Question about Canon PIXMA MX310 All-In-One Printer
Can receive but can not send out fax - Canon PIXMA MX310 All-In-One Printer
    Champion:
  • 220 Answers
Faulty liu/modem board
Posted on Jun 26, 2009
Hp 8500 printer/fax machine will no longer receive a fax in color but can send in color. it used to work fine both ways. What can I do to fix the problem?
If the person who is sending the fax cant send in color, then you would not be able to receive the fax in color. Just make sure you choice the option to received the fax in color. Ask someone to send you a fax in color and just received in color.
Feb 17, 2013 | HP 8500 Premier All-In-One InkJet Printer
Cannot send or receive faxes to one particular number, but is able to send and receive faxes with other numbers
"cannot send or receive faxes to one particular number, but is able to send and receive faxes with other numbers"
If your machine can receive a fax transmission from one number, it will receive from all numbers.
If your machine can send to all but not to one particular number, please check that there is a fax machine there to receive it.
You can try to send manually and listen for beeps from the other fax -if one is present- then push the START button to initiate transmission.
If their machine is in working order, the transmission should start. (After the initial 'handshake' of course.)
Jun 16, 2011 | Office Equipment & Supplies
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
1. Press Setup.
Send &
Receive
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Fax will not send
Does the receiving or sending party have a DSL phone line?
Aug 01, 2008 | Brother MFC-8220 Fax
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Setting up fax machine to receive
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Sending Methods Sending From Your Machine (Memory Sending)
  1. Load the document on the Platen Glass or the ADF.
    Sending from the platen
    Important: When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
    Sending from the ADF
    *MP830 shown
  2. Press <FAX>.
  3. Adjust the settings for your document as necessary.
  4. Dial the recipient's number using the numeric keys or speed dialing.
  5. Press <Color> for color sending, or <Black> for black & white sending.
    • When the document was loaded on the Platen Glass:
      1. When the following message is displayed, load the next page on the Platen Glass.
        If you have only one sheet to scan, press <OK>..
      2. Press <Color> to send in color, or <Black> to send in black and white.
        IMPORTANT: If you do not press the same button you pressed in step 5, the machine does not start scanning.
      3. Repeat steps 5a and 5b to scan in all pages of the document.
      4. Press <OK>.
    • When the document was loaded in the ADF:
      The machine starts sending automatically after the document is scanned in.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
  • To cancel sending before sending a fax, press <Stop/Reset>.
  • To cancel memory sending while sending a fax, follow any instructions on the LCD after pressing <Stop/Reset>.
  • If the document remains in the ADF after pressing <Stop/Reset> during sending a fax, press <OK>. The remaining document is automatically fed out.
Sending From Your Machine (Manual Sending)
Use manual sending when you want to talk to the recipient before sending a document, or if the recipient does not have a fax machine that can receive automatically.
Caution:
  • With manual sending, you cannot use the Platen Glass to send documents.
  • You will need to connect a telephone to your machine if you want to talk to the recipient before sending a document.
Follow this procedure:
  1. Connect a telephone to your machine if you want to talk to the recipient before sending a document
  2. Load the document in the ADF.
  3. Press <FAX>.
  4. Adjust the settings for your document as necessary.
  5. You can lift the handset if one is connected to the machine.
  6. Dial the recipient's number using the numeric keys or coded speed dialing.
  7. Talk through the handset to the recipient. (If you hear a high-pitched signal instead of the
    recipient's voice, go to step 9.)
  8. Ask the recipient to set recipient's fax machine to receive faxes.
  9. When you hear a high-pitched signal, press <Color> for color sending, or <Black> for black & white sending. Then hang up the handset.
Jan 07, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
80 people viewed this question
old marine
old marine
