Question about RIM BlackBerry Storm 9530 Smartphone
My Storms locks looking for unlock key, where is the unlock key?
My storm will on lock itself on average of a couple times a week. It's like you hit the lock button in other words. Problem is it says hit the unlock key.. where is the flippin unlock key and where can I set it. The only way for me to bypass is to remove the battery.
  • 129 Answers
The lock key is located at the at the very top of the unit, on the left hand side as facing. This is a very frequently asked question, and not a very good design element on the BlackBerry Storm.
Posted on Jun 26, 2009
One day I noticed after my kid played with my laptop dell insperion mini 1012 that my keys stopped wprking. The mouse woorks and when I searched in the control panel it says the divice is working. It has...
Look at the top right hand side of the keyboard. See if the NUMB LOCK and FUNCTION LOCK keys are lit. If one or both are lit hit the key to unlock it.
Pressing the WINDOWS KEY and the letter U will bring up ease of access window. Down the list you'll see use without keyboard and mouse. Click there and make sure it is not check marked. You may also need to turn off STICKY KEYS and FILTER KEYS and hit save to unlock it.
Try pressing the WINDOWS KEY and the letter L at the same time and see if that doesn't unlock it. If that locks it instead of unlocking it press it again to unlock it.
If none of these fixes the problem then UNPLUG the laptop from the adaptor. Turn it upside down and remove the battery. Wait one minute then put the battery back in. Reconnect the power supply and reboot the machine.
Aug 16, 2011 | Dell Computers & Internet
Chubb lock stuck in lock position key turns in lock but nothing happens
this happens because, either a stuck ball in the lock is not falling out of the way and not releasing the shackle or the tail end of the cylinder has broke. there are a couple things to try and get the shackle to release --- first, spray some lubrication into the top of the lock around the shackle area and also in the key hole,, let this sit for a few minutes and try the key again. if it still will not unlock - try to turn the key AND at the same time smack the side of the lock with a hammer and see if you can get the shackle to free itself that way. since you will not know what side is which -- try to hit the lock from both sides ( make sure you hold the key in the unlock position while smacking it ). also -- with the key turned, kinda push in and pull out WITH great force the shackle and see if this frees it up. if none of these tricks work you are going to have to grind off with a grinder.
c...
Jan 02, 2011 | Locks & Locksmithing
Hatch back will not open
With key in hand,hit power door lock switch to lock. Raise release handle & lower. Hit power door lock unlock raise & lower handle. May take a couple times is stuck in limbo between lock & unlock mode.
Jun 07, 2010 | 2001 Volvo V70
Key remote will not lock unlock set the alarm, work just done needed to reset radio code, replaced batteries in key any suggestions
you can manually relearn your key. heres how- put the key in ignition turn key and ignition to run (not start) and hit unlock on the key. repeat this 4 times and you will here the doors unlock then hit the lock button and the doors will lock and your key will work properly.- note the ignition and unlock sequence needs to be done quickly. you may need to do it a couple times to get it right.- hope ths helps you
Dec 18, 2009 | 2007 Honda Ridgeline
2005 Chevrolet Silverado Automatic door locks
I assume you mean that the central locking system will not lock the doors but you can do so manually.
Get inside the vehicle and close all doors.
On each rear door, lock and unlock the mechanism manually a couple of times. In other words do not use the key pad.
Then leave both rear doors in the locked position (manual locking) and operate the lock button on you key pad to operate the central locking system. Wait a few seconds then hit unlock on your key pad and a few seconds later hit lock on your key pad.
If the system fails to lock your rear doors you will need to get the vehicle to an auto electrician to check out the issue and rectify it for you. There are a number of possible causes which cannot be identified without physically checking the system. So you will need to have this rectified by a professional.
Dec 04, 2009 | 2005 Chevrolet Silverado
Rear doors unlock but will not lock
Automatic door locks will not lock rear doors, they open fine when manually locked but will not lock with switch key fob or when put in gear.
You mean that the central locking system will not lock the rear doors but you can do so manually.
Dec 01, 2009 | 2005 Chevrolet Silverado
Drivers Door will not unlock. Inside or outside or with the key
Pull the inside panel off ,and look at the latch itself,that latches the door,and look for the lever that locks the latch,it will be sticking out of the latch,and try and release the lock by moving the lever.
Nov 09, 2009 | 1997 Jeep Wrangler
KitchenAid gas range - Err message F5 E7 - cannot unlock door
Normally when storms hit your oven, the electronic control board goes out. That's what has happened to this oven.
Oct 24, 2009 | Ovens
The Mx310 will not power on. We had a few bad storms this week but the mx310 is on a surge protected outlet.
Those surge protectors are not really a good protection in heavy storms which means that the power unit did get damahged and therefore you may have to try and obtain a new power unit ... mybe try another unit that you are sure about its working condition to prove the problem. It may even be the printer itself the got damaged
Jul 06, 2009 | Canon PIXMA MX310 All-In-One Printer
RIM BlackBerry Storm 9530 Smartphone Logo
496 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
