Question about Casio FX-115ES Scientific Calculator
I have too many zeros after the decimal point and I need to delete them. How do I do that?
  • 700 Answers
If got to do with the mode settings. Usually MODE fix in other lower version of calculator. The combination can be MODE FIX 0 for no trailing zero's if MODE FIX ONE then if will 0.0 or one zero then shifting the settings to NORMAL mode and at DEG mode.
Posted on Jul 01, 2009
If a decimal # has a value less than 1 do you put a zero to the left of the decimal point?
There is no rule requiring a zero to the left of the decimal point, but it's generally considered good style.
You don't put a zero to the right of the decimal point unless it's significant (that is, you know that digit is not 1, 2, 3, 4, 5, 6, 7, 8, or 9).
Sep 12, 2014 | Office Equipment & Supplies
Need 4 zeros past the decimal point
Go to Display upper right hand button.
Press 1 Fix then press 3 for number of decimals
Mar 10, 2014 | HP 33s Calculator
How to get rid of the two zeros on far right in hp12c?
Your calculator is set to scientific notation. To get out, press f followed by a digit representing the number of digits you want after the decimal point. To have two digits after the decimal point, for example, press f 2.
Oct 10, 2013 | HP 12c Calculator
Significant figures
Press SHIFT MODE 6 then select the desired number of digits after the decimal point. Alternatively, press SHIFT MODE 7 then select the desired number of significant digits.
Sep 09, 2013 | Casio FX-115ES Scientific Calculator
Whenever I try to add or subtract a number with a decimal in it, when I press the + or - key, it rounds the number I entered either up or down to the nearest whole number.
You have the calculator set to round everything in the display to zero digits after the decimal point. To change this, press SHIFT [DISP] and then a digit representing the number of digits you want to the right of the decimal point.
Nov 09, 2010 | HP 10bII Calculator
I'm having problems programming radio frequencies on my scanner.
You didn't mention the make or model of your scanner, so I can't provide a response specific to your unit, but the trailing zero is meaningless, so there's no reason to enter it. Some bands on some scanners will only accept three decimal digits, but the scanner should round off your entry and still receive the intended frequency.
Bill B
May 02, 2010 | Radio Communications
How to round the fig. in Excel 2007 E.g. 12350*32.75% = 4044.625 I want it to be rounded to nearer rupee. If the decimal is lesser than 50, rounded fig. should be lower Rupee if the decimal is more than 50...
The function is called ROUND. It has 2 arguments, (1) the original number and (2) the number of decimal digits. Here is the Excel's help: ROUND(number,num_digits) The number you want to round. None. num_digits The number of digits to which you want to round number. If num_digits is greater than 0 (zero), then number is rounded to the specified number of decimal places. If num_digits is 0, then number is rounded to the nearest integer. If num_digits is less than 0, then number is rounded to the left of the decimal point.
So for your case use this in a cell "=ROUND(12350*32.75%, 0)" without quotes, where I assume one or both numbers will come from other cells. -Ken
Aug 29, 2009 | Microsoft Office Excel 2007
Help me solve
1. Four Hundred Seventy-Eight Ten Thousandths
2. One Thousand Four Hundred Thirty Five Ten Thousandths.
3. Three Thousand Two Hundred Five Ten Thousandths.
4. Four thousand Seven Hundred Eighty Four Ten Thousandths.
5. Four Hundred Ninety Seven Ten Thousandths.
OR
1. Zero point zero four seven eight.
2. Zero point one four three five
3. Zero point three two zero five
4. Zero point four seven eight four
5. Zero point zero four nine seven
Thanks and please take a moment to rate as fixya.
Jul 06, 2008 | Audio Players & Recorders
Casio FX-115ES Scientific Calculator Logo
1,944 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
