Question about Pride Sonic 3 Wheel Portable Scooter
The free-wheel lever will not release.
The free-wheel lever will not move far enough to allow the scooter to move without power.
I had same proble - spray some lubricating oil on the lever, let it sit for awhile, than GENTLY tap it with a hammer. Worked for me
Posted on Oct 02, 2009
TGA Breeze S4. Why doesn't it freewheel?
hi George, if you took the brake apart , you reassembled that incorrectly as there should be a slight gap when moving the lever into free-wheel to allow the motor to move freely...Normal you put a plate the wrong way during reassembly ...a common mistake...
Now with the free wheel working correctly both wheels will move in the same direction when the brake is released either by powering forward or backwards or using the freewheel lever has released...what you described is a normal action ...because they can move independently...that's by design.. so strip the brake again and make sure plates and springs if fitted are the right way round...
Regards
Mar 01, 2016 | Health & Beauty
I cannot start my Celebrity X mobility scooter. Drops into free wheel when I apply power lever.
After a fault has accorded with the scooter and you have reset the fault. Turn off the scooter with the key and count to 10 then switch on again. This will reset the fault in the system. If still have fault, try moving the lever in and out a few times in case the brake micro switch does not make circuit properly.
Mar 21, 2015 | Health & Beauty
How do i move rascal245 without power?
Place it in free wheel by the lever in the back. It should move freely when the brake is disengaged.
Aug 23, 2014 | Health & Beauty
Rascal scooter 245
Most of these chairs have a clutch release lever near the motors. Move it into free-wheeling and it should roll nicely.
Aug 23, 2014 | Electric Mobility Invacare Pronto M41...
Scooter won't move when forward/reverse engaged.
http://mobility123.com/help-fix-mobility-scooter-powerchair/
Engage the freewheel lever
- allows you to operate the mobility equipment with the standard controls.
Disengage the freewheel lever - This unlocks the unit and allows the wheels to spin freely. You can easy push the equipment without power. This is especially helpful if you run out of battery power and need assistance.
Apr 21, 2017 | Health & Beauty
Flat battery
the scooter will not move when plugged in, if you have a free wheel lever on the back to allow the scooter to be pushed make sure the lever is in the run position also have the batteries load tested
Mar 23, 2014 | Amigo Rd 3 Wheel Scooter with 33AH Battery...
Go Go scooter wont engage gears
Try first without power to switch from freewheel to engaged. Its usually a small lever on the back by the wheels. If the scooter can be moved by hand its in freewheel. Switch the lever then move the scooter slightly til you hear it click in. They don't have brakes, They are supposed to live in gear and then are either moving or not. :) Hope this helps.
Oct 16, 2013 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
Pride Celebrity 3 wheel. The free wheel lever
My Mother buggy does the same and you can damage the gearbox, so I use a elastic try down to the bumper this stops it from moving but should there be a need I can remove it.
the Freewhel mech may have come loose so check it out.
Regards
GeWiz.
Oct 12, 2009 | Pride Celebrity X 3-Wheel Electric Scooter...
New batteries, fully charged, still wont work
I will ask but don't take offence, so many people overlook the obvious, have you checked the free wheel lever/s are not set to free wheel (if it is the scooter will be relatively easy to push forward or backward) if set to free wheel then move lever/s to drive position
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Sonic_om.pdf
this is a link for the sonic scooter user guide, not 100% sure that it is the exact one or not but it should show you were to find the free wheel lock on your scooter it is in this guide and I would be surprised if it is not the same as yours. Hope that helps. Mark.
Oct 29, 2008 | Pride Sonic 3 Wheel Portable Scooter
Pride Sonic 3 Wheel Portable Scooter  Logo
175 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
