Question about Frigidaire FTF2140E 3.5 Cu. Ft. Front Loading Washer
LG stinks too
I have the same problem, I have to run and empty load with bleach (what a waste of energy!!!!!!!) and leave the door open all the time. Poor design!!!!!
  • deborah_h527 Jun 26, 2009
    Thanks, I'll give this a try.
    President:
  • 1,185 Answers
It is not a poor design its the way we have gone re washing clothes
Old machines washed hotter and with more additives in the powders.
Try using a good strong mix of soda crystals in hot water , pour that into the wash before you switch it on and do a hot wash without any soap powder
Use old fasioned powders for a couple of weeks and do a hot wash once a month with the soda
The constant cool washes leave body fats from the clothing inside the machine as there is no real heat to melt them and no soda in the washing powder anymore to unstick them from the surfaces .
Posted on Jun 26, 2009
My lg tromm front load washer smells
Try this, It's involved but it worked on my Kenmore HE4tDrain the machinePull the filter (have a sheet pan, wet vac and towels handy, there's a lot of water)Disconnect the drain boot from the pump and tubDisconnect the pump drain hose (waste)Disconnect the pump electricalWash everything (not pump motor) in a 25% bleach solutionReassemble.Put 1 gal boiling water, 1 gal hot water and 1/2 cup bleach in washer compartment. check for leaksWash entire compartment with the bleach water and spin the drum time to time for 15 minutesAdd TechnoFresh (which claims to loosen gunk) to the powdered soap dispenser, through a bunch of rag towels in and run the machine on the hottest cycle.This process works well until machine is stinky again (about 6 months depending on bleach usage)BTW "the leave door open trick" only helps the door gasket and does not address the constant reservoir of fermenting water in the bottom of the machine
Feb 11, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My clothes stink so bad from my front end LG washer! My co-worker on my first week of work started buying bath and body sprays and body wash leaving it on my desk. I'm so pissed off because my washer was...
My LG stunk too. I did the tub washing with 1 cup bleach and wiping the rim, leaving everything open, nothing worked. I added 2 cups of a 6% bleach and used the tub cleaning cycle, rinsed with an empty hot water cycle then added bleach-able clothes to the 2nd hot water rinse (the third cycle/step). It gets a very strong bleach smell so don't take a whiff if you open the door in the first 2 cycles! After I did the strong bleach cycle, I am able to treat with just the 1 cup bleach about every 3 or 4 weeks and I make sure to wash with a hot water wash every week and a half at the least. This seems to keep my clothes smelling fresh like they should. Before I bought the LG, I read where people turned up the amount of water the washer takes in but I can't find the link that said how to do that. I think it was 1/4 turn on a screw on the top of the machine (when you take the cover off) but I can't guarantee how to do that.
Jun 26, 2010 | LG WM-2277HW Front Load Washer
Washing Machine Stinks
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Nov 21, 2009 | Dryers
My machine has such a strong smell when the door is left open that is goes thru my whole house. I have black mold in the rubber ring - my machine is only 2 yrs old. Is LG helping their consumers?
Nov 09, 2009 | LG WM2688HWM TROMM SteamWasher
There is a moldy smell....I have ran a load with no clothes and just bleach and it smelled ok for a week and now smells again
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub/basket, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 24, 2009 | GE WSXH208A Front Load Washer
My GE Adora front loader- our clothes stink!
Clothes washing rules for mildew stink: 1) never leave clothes in machine for more than a few hours 2) never add too many detergent or clothes 3) clean the machine itself. Also if your fabric softener port is gummy there is a good chance you got some funk from that so clean all places where you have fabric softener contact. After all that, if this doesn't help you may need to run an empty load of strong hot bleach water and follow it with a hot empty rinse then a load of whites
to becareful not to ruin your colored clothes
Aug 09, 2009 | GE WSXH208A Front Load Washer
LG WM1812CW washer smell
Usually caused by doing all low temperature washes. Every 2-months do the hottest wash, with a good suirt of qualuity bleach. Also check the waste pipe of the wahing machine is high enough, so it does not **** dirty water back from the drain.
May 26, 2009 | LG WM1812C Front Load Washer
Our front load washer stinks like stale water inside. How do we clean it out?
the only way is to run a empty load of warm water w/heavy bleach after running cycle wipe door boot/gasket out with like kitchen cleaner w/bleach making sure you get in between the tub and the front panel on the boot. then you have to ALWAYS leave the door open to dry. TRY THIS AND LET ME KNOW
Bill
Jan 09, 2009 | GE Energy Star WCVH6260F Front Load Washer
Smelly clothes and machine!
Do you wash whites separately or with bleach? Sometimes changing up the loads to whites with bleach would kill the germs.
Jun 12, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Frigidaire FTF2140E 3.5 Cu. Ft. Front Loading Washer Logo
154 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
