Question about Canon MVX250I Mini DV Digital Camcorder
Cassette loading - keeps on ejecting cassette
Camera on off
Open loading as usual
Insert cassette
Close casing from side
Motor starts running
Cassette ejects
Tried different cassette's/even checking tension on cassette itself???
  • 3 more comments
  • yasirawan Nov 26, 2007
    I cannot charge my camera, It does not work at all.I have tried replacing battery but no joy,Any idea
  • rethga Jan 01, 2008
    MVX250i - 3 years old
    get eject cassette message when turning on
    taken battery out and put back in
    initially cassette would not eject, but now ejected will not accept a new one.
  • jez99 Sep 04, 2008
    My 3 year old MVX250i started ejecting tapes constantly last summer. It somehow resolved itself after being left on a shelf for a few months, and I got another 6 months normal use from the camera. Unfortunately its just started happening again. Really annoying as I have hardly used the thing and its in perfect condition otherwise. Cant tell whether the head drum spins up or not. Contemplating a dismantle.
  • Anonymous Jan 06, 2009
    Same problem here. Thought I was the only one but only now got into these pages. Had service already twice with more money than originall investing on the camera and still it is not working. It all started with Zoom being stuck in the tele position. Once it was fixed this cassette problem started.
  • futo Jan 06, 2009
    Same problem here. Initially the zoom was stuck in the tele position and once that was fixed with 200€ invoice this problem with rejeting cassette started. Estimation for replacing the cassette base was 250€, estimation costed 100€. Really annoying!
    Problem Solver:
  • 6 Answers
The "remove cassette" problem on Canon DV cameras is a general fault error that can be induced by many varied problems from faulty dew sensors to jammed mechanisms. These mechanisms are small and delicate and it does not take much to stop them working. If the head drum is starting the next thing that should happen is the capstan spins which in turn drives the take-up spools when the cassette loads. Tape tension problems (other than a broken tape) would not be detected until after the capstan is running. With the battery removed and the cassette door open, CAREFULLY attempt to rotate the capstan spindle. I use a small rubber insulating sleeve stretched over a small screwdriver. If this does not solve the problem then other possibilities are that the printed ribbon cable from the cassette mechanism to the camera needs re-seating or perhaps the capstan drive motor is faulty. However, try and look for the obvious first. To investigate further by dismantling is extremely difficult and I would not recommend it unless you want to risk writing-off your camera completely. I have done this operation (successfully) as a last resort and found that re-seating the printed cable in its socket solved the problem, however, I would not recommend or suggest this decision be entered into lightly. Its a good feeling when you get it working again but sickening when you have to allocate it to the re-cycle bin. As I say, this fault indication has many causes. Getting it serviced by Canon is not an option as the cost would exceed its value so unless you can find a local repairer that's prepared to look at it, then you have very few options.
Posted on Dec 18, 2007
it sounds like moisture. leave the door of the cassette mechanism open in a warm dry room for 24 hours.
then try to operate the eject mecanism as normal.
May 09, 2017 | JVC GR-DVX7 Mini DV Digital Camcorder
Cassette stuck in Sony TC-K611S deck
Rotate loading gear with your finger until mechanism released and set on stop position. press eject button and take out tape.
Jul 01, 2009 | Audio Players & Recorders
Cassette doesn't load and move down into machine
I had the same problem. With the camera on, keep taking the battery off and putting it back on. Start to close the door and then open it. Eventually you should hear it try to move. Keep doing it and it should move down all the way.
Jun 01, 2009 | Sony DCR-HC38 Mini DV Digital Camcorder
8mm Cassette mechanism fails to eject or sometimes fails to close
This camcorder is at least six years old now, and replacements are available quite cheaply vie on-line auction sites, probably at far less than the cost of repair.
Apr 05, 2017 | Sharp Viewcam VL-AH60U Hi-8 Analog...
Cann't eject cassette from Canon ZR60
I had a similar problem last few days with my ZR60.
The problem I had was that the tape won't eject and on repeated attempts to eject it would eject as if it had a mind of its own.
I was messing with it a little bit and realized that the door was not opening fully. Being a delicate item I didn't realize that I was not fully opening the door may be because there was a little friction in the pivot pins or what ever.
Try to gently swing the door open fully and see if it helps.
Since I discovered this problem I tried 10-12 times, and every time it would eject the tape and load it.
I was almost going to give up this camcorder last night thank GOD, I am able to use it.
Good Luck to you.
Dec 27, 2008 | Canon ZR60 Mini DV Digital Camcorder
Loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Dec 10, 2008 | Sony Handycam HDR-HC7E DV Digital...
Cassette jammed after camera dropped
I think your ejecter motor is not working.temporarily open with any tool.
Dec 10, 2008 | Sony Handycam CCD-TRV107E Camcorder
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Can not load any cassette even empty cassette holder can not be closed.
I had the same problem and solved it by removing the battery to allow the camera to reset. Worked fine after that.
Sep 24, 2006 | Sony Handycam CCD-TRV11 8mm Analog...
Canon MVX250I Mini DV Digital Camcorder Logo
437 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
