Question about Nokia N72 Cellular Phone
I sprayed a shower on my n 72 what should i do?
The battery and the system is working but i am not switching it on because i can see vapours in side the screen what should i do?
  • 436 Answers
Remove the battery from the phone and keep your phone in an open dry space(under a ceiling fan),but never try to heat the phone.After making sure that all the moisture content is escaped you can use your phone
Posted on Jun 26, 2009
My grohe 5 spray plus hand held shower is locked in the hand held position and I can't get the top shower head to turn on. The control used to switch easily from top spray to hand held but is now locked...
The control may be clogged with mineral deposits and consequenly unable to function. You can try disassembling the shower to remove the deposits but it may be necessary to replace the complete unit.
Feb 13, 2014 | Grohe 28.444.AV0 Movario 5 Spray Hand...
How to install
If you want to install 72" Shower Rod then you should call a professional as he can fix this problem very easily.
Apr 14, 2013 | Mainstays 72" Shower Rod
RF?>? got a new 72 pin nintendo system off ebay
Ok to begin its quite possible you have been scammed and given a broken console to which you should try to get a refund.
First be sure everything is securely in place Better Safe then Sorry
Second make sure that you are on the right channel usually Channel 3 or 4 but i would recommended checking the Switch itself for that information
If this doesn't work try cleaning your Cartridge with a Cotton Swab and windex 1 Get a small cup to spray the windex onto 2 Dip one end of the Swab in the windex 3 Carefully Clean the Connectors on the Cart with the Windex Side 4 Dry off the Cart with the Dry side or another Swab if yours only have one side 5 Plug it in and see if it runs
Its Also Possible that your RF connector simply doesn't work with the Nes you can find a replacement here
If all else fails you can try Repairing it which is no my real area of knowledge
You can Find one guide here
If that doesn't work and your willing to spend a good 30 dollars you can get it repaired here
Well i hope this helps and happy gaming
Feb 28, 2011 | Nintendo NES Console
I have an SI-538 shower companion cd player/fm radio. It works with the adapter plugged in, but it won't run on batteries all of a sudden, even if they are brand new and the correct voltage. What could be...
Check the battery terminals for corrosion, and if possible spray the terminals with some switch/contact cleaner spray... the other problem maybe a bad solder connection on the adaptor socket, not allowing connection from the batteries to the unit.
Aug 27, 2010 | Audio Players & Recorders
How do I install rough plumbing for a 015-BD0K side spray by Price Pfister?
The side spray hose has to connect through your faucet diverter. If this is not equipped with a side spray outlet you can still run splitters available at any local hardware however your side spray unit will not have any temperature control.
Feb 16, 2010 | Price Pfister 015-BD0Y Body Spray Trim Kit...
I just installed body sprays in my shower. Two on one side and two on the other. I went to the basement to turn the water back on. I came back to the shower and one side of body sprays are running, the...
If the sprays are on individual controls for the sides you MAY have a stuck pressure balancing valve or mor likely the service stop valves MAY be closed. These are small screwdriver controlled valves usually behind the escutcheon of the control valve. They turn CCW to open.
Nov 19, 2009 | Grohe Home
Shower/tub converter dial will not switch to
found someone else to help.....problem wasn't with airconditioner...you didn't even read my email!!
Nov 14, 2009 | APC Heating & Cooling
Nokia N72 Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
