SOURCE: Targus COMPACT laptop charger isn't working
Your battery sounds like its buggered. I would suggest buying a new battery
SOURCE: Lenovo Laptop not starting and Charger's light blinking..
It sounds like your power cord is bad. If you got a notification that the battery was getting low and you had the power cord in, that means the power cord was not charging the battery, you were working off the batery even though the power cord was plugged in and eventually you drained the battery.
You'll need to purchase a AC Adapter Power Cord that is built for your laptop, not a one size fits all laptops that the big box stores will sell you . By one size fits all I mean the end that goes into the computer is removable and you can replace it with one of many ends that come with it until you find one that fits. Use it and you'll surely burn *********** board out eventually.
Exactly what happened to my v570.. power supply is stable when unplugged to the laptop but blinks when plugged in..i took out the battery .. same thing.. any other solutions here?
Chornic solar charger is designed to the highest technical specifications and standards ,It will supply years of maintenance free use. Chornic 14W Foldable Solar Charger with 2 Port USB Charger Build with High...
Green means you have a full battery charge.
So probably it seems your battery is out of juice. Keep it on charges & it should be fine.
If there is nothing changed, you may need to exchange the laptop charger.
Lenovo IdeaPad Z570 AC Adapter
Hope this helps.
