seconds, the reboot up you blackberry, and firmly press down on the tracking ball as you scroll up
Jun 11, 2009 | RIM BlackBerry Pearl 8100
The track ball on my black berry pearl doesnt scroll down
yes sure!
just take it apart and clean the track ball area with amedical alcohol and brush, remove dirt from it!
plz give a good rate
that happend with mines once!!
Mar 25, 2009 | RIM BlackBerry Pearl 8100
Blackberry pearl
Common faults with Pearls, do you have warrenty on the Phone?
Send it back for replacement as its hardware fault.
I hope this helps,
Thanks.
Mar 07, 2009 | RIM BlackBerry Pearl 8100
Blackberry rolling ball will not roll down
Cleaning the track ball on blackberry phones. Remove the metal ring then the ball mechanism remember how you removed it because it needs to go in the same way. You can also try removing the battery from phone taking a qtip with alcohol the higher the percentage of alcohol the better. and wiping and rolling the ball around even without removing it from the phone. this usually helps unless the ball is extremely dirty. Below are step by step ins for removing the ball. just follow the link
Removing blackberry tracball (non BOLD)
Dec 28, 2008 | RIM BlackBerry Pearl 8100
The ball won't scroll down
Pop the ring around the track ball out with a small blade or your finger nail. Three double prongs hold it in place (bottom and both sides, none on top). Turn device over and gently tap the back. Track ball will release once ring is removed. At this point you can view the track ball and see exactely what is causing the block. Clean if needed with q-tip or remove lint/debris/etc... Just did this with my 8830. Working perfectly now. - {would not scroll down at all prior to}
Nov 25, 2008 | RIM BlackBerry 8800
Keyboard and tracking ball problems
Sounds like you have 2 different problems. Your trackball probably needs to be replaced and also your keypad needs to be cleaned or replaced.
May 19, 2008 | AT&T Blackberry Curve 8300 Smartphone
RIM BlackBerry  Pearl  8100 Logo
309 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
