Question about Bosch Washing Machines
The machine keeps stopping and starting,rather than filling continuously it seems to stop and start and the same thing is happening when it finally starts the wash cycle?
  • 3,230 Answers
It seems like Drive motor
Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other, It also cause over overfilling. If this happens, you need to replace the entire motor.
Good Luck!!
Thanks
Posted on Jun 26, 2009
Hello. Recently my fisher &PAkel smart drive 703 was removed from its connections as we renovated our laundry. When it was reconnected by our tiler, it stopped working properly. This is what hap
Need to know the error code to help you. When it beeps, take note of the top row of lights & count from right to left. Tell me exactly which lights are on & which are off. Also, tell me if any other lights are blinking. The only thing the tiler would of disconnected are the inlet water hoses. Check that the hose from the cold tap is on the cold inlet & hot tap is on the hot inlet. Marked C & H on back of panel.
Mar 06, 2017 | Fisher and Paykel Washing Machines
GE WPRE8100 washer starts to fill and immediately shuts off
I would suspect the washer control panel or timer is the problem.
Jul 25, 2017 | GE Profile WPRE8100G
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
Won't stop filling. When I go through the cycles it continues to fill until I reach the final spin cycle then it will start draining and spin out.
Two common problems for this simptom:
If water stops filling when you disconnect the washer:
Change the pressure switch.
If water keeps coming in after you disconnect the washer:
Change the water valve.
GOOD LUCK MY FRIEND
Aug 30, 2009 | GE Washing Machines
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
On/off button & non crease button flashing
Sounds like the pump and sump hose is blocked,Check both out
Oct 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Washer fill with water after final spin cycle
CHECK THE TIMER MODULE ,the one you pull and push to start and to stop ,that could be damaged , try different cycles , like DELICATES cycle , see what happens, hope it helps AJ
May 05, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
