Question about Anycom HS-890 Wireless Headset
I have got my anycom as a present from a friend. He is an expert freak but working far from here. Since, he paired my Nokia 6680 with the device I am using it with no problem. Recently, I have bought a second hand Nokia N70 and want to swap it. But, N70 doesn't recognize it? I have only car charger kit and no USB cable connection for my anycom. Is it possible to pair two cells at one time or I must to disable my previous "pair" first? Please HelpVladimir, Sarajevo
5 Suggested Answers
  • 405 Answers
SOURCE: forgot what the default pairing PIN is.
Default pin is "0000"
Posted on Feb 19, 2009
  • 19 Answers
SOURCE: pairing a anycom paros-10 an its asking for a passcode
Most of the time you will use the passcode 1234 are 0000.
If not email me back.
Posted on Jan 02, 2010
SOURCE: Need to find process to put Anycom HCC-250 device
press and hold power button for 6 seconds and it will start discover mode.
here.s a link to manual i found on line.
Posted on Sep 17, 2010
SOURCE: How can I pair the anycom ARIS-21 bluetooth with
Just push the button for a long time until the led is not flashing but the colors of the led are changing red and green. I connected it to my laptop and my phone too.
Posted on Sep 27, 2010
Can't figure out how to pair anycom bsh 100 with my phone
you must put your blue tooth device into discovery mode most manufactures use the power button,by holding it for 6 to 10 seconds while turning it on will put it into discovery mode and if you have your bt power turned on in your phone menu then you can search or add new device,once they have paired it will ask for a pin or pairing code .Most blue tooth device manufactures use a 4 digit pin code they are as follows 0000,1234,9999,or 1111 i hope this helps
Feb 20, 2011 | Anycom BSH-100 Consumer Headset
Can not figure out how to connect my ANYCOM Milos-9 to my cell phone. no instructions came with product.
Turn off the Anycom headset. After it is off, press and hold the silver power button. You will see a blue light come on but dont let go off the power button, keep holding it till the light turns red. Then the device will be in pairing mode. Turn on the phone and make sure that the phone is visible in the bluetooth settings. Scan for a device in the phone and you should see the Anycom headset. If it asks for a code to enter then the code is either 0000 or 1234 or 9999.
Dec 27, 2009 | Hagenuk Anycom MILOS-9 Bluetooth Headset -...
Dec 20, 2009 | Anycom Aris21 Bluetooth Headset Wireless...
I need to know how to connect it to my phone
The owners manual for the Aris21 Bluetooth Headset is available here:
Specific instructions on how to connect it will depend on your Bluetooth mobile phone model. Typically, this has to be done by going to a setup or connect menu and then selecting the options to discover Bluetooth devices.
Before you start the process, make sure the Aris21 is fully charged and the charging cable is disconnected from it and while the
Aris21 is powered off, press and hold S1 for 10 seconds: red and green LEDs flashing alternately will indicate that the headset is in pairing mode.
Then follow the operating instructions for your Bluetooth mobile phone to start the pairing process. Bluetooth may take several seconds to establish a connection.
Your phone's display should indicate that it has found the “ANYCOM ARIS-21” headset and asks if you want to pair it. You should confirm this. The phone's display would prompt you for a passkey or PIN. Enter a sequence of “0000”.
The headset LED will flash green every 3 seconds, indicating successful pairing. Usually the phone will also ask whether
you want to change the headset's name. It is recommended to approve the ANYCOM ARIS-21 name and not change it.
If pairing does not occur as expected: Turn the headset and the phone off and wait for 10 seconds. Turn the headset and phone on again and repeat all steps from beginning. Pairing does authorize the devices like mobile phones and headsets with each other and only needs to be performed once.
After successfully pairing the ARIS-21 and the mobile phone, you may need to establish a Bluetooth link between them according
to the operation manual of your mobile phone. To establish the link, press S1 shortly. Use Nokia 6130i as an example, the mobile
phone will show „Do you accept ARIS-21 request for connection?” Select YES to establish the link. You are ready to make and
answer calls on the Headset. For other phones, please follow the operation manual to establish the link.
Aug 30, 2009 | Anycom Aris21 Bluetooth Headset Wireless...
How to open line the Nokia 6680
hey there, as far as australia is concern most of the service providers(3mobile,virgin,vodafone,telstra,optus, etc.) over there put a network lock on each n every cell phone they sell. It seems your cell phone is network locked so you can either search a NETWORK LOCK OPENING HACK on internet or try to contact the customer care center of the same service provider where your friend bought this cell from.
Mar 15, 2008 | Nokia 6680 Cellular Phone
Sim card not valid on nokia 6680
try to use the same line on diff phone that accepts your card, activate pin request to "ON" and make a call using this phone,
now take the sim to the 6680 and see if it works.
if this doesn't work find a new phone
Mar 10, 2008 | Nokia 6680 Cellular Phone
Nokia 6680 wont connect to Bluetrek G2
Just had the same problem.
But I found some bluetrek instructions on the net & it works
Pairing the BLUETREK® G2
Before using the BLUETREK® G2 headset, you must pair it with your Bluetooth® mobile
phone. Pairing is the process of linking 2 Bluetooth® devices, so that they can
To initiate pairing:
1. Place the BLUETREK® G2 and your mobile phone within 0.3 meter (1 foot) from
each other.
2. Switch on your phone and select its Bluetooth® discover mode (refer to the
Bluetooth® mobile phone user manual).
3. When the BLUETREK® G2 is switched off, press and hold the TALK button for
about 7 seconds until the indicator light flashes red and blue alternatively. And a
sound can be heard in the speaker.
4. Once the mobile phone detects the headset, a “BlueTrek G2” message will be
displayed. Follow the phone instructions to accept the pairing. The PIN code (or
passkey) is 0000, then press “yes” or “ok”.
If pairing success, the indicator light will switch to blue and flashes slowly.
If you haven’t started the discovery mode within 5 minutes, the headset
Jun 26, 2007 | BlueTrek G2 Consumer Headset
Anycom HS-890 Wireless Headset Logo
Top Anycom Radio Communications Experts
Michael Vincent Cruz
ray gallant
Are you an Anycom Radio Communication Expert? Answer questions, earn points and help others
