Question about Bose Lifestyle 38 DVD Home Entertainment System System
Pretty much the same problem
I have my ps3 , a toshiba hd dvd player, and our verizon fios cable all connected to my 56 inch sony bravia lcd through hdmi. i noticed that none of the components were outputting full surround so i went out and bought an optical audio cable. i connected the cable from the optical out slot in the tv to the optical in slot on the bose lifestyle dvd. once i went and changed the settings on the bose to optical audio i noticed that pcm 2.0 came up on the display. it has surround and it sounds pretty good but i am wondering if dolby digital 5.1 sounds alot better? i have tried everything and cant get it to output on dolby digital. any suggestions on how i can get the bose to output dd 5.1? i am not real technoligically advanced so if you could break it down for me in laymens terms i would greatly appreciate it.
I have the same system. I have a Lifestyle and a Sony TV with a Samsung Blueray player. I also have an X-box 360, plus my pc with all my CDs (I-tunes) plays through my bose. Do this:
1. Use the optical cable for the blueray player to the Bose (AUX).
2. Use a digital audio cable from the cable box (either black or orange output) to the Bose CBL-SAT digital input. (it's a single audio cable)
3. For my PC, I'm using a digital cable from the pc to the Bose. I'm using the TV output because it's empty.
4. For my x-box (which I'm not too happy about) I'm using regular red-white audio cables from Bose TV input directly to the TV audio out. (You can play all of the above through this channel, but don't).
I figured the most important high quality sound should come from the blueray player and from watching regular cable tv. For picture, you should be using all HDMI connections.
Hope this helps.
MC
Posted on Jul 11, 2009
I have a sony bravia 40 inch hd tv. i also have a comcast hd box that always worked on the tv through the hdmi. One day i was having trouble with cable box so i unpluged it to reset it. now my tv will...
Your PS3 working doesn't mean a thing for the cable unless you are using that cable for your PS3. I would bet you have a bad HDMI. They are pretty sensitive to being bent. Try replacing that first. The other thing to check is to first make sure you have the proper input selected on the TV for where you have the HDMI plugged into on your TV.
Aug 25, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony bravia volume control not working with FIOS STB
found the problem after reading a post on this site. Last thing I used was DVD player so disconnected DVD Sony player, followed the factory reset instructions and now the volume works normally! It was the DVD player. Thank you so much for the info and lead. The problem is DVD not TV,
Jul 20, 2014
Apr 08, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
I am having an on and off again problem with "no sound" just a picture on my Soney HDTV Model # KDL-46S2000. I have Verizon Fios and they have been out several times to try and fix the problem by changing...
when the sound goes out again ..try connecting a dvd with the same wires and input ...this will let you know if it is a tv problem ...and if it doesnt go out ...when you do this .. verizon need to check the sunrise readings to your set top box
May 20, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
New Proscan 40 goes to green screen when using HDMI cables
I have the same problem with a 40" Toshiba LCD, Component cables work fine with FIOS but not HMDI, goes in and out then blank. HDMI with DVD player works fine. Best buy reported this same problem from users with this toshiba lcd but no solution.
Dec 26, 2009 | Proscan PS50700 50" Rear Projection...
Trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Aug 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
Jul 25, 2009 | Sharp DVMX1U DVD Player
Sony 52" Bravia LCD will drop picture and sound for 1-2 seconds
the only thing that i can think of is that the cables and connections are bad but if that is not the case it may be the internal components of the tv. my guess is that the tv was dropped or jumbled around while transported and what happened was internal components were broken or just mixed up so go to the retailer and get a refund or a new tv. hope this helps
May 22, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony Bravia
I have purchased KLV-40W400A Full HD but I am not satisfied with the picture quality. When the issue was raised sony is putting blame on Tata Sky and vise versa.
Kindly suggest.
Jun 19, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Code to enter on remote
i have new Sony BDP-S350 Blu-ray disc player. i want to connect it to E-net and some other devices, Camcoder, Pc, Laptop. i have got all HD ready cables,
I want to use the Universal Remote from my Sony Bravia LCD 42'' TV and Blu-Ray. can anyone help me?
thanks
omar
Dec 10, 2007 | Sony BDP-S300 Blu-Ray Disc Player
Bose Lifestyle 38 DVD Home Entertainment System System Logo
590 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
