Question about Dual Car Audio & Video
I have a dual in dash dvd and it won't turn on. the system is getting power bc the power light is on.....it simply won't turn on. Idea's ?
I got the same problem and i am desperate. Dose anyone know the answer? Email me, Virre_142@hotmail.com Thanks! :D
Posted on Aug 31, 2010
1985 f150 lariat with dual tanks, rear tank rusted and leaking, would like to know what to plug to make front tank work on its own with required fuel pressure. its a 302
I see that you have not received an answer yet. I had a dual tank Diesel which had a switch under the dash to change tank feeds. Both tanks reported fuel amounts to the same fuel gauge as each tank was switched on.
If this is the system you have (using gasoline) then simply turning the dash control should isolate the rear tank. If yours is different, you need to look underneath the truck at the fuel line routing.
For gasoline engines there was an idea to meet EPA Emissions standards by closing the fuel loop. This meant that unused fuel that was brought to the engine was returned back to the fuel tank. Some things were different for Trucks by weight Class and because of the EPA rules, trucks keep their carburetors while cars went to fuel injection. The "light" Trucks changed to fuel injection before "heavy" Trucks.
Most of the fittings to fuel components can have a taper machined to match fuel components only. There can be different thread seats, even Metric for replacement parts. Your best bet to match components is disconnect the problem part, take it with you, and then get a cap plug to block the flow. This is providing that the rear tank does not need the loop anymore.
Sep 14, 2013 | 1985 Ford F150
My Windows 7 does not recognise the dvd writer 740e
i understand completely. i have the same external device. if yours is an external device, simply unplug the power that supplies the dvd rom, while your system is running. and it will detect, but once you shut down and reboot you wil again need to turn the power off and then on again on the HP DVD 740e this is not to annoying at least it works right? well it does for me in my win 7 64 bit home premium. i have not found any driver or other solution. i just power off and on the DVD ROM and it then detects, sorry i cant help any more.
Aug 21, 2011 | HP DVD 740VI 16X16 Dual Layer LightScribe...
I unplugged my dvd recorder. When I plugged it back in it won't power on.
Hello
Just look at the power chord, whether it has been pluged into the slot well. Check the wall power socket also for presence of power. Replug it to an other power plug point. Till the problem perists, surely there must be some fault with its power regulator board inside. Normally, if power regulator board gets power, the power indicator must light up. If not power regulator board [SMPS] board is faulty, and should be replaced with same type and number. OK.
Jun 27, 2011 | Philips Magnavox DVD/VCR Dual Player
Dual battery system
Double insulate the positive cable like with a heater hose the same length as the cable to make sure it does not rub into the cable anywhere.Use 1/0 cable,this will carry,and hold the volts and amps,on the ground,just use 1/0 cable from that battery you are putting in,to the nearest body bolt or frame.
May 20, 2010 | 1998 Toyota 4Runner
Magnavox dvd/vcr dual player wont work with satellite! HELP
please check if have any light indicators working, if nothing. check the fuse first from primary ac. be sure cable is unplugged.
Aug 20, 2009 | Philips Magnavox DVD/VCR Dual Player
Acer X223W monito won;t wake up after sleep.
I have a dual monitor system, both are the x223w. Same problem but only on the second monitor. Backlight shuts off.On/off light stays blue. I have to turn off the monitor and turn it back on. I returned it and Acer could not find any problem so I got it back. No problem for awhile and now a few times over the past couple days. Not good...
Aug 10, 2009 | Acer 22" X223w LCD Monitor
MY DUAL IN-DASH DVD WON'T LOAD ANY DVD OR CD.
OK so be said the player will not load the CD...how in the world is he going 2 clean the lens if the player won't load anything? I'm just sayin...
Feb 03, 2009 | Dual XDVD8181 Car Video Player
I have a dual brand car monitor stereo that won''t show dvd
hi there
well to start the e-brake will need to be applied to allow you to see the video if it was installed correctly.................to over ride this feature you need a toggle switch with 3 pins on it
on the toggle switch there should be two logos (power & ground) if you run a small wire from the red wire from the back of your in-dash system to the toggle switch (power) and do the same for the black wire (ground wire)..........the last pin on toggle switch you attach the e-brake wire from the back of your in-dash system to the toggle switch pin and turn it on video will play
if this doesn't work switch the e-brake and ground wire around on the toggle switch
hope this helped
Nov 28, 2008 | Car Audio & Video
Dual-in-dash dvd player/ receiver with
The revised cord is simply a ground wire just splice it to you ground wire and you can have the video playing while you are driving try not to watch it while your driving though
it is a yellow and blue cord i have this Sterio and soled the problem the same way i discribed if you want to be able to turn the screen off for any reason you can hook up a switch in the yellow and blue wire then run it to the ground wire
Jan 05, 2008 | Dual AM/FM/CD/DVD/WMA 2.5 MONITOR Car...
Car Audio & Video Logo
535 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
